there is a youtube review of an eagle eye light direct driven with a single SST40 emitter running around 2400 lumens. I think if the maker can get enough current to each LED, this light might be quite impressive. Can’t wait to get mine…shipping next week is the rumor.
I found the triple XHP50.2 version on a Chinese site but not sure where to order it for the US. Any idea if the triple 50.2 version uses a different driver than the SST40 version? The 50.2 is 6v right?
yup, xhp50.2 would do maybe over 4000 lumen per led, so 3 led would be over 10000 lumen in theory
but finding or making the driver is pain in the @ss
so SST40 is more suitable for this light
From my perspective a far more interesting question about this light is the power source. It is shown a single 26650 battery, and to deliver 6000 lumens, is going take 20 amps if not a little more, and there are not a lot 26650’s out there that can sustain 20 amps for a long period. The more output you want, such as from xhp50.2, the more power you need. 10,000 lumens is going to require 30+ amps, and if you thought 20 amps for a sustained period was difficult, 30 amps is much much worse, and in either case, the heat dissipation is going to be very big problem, very quickly. The Keeppower IMR 5200mah according to HKJ’s testing isn’t good for much more than 20 amps.
This is not such a good cell for high drain due to its heavy voltage sag. Something like a Liitokala blue or black or a Shockli 5500 would be a lot better choice. The really hot ticket would be the Samsung 30T 21700 which can do 30A continous. Depending on the driver design, a too powerful battery might burn up the driver or emitter. More testing is needed.
