No worries
Will be watching in anticipation,
Even if an upgrade option is put into production I would be interested,
It doesn’t have to be a full gt unit.
Thanks for the opportunity to be part of your blf family.
Hello, who can assist me with my getting my BLF GT? there was an issue with sending my original address and I have providing an alternate address, so still waiting as of this message.
I see you were #271 on the list. Did you make the deposit?
There was a final payment deadline of Dec 30, if I recall correctly. Did you get a personal message with the payment instructions? Did you pay, but had an issue with the shipping address?
I would do that. Hopefully Lumintop is taking over this survey.
Then I would get into contact with Lumintop (Marketing.Lumintop@gmail.com) and explain that you were #271, made you deposit, made your final payment, but there was an issue with your address and that the whole thing seemed to slip through the cracks.
You can also send Neal a personal message just in case he is able to help out, but I think Lumintop are handling issues like this.
Sure, slice the dome.
With the dome on you get about a –45- 40 reduction in throw (2200m 2000 to 1200m)
With a sliced dome you get about a –27- 20 reduction in throw (2200m 2000 to 1600m)
This is based on Texas_Ace’s GT. You lose about 15% lumens by slicing the dome, which isn’t too bad.
Hopefully I remembered all these numbers correctly.
How is pricing for new version? As opposed to upgrading? If price is good then better off buying new version to have BOTH thrower and spotter versions.
You only get 0% reduction by using a led that has a die with the same luminus intensity as the XHP35 Hi. These leds exist (XP-L Hi, dedomed XP-G2, and Oslon Black Flat have even higher luminus intensity and should throw further) but have usually smaller dies so you loose output instead of gaining it. There is currently one led that gives the same throw combined with higher output, the Luminus CFT90, but it is not very efficient, it is a 3V led so it needs a new driver, it needs some modding get it fit and centered, and perhaps most significant it is a really expensive led, like over 100 dollar.
