*** NEW *** Haikelite MT09R Monster lights *** Update *** 2018-07-03
Anyne know parameters of chargers?
How much lumens on max mode?
BTW I recived new MT09R and replacement drivers to my MT09R from group buy.
Nice, can you post some detailed pictures of the drivers?
Picture in this treat Haiklite MT09R GB replacement drivers
Thanks! Awesome! :+1: :beer:
I think I read somewhere that HL will be using P2 bin emitters. If that’s the case, they should be getting 21k lumen sper Newlumen’s TA_tube measurements. That’s actually not far off from their 24k claim considering the majority of flashlight manufacturers way over specify their lumen ratings. It seems only Olight/Acebeam/Thrunite have been pretty spot on with their advertised lumens. I found even some premium brands like Zebralight overrate their lumens much more than that after testing it with my TA_tube.
HL had a 4000k 80CRI option for the GB. I bought both the 4000k 80CRI and 5000k 70CRI. The 5000k version was 32.3% brighter than the 4000k.
I really liked the tint on the stock 4000k 80CRI, which was almost as good as my 4000k 219b 9050. The tint was actually closer to the BBL than the one TA was using from Arrow. But the Arrow 4000k was much better than the same 4000k 80CRI from Mouser which is horrendously yellow.
My knowledge/memory on the MT09R emitters is not that great. We should ignore what I said and use your info. :+1:
I Improoved Haikelite's job.
https://imgur.com/4SQXeN5
https://imgur.com/BYIT3ty
On fresh cell Sony VTC6
lux lumen
MT09R Series from group buy 1374 13 000
MT09R mod on TA driver, all springs bypassed. 2120 20 057
MT09R NEW Series 1802 17 049
MT09R New with all springs bypassed. 1920 18165
I don't think that they are using new P2 led. All my MT09R has oryginal led so it looks like in new MT09R LED has higher VF or lower bin than thoese from group buy.
So basically, the stock light (XHP70.2) went from 13000 lumens to 17000 lumens. If this is true, then it’s a big thumbs up from me. :+1: :beer:
From smokuxx1987:
I Improoved Haikelite’s job.
        lux                          lumen
I don’t think that they are using new P2 led. All my MT09R has oryginal led so it looks like in new MT09R LED has higher VF or lower bin than thoese from group buy.
Thanks Jason. :+1: :beer:
[video:]พรีวิวไฟฉาย Haikelite MT09R 24000lumens NarsilM firmware - YouTube
It’s hard to pull any useful information from that video (that we don’t already know), but one thing I noticed was that the 4 battery springs on this 70.2 version are not bypassed at the factory. This would seem to indicate it’s definitely not going to make 24000 lumen. I wish they didn’t over rate it so much. Still, it seems way better than the original light.
Yep. Unless they changed the springs for something much more conductive, which I really doubt, it’s never going to come even close to 24k lumens.
After bypassed springs there is only 1100 lm more .
I’m not used to complaints about only 1100 lm gains. :slight_smile:
BTW, seems like Samsung 20s is a good cell for this light.
It can be had from Vapcell (Vapcell Black 2000 mAh), but it’s a bit expensive.
Is there a better source?
not sure many can see the difference between 17000lm and 18000lm, and are these the startup lumens? If yes, both should drop quite fast too.
Sure….in this light such gain ain’t large. But that actually tells a lot about how powerful MT09R is.
Did anybody try to rised the current in to the white led on charger?
The charger output is about to 50-70 lm.
I suppose that there is synse resistor.
100 = 10 ohm is before mosfet 2300
[img]https://i.imgur.com/5hRmzHD.jpg[/img]
I did ceiling bounce output sag measurement on the output for new version Haikelite MT03 that I estimated to be about 12k lumens compared to my other lights. No temperature chart here, I was lazy to use thermal meter, it is getting very very hot in one minute. With freshly charged batteries and in about one minute, its output dropped from 12k lumens to 11k lumens.
