dekozn
(dekozn)
June 24, 2018, 7:58pm
333
interested in 10x 3000K 90CRI LH351b
Texas_Ace
(Texas_Ace)
June 25, 2018, 5:19pm
334
contactcr:
fully modded w/ stock LEDs:
XP-L V6 3D
0s: 6,369lm | 30s: 5,774lm
fully modded w/ LH351D 4000K 90CRI:
LH351D 4000K 90CRI
0s: 5,095lm | 30s: 4,687lm
These numbers were adjusted to be in line with Djozz-lumens
Thanks for the info, impressive numbers for a 90cri LED.
I am sure there have been beamshots posted but does anyone know where they are in this thread?
Texas_Ace
(Texas_Ace)
June 25, 2018, 5:21pm
335
Links don’t work sadly.
Hmm, I just might get a combo of 4000k and 5000k and make my own 4500k setup!
Is this Group buy still open? Or do we have to buy then from digikey now? I didn’t see a recent update in the op and have not had time to read BLF outside of my own threads this whole year.
Texas_Ace
(Texas_Ace)
June 25, 2018, 5:23pm
336
How much floodier are they then the XP-L? IIRC the die size was about the same?
What as the results of slicing / dedoming?
It is a bit floodier than the XPL.
Dedoming(slicing) actually works quite well.
AEDe
(AEDe)
June 25, 2018, 5:49pm
338
Yes It is open. There was a delay at the supplier. But I finally got them today.
contactcr
(contactcr)
June 25, 2018, 5:50pm
339
The Q8 reflectors still give you a nice hotspot though even with dome on so you will still get some of that signature Q8 combination love.
contactcr
(contactcr)
June 25, 2018, 6:00pm
340
Any idea where this reel falls on this chart or do we need to test again?
Edit: I guess T6 after looking at the packaging closer F2T6Q2
AEDe
(AEDe)
June 25, 2018, 6:20pm
341
yes everything are the same except about 125K colder.
Texas_Ace
(Texas_Ace)
June 25, 2018, 6:39pm
342
Works for me, puts it closer to my personal ideal 4500k color temp
I will take 20 (possibly more depending on exactly when payment is due) 4000k and 20 3000k.
Then if I can find that 5000k part number I can get some of those and try a mixed tint setup. That sounds very enticing.
@Texas Ace, you said my links were dead, right?
Strange. They were not dead 2 weeks ago.
Now I have to go back on the datasheet and search manually.
Ok, here are some not dead links:
Here is 5000k 90+CRI:
Order today, ships today. SPHWHTL3DA0GF4RTS6 – LED Lighting LH351D White, Cool 5000K 3V 1.05A 128° 1414 (3535 Metric) from Samsung Semiconductor, Inc.. Pricing and Availability on millions of electronic components from Digi-Key Electronics.
Here is 4000k 90+CRI:
Order today, ships today. SPHWHTL3DA0GF4TPQ6 – LED Lighting LH351D White, Neutral 4000K 3V 1.05A 128° 1414 (3535 Metric) from Samsung Semiconductor, Inc.. Pricing and Availability on millions of electronic components from Digi-Key Electronics.
Here is 3500k 90+CRI:
Order today, ships today. SPHWHTL3DA0GF4UPP6 – LED Lighting LH351D White, Warm 3500K 3V 1.05A 128° 1414 (3535 Metric) from Samsung Semiconductor, Inc.. Pricing and Availability on millions of electronic components from Digi-Key Electronics.
2700k 90+CRI:
Order today, ships today. SPHWHTL3DA0GF4VPN6 – LED Lighting LH351D White, Warm 3000K 3V 1.05A 128° 1414 (3535 Metric) from Samsung Semiconductor, Inc.. Pricing and Availability on millions of electronic components from Digi-Key Electronics.
Hope I helped you Texas Ace.
AEDe
(AEDe)
June 25, 2018, 7:09pm
345
Ok, I ’ll write you down in the list. You can pay any time while LED are in stock. Now only about 400/800 of 351D are reserved.
Dear AEDe,
I‘m just checking how much LEDs I need. I get back to you soon. Do you also sell the LH351D 5000K with CRI 90 or CRI 70 only?
AEDe
(AEDe)
June 25, 2018, 7:29pm
347
Hi. Only LH351D 5000K in CRI 70.
SKV89
(SKV89)
June 25, 2018, 8:51pm
349
T6 Bin would be awesome! That’s going to be similar to a 4A Cree bin. The previous ones Maukka tested were above the BBL line and had some slight green/yellow like the 219C. Maukka applied the minus green Lee filters to bring it back down to the BBL. Hopefully this T6 bin means it will be neutral/rosy without having to apply a green filter.
Lymast
(Lymast)
June 26, 2018, 4:11pm
350
Interested in 10x 90 CRI LH351D 4000K
Bob_McBob
(Bob_McBob)
June 26, 2018, 4:56pm
351
What was the tint bin of the previous reel?
Edit: F2T7Q2 , so like AEDe said, 125K warmer than the current reel and still below BBL.
Interested in 10 pcs of LH351D 5000K in CRI 70. Thank you!
