“Worst is any Coast Flashlight because they are exspensive and all have purplish hue beams.”
Many Coast lights do have unpleasant blue tints, but not all. My HP3 is quite blue.
My Coast HX5 has a nice white tint and is $20 at brick and mortar stores. It’s my most used light. Very easy to grab by the head when clipped in my back pocket.
I will buy one of these, soon, to mod it (just to use with 14500s)!
I like the form factor, and also that it is a push-pull (not twisty) zoomable! :+1:
BTW, can you confirm the diameter of th driver, please? Thanks in advance :+1:
Don’t. Lookit the spring in the tailcap. I just went off on the damnable AT01s for having those ballpoint-pen springs. The switch inside will be just as crappy, and it’ll be flickering in no time.
I donated a pair of AT01s to mum, bypassed the drivers to run DD from the 3×AAA carrier (so no driver issues), and it still flickers like crazy. Bap the switch and it stops flickering for a little while, then back again. No contact, some contact, maybe contact.
Save yourself the ag. Seriously, unless you intend to waste lots of time trying to transplant an Omten into that ’cap, it won’t be worth the bother. Especially trying to run 14500s…
It was the tailswitch.
Αs you have figured out, I have no idea of flashlights. :person_facepalming:
But I love to disassembly things.
I hope this time to measure the correct part.
Thanks Lightbringer, Kramer5150 and kostasb!
Those indications demoved of buying it… I wanted a AA/14500 zoomable light to mod, in this “form factor” but this doesn’t seem to be the best one for that
I will not go through that work of full switch replacement.
Does anyone know any reliable AA/14500 zoomable light, tailclicky, easy to mod (driver and emitter) on this short and tube form?
If I don’t find a suitable one I may leave this option aside and opt for an On The Road i3…
samyy, thanks for the suggestion! However, for the purposes I want it, the head of the Xtar seems a bit bulkier that what I wanted! That was the first light i thought about, but the seems to be larger that what I want Yeah, I may be a bit picky on the form currently!!
Thanks anyway!
BTW, I guess that Rofis R2 is a light that can be added to the “list of 14500 lights” we have been discussing
Is anything remotely close to a Zebralight AA headlamp?
Main priorities:
1. Lowest weight possible: ZLs come in around 2.8oz with everything (light, battery, headlamp)
2. Good efficiency - since I’d be using an AA instead of an 18650 I want as much runtime in the 1 - 70 lumen range as possible.
$60 isn’t crazy, but just curious if there’s an alternative out there for maybe $20-$30 less.
I have a skilhunt h03 (only 44g), but the 18650 battery makes it quite heavy.
Sorry to necro this thread, but did you SKV89 or anyone that have/had the OTR M5 ever open the flashlight’s head to see how it is made?
If so, can anyone show any details on that?
It is very hard to find any information of this light by someone how “dismantled” it to show how it’s done!
Thanks for the reply!
I guess the bezel wouldn’t be the hardest to access, but thanks for the information!!
I was looking for some more info on the driver “structure”, in particular.
I believe it will be more or less similar to the M3 (and the M3 clone) that some people moded here, but I wanted to be sure about that!
The UI on that light is not good at all and it has PWM, so I was looking to mod it, but I’ll only get one if I am sure it has “room” to be modded (with my skills, I mean).
Thanks again and if anyone has some more details. please share
