Honestly, the finish doesn’t matter to me at all. Not a bit, especially if it won’t matter with regard to a physical lock out. (I’d prefer a physical lock out, given the option, by the way). So, I agree, let the designer decide.
My guess is that they crammed the anodising tank too full. Imagine lots of tubes standing in square formation, Current density i.e. ano. thickness varying dependent on how close to each neighbour. Hence “seams” at 90 degrees.
Agreed, that would be perfect, and so durable. But proper thick hard anodising is a slow cold expensive process, I doubt Lumintop would know how, even if the alloy is suitable. It would be nice if they could though, it would lift it into a different class.
Rarely seen on a torch despite claims, the only one I have with it is an Inova X1, but I’ve also seen it on Surefires and I think Zebralight. None of which are $30 torches.
The main thing is no gaudy colours, and no bead-blast please.
Not sure whether Fritz is in tight control here, this is now quite a big project, and Lumintop will do what they do, hopefully listening to feedback.
Edit: and striving to up their game, which this already does no-matter the finish. Otherwise why bother with BLF unless you are going to listen and learn ?
Aesthetics matter to me, but I won’t get too precious about them on a $30 torch. Though it could be done beautifully and within budget.
