The Zebras should be fine, if these truly are 10A cells. I have both the SC600w MkIV HI and the SC600w MkIV Plus. The HI will only draw about 4-5 amps, at most. The Plus will draw more, but at most 6 amps on a fresh cell and 8 amps on a low cell (more current is needed to boost it up to required voltage from a low cell).
I use Sanyo NCR18650-GA cells in both. They’re 10A cells, and they work fine. If I know I’ll be using the Plus on max for a lot of time, I’ll stick in a Sony VTC6 cell, but it’s not really necessary.
As for your other lights, they may require something higher than 10A, or at least benefit from it. Chances are that anything using a FET driver (like the D4) will simply run a bit dimmer, but not actually use more than 10A.
I recommend “Varicore” instead of “Liitokala”. I bought 4 batteries from this store and they are original and properly wrapped (I bought pointed version). Shipping prices are also fair.
And this is another store I have bought cells, but shipping cost is too much now:
I cannot afford to waste time or money on things that may or may not be what I’m wanting. So thanks for sharing your experience with a place I will not bother going to. You saved me a head ache.
I have video of cells, and showed the internal resistance is too high, I showed the four vents, I showed a real 30q to compare.
In the video, there are 2 older used 30qs and 2 of the new ones from AliExpress, all on the opus charger. You can see the two new ones have higher resistance.
Seller says ” buyers said that the product is a problem, but the picture provided is false, cannot prove that I have a problem with the product, but also seriously deal with customer service,thank you.”
Well if we all show them the cells we were sent, it proves he is selling counterfeit cells.
AI has ruled in the seller's favor. They stated I did not include adequate evidence of counterfeit such as including authentic cells in the pictures, etc.
Not really bothered as the cells are a fair price for what they actually are. They drive my modded Q8's fine. I wouldn't put them in anything that wants more than 10 amps though. I opened a dispute because the vendor is blatantly falsely advertising. Kind of shocked that so many valid and consistent disputes can be opened about a single product from a vendor and AI doesn't weigh the pattern of complains in their decision.
The risk with that is that Ali will then cancel your account, since it costs Ali quite a bit when you do a credit-card charge-back. They might not do it the first time, though.
Also, don’t you have to provide evidence of fraud to your credit card company? What is their criteria for charge-backs?
It is a shame that Ali is letting this vendor get away with what are obvious fakes. But, they’re only obvious to us. The Ali drone making the decision has no idea whether 4 holes is good or bad.
Even the vendor might not know they’re fakes. They could have been provided fakes by an unscrupulous middle-man.
I’ve had many disputes in Ali (none about batteries thou) and they always, ALWAYS have sided with my complaints after a rejection or non-response from the seller, and I never had any negative consequence to my account (once got blocked by sofirn store, but that was a store sucker punch because of a negative review)
I find it unusual that Ali hasn’t sided with the buyer in this case. Maybe you could use pictures from other BLF threads as evidence to counterfeit. I do encourage anyone with these batteries that are different in any way to open a dispute and complain directly via message to the store and give them 1 star reviews (to product and store)
I opened a dispute on Aliexpress with the Liitokala official store because the last round of Samsung INR18650-30Q are clearly counterfeit.:
Below is my complaint and the seller’s response….
I received the items and found them to be counterfeit. In testing, they became hot when run in a device requiring 9 amps continuous proving not 15A cells as advertised. I tested capacity to be 2810 mah, not 3,000. After visual inspection, the cells have four posts on the positive terminal = counterfeit. The printing on the wrap is not the correct slant nor DPI. Genuine INR18650-30Q have a slight slant or camber to SDI and 136. the cells I purchased do not. These are counterfeit and I demand refund.
Buyer rejected proposal
Comments from Liitokala Official Store:
Hello! Our batteries are all 100% genuine and the capacity power is also in accordance with the description. We do not understand that buyers use such pictures to explain that the product power is inconsistent with the description. Is there any persuasive power? If the buyer is not satisfied with our product, please return it to us, thank you!
They are disputing that “capacity power” is in accordance with the description. Typical…
They say please return it to us…typical as well knowing that the shipping costs from the US to China would be cost prohibitive. Good thing I used Paypal and a claim is in the works.
(got the “non-genuine” VTC6 from a different local vape shop when the other vape shop where I got the “genuine” VTC6 ran out of stock…)
Both VTC6 capacity tests are 3000+ mAh (4.20v drain to 2.50v @ 0.50A discharge current, using SkyRC MC3000) ; so a simple test of capacity may not be able to differentiate them apart. The IR tests will differentiate them though.
I was actually a bit surprised at how quickly and effortlessly my PayPal dispute was resolved.
1 message(no response from seller as far as I could see)…1 auto response saying my “claim” was being investigated…5 or 6 days later…full refund ( including for 4 Sony VTC6, that were part of my order)
