Deep discharge is to <0.6 Volts or lower.. but will write it down
Never heard of that.. will add it to the list.
That's hard to answer, at least they answered that in their FAQ, and I also did in the FAQ. Dropping can damage, but I dont think they can precisely tell what is too much etc.
I think not, but I’ll be interested in hearing his answer also. :+1:
On a side note… I use them (Eneloops) in all my cameras & have for years. I get great results with them (Eneloops)….
In fact Eneloops are the best thing since sliced bread!!!
I have some well over 10 years old that are still going strong. So far… knock on wood…. I have never had one go bad. . . :+1:
1. Will Eneloop ever make a standard sized C, D, or 9V version as their competitor Tenergy does? We’re aware that there are AA conversion adapters for this (size C, D) but the capacity is limited as a result.
2. Has Eneloop considered making a DC solar charger sold as part of a battery package as Costco sells in its AC charger version? IMO it could be a great seller for hikers, preppers, power-out emergencies, etc.
3. Has Eneloop considered making a USB battery charging port version? Competitors are coming out with more and more rechargeable batteries that have this very convenient feature.
Thanks ChibiM. New to charging eneloops and never knew the little AA's could take up to 2A charging.
Would also be interested what the technicians says allowable temps would be for charging AA and AAA for longer life as I could set
my MC3000 to cut off around that and rest the batteries before charging up to full. I always feel they get too hot when charging in some chargers but never knew for sure.
I'm also interested in knowing the answers to questions 1, 4 and 6. :) Especially question 1.
Also, I remember when Power Me Up did that 5000 cycle test on Japanese eneloops, by limiting the maximum charge and discharge levels to prevent most of the wear induced due to charge-discharge cycles.
I would like to know, if possible, the methodology used to test the eneloops for the 2000 cycle claim.
Or, more interestingly, what charge and discharge levels should we not exceed to achieve maximum lifespan?
To put it another way, which causes the majority of the wear and damage from charge/discharge cycles: Charging to full capacity, or discharging to empty (Which in this case means about 0.9 volts when 99% of the charge has been used up, not <0.9 or 0 volt)
They already do.But only available to the Japanese market.
Not sure what kind of solar charger you mean, but they have sold them a long time ago. https://eneloop101.com/eneloop-products/ see the solar chargers. if that is what you meant.
You mean that the battery will be extended and that the battery has a charger port on the battery itself?
I personally think that they will get too long, and wont fit in many devices.
@klrman. At least I got the information that the cut off temperature on eneloop charger(s) is 57 degrees celcius.
@Pablodellama: the cycle life is something they determined following the IEC procedures. More on that in the Advanced charge section on this page: https://eneloop101.com/charge/
How can I track down a supplier that will ship Eneloop to South Africa without significant postage charges, are there perhaps any Chinese agents that I can order through and be sure of getting the genuine article?
1. Ok only available in Japan. Is there any chance for a future test market
in the U.S.?
2. The discontinued N-SC1AS general concept for example looks appealing for reintroduction.
3. A USB AA version primarily for single (or more) cell applications could still fit in lights depending on spring lengths, tension, or tail cap designs. Same for various devices. Granted your comment has valid merit that it wouldn’t fit in a lot of cases. But we’re also maybe assuming that Eneloop can’t compress densities in the original design to compensate for the added length? Maybe they can but haven’t as standard AA dimensions is all they needed to accommodate and built to that standard accordingly.
@zulumoose: I don't think the technician would know. But I would take a look at ru.nkon.nl or a Japanese eBay seller, that sells eneloops with Panasonic text on the side instead of eneloop.
3. My fault sorry should’ve been clearer. This is what I have in mind.
I propose this as I’m not keen on charging ports on flashlights in particular. I think they’re just an eventual invitation for moisture and charge port grommet failures especially if an EDC.
