*** NEW *** Haikelite MT09R Monster lights *** Update *** 2018-07-03
I would suggest you to buy the DX80. Because it has more fins for heat transfer, more LEDs which are not so much overdriven. And the Battery-Power / Lumen ratio is much better on the DX80. And you have more battery capacity in a similar small package. The DX80 can deliver similar lumens much longer than the Haikelite.
But the haikelite is smaler and handier.
It is your choice.
HL is obviously over rating their lights again. They are not using the 4000K 70.2 that Texas_Ace was using. Plus TA’s measurement of 24k lumen was a little bit high if I remember correctly.
HL should be rating them closer to 17k to 18k as I think that’s the lower end of the range with all springs bypassed.
The blue was a limited run and are no longer being sold.
These 2 lights are not very close to each other. I think the DX80 is actually around 28k lumen and can sustain that for quite a while even as the voltage goes down. It’s 8 cells extend that max output.
The MT09R are not 24k lumen. It uses a FET driver so as the voltage drops the max output drops. It can drop fast due to only 4 cells.
I hope Texas_Ace can comment on what the new HL can actually put out. It’s not 24k lumen. Maybe the CW are doing 16k lumen and NW 20k lumen for a short amount of time? It’s been a while, so I don’t remember off hand.
I think the DX80 is in a whole other league from the MT09R and I don’t even like Imalent. Some people say the current versions have all the bugs worked out. It can also sustain 7k lumen for over 90 minutes. A record I believe.
I would wait for proper reviews of the new MT09R before making any decisions. Let’s see if they got the drivers right and if they live up to the claims.
Well that’s a major pity :frowning:
I got a mt09r p2 bin 5700k with TA driver… I got 21000 lumen at turn on and 18000-19000 lumen after 20-30 seconds… i measured with Texas ace lumen tube…
I can’t tell what your point is exactly. Are you agreeing with me that HL is over rating their lights again? In your case by 5k to 6k lumen?
Great news!!! Banggood sells the MT09R!!! :smiley: :beer: https://www.banggood.com/search/haikelite-mt09r.html
Not in stock yet though…
does the xhp70 peak the stated 25k lumens?
25.000 Lumen….lol…. :smiley:
My guess it’s not going to. It’s probably (IIRC) closer to something like 18k lumens OTF, whereas the original version did something like 13k~14k lumens
@Newlumen
Is your MT09R direkt from China or is that one which built Texas Ace?
It’s modded by Texas Ace. Texas_Ace MT09R Modding thread, 20k+ lumens, 80CRI, can start fires? Yes please. - #54 by Texas_Ace
The “24k lumen” version has yet to go on sale.
has anyone received the driver replacement from Dale yet?
I haven’t even received my replacement driver for my Haikelite MT01 yet :frowning:
I started a post for the replacement drivers: Haiklite MT09R GB replacement drivers
I got an email from HL on 6/7, telling me that the replacement driver would be shipped on that date.
Banggood lists them for Natural White amd Warm White. Is it safe to assume that it will be 5000k and 4000k respectively?
Yeah probably. Or more like:
5700k 80CRI(my MT09R stock LEDs)
4000k 80CRI(maybe)
I don’t think it’s safe to assume anything on these lights. I will be interested in the reviews once these factory lights ship to see if they got the drivers and UI correct and see if they come close to specs.
Haikelite does normally do warm whites. Typically they just use cool white and neutral white. So there could be an error in the description.
