Hmm, I have some more Senybors now and really should get round to doing some more tests but in my tests they outperformed the @&£)fire cells. I will get the internal impedance tester on them also.
If you might consider unprotected, I've been looking at these for a while, Sanyo 18650 2600mAh from Intl Outdoor, at $5.85 a piece. Free shipping if bought 3pcs above.
Its brother (2100mAh) has been tested to get 1800mAh, around 85% of claimed. Since it's Sanyo cell, I believe that result will be consistent, and for a 2600mAh cell, good chance you will get a good 2200-2300 mAh from these. Still a great value for the price.
No, they are the real deal. They have a US and China warehouse. After reading the bad reviews, I decided to risk and purchase them. So far I've had good experiences with Pandawill.
I recently had a DX Trustfire Flame go bad on me. Not in a bad way, it just wouldn't charge up anymore. I'd probably had it for a couple of years, but not real heavy use. So I bought some more XTAR 2600's from the longstanding group buy. I think those are very good batteries for a little more than Trustfires. Still a lot less than AW's and equivalents.
I think you're safest with the XTAR 2600 at $13.50/pair from Serena or I guess even that Pandawill site if you're feeling lucky. That's all I've been buying lately, for myself and for friends.
They might not be the cheapest but I just ran some testing on these in a light that draws high amps and they truly are outstanding! Definitely more capacity than the AW IMR's and as long as your application is below 10A then you should be good.
I also used them as a pair in the EYE30 runtime testing and they yielded just slightly less than the AW 2600's: https://budgetlightforum.com/t/-/6527 (look at chart under: RUNTIME (2 cells) )
no but I think callie's sells them re-wrapped w/ protection. They are safer chemistry cathode, despite saying li-ion on the side, so for my purposes, the protection isn't relevant (I don't drain my cells to where protection trips....on purpose anyway).
I'll also back the Sanyo-based Solarforce 2400mah. Indeed, the wrap is brittle, which is the only downfall. Otherwise they are quite the performer for the price. They seem to match my XTAR 2600's.
What about cycle life & shelf life? I’d guess they would be quite high due to low initial internal resistance (isn’t it’s increase the cause of cell degradation?)
