Don’t be distracted by the ‘Mom’ part. The overall question is an 18650 light that they don’t have to go out and buy a bunch of gear to keep it charged. Simple but effective.
Good suggestions, thank you.
Great looking light, although it doesn’t seem to be in stock anywhere.
Thank you for the recommendations. You are exactly correct, sometimes you need 1000 lumens to see out into the field. The Nitefox seems to be a popular option.
I actually did this last Christmas, and my technophobic mom really loves her Convoy BD01. I got a spare charging cable with it. I went with the 26650, but it would be fine with an 18650.
Personally, I like the BD0* charger better than micro-usb, but usbc might be better overall.
She can shine the light from the dining room table and see deer way up the mountain in the back yard. It completely blows away everything in her old incan collection in light output and build quality. And the switch is reminiscent of a MagLite, so familiar and easy.
I think there are some threads with similar question recently:
Basically you’re looking for an EDC-sized flashlight with a micro-USB port for charging…
There are many of them. Some that I know of would be (all have micro-USB port and use a single 18650):
Zanflare F1 ~ 1240 lumens
Wuben L50 ~ 1200 lumens
Fitorch P20R ~ 1000+ lumens
Sofirn SP30A ~ 1000+ lumens
On The Road U18 ~ 900+ lumens
Eagle Eye X2R ~ 700+ lumens
Convoy S9 ~ 500+ lumens
(I think the shortest height of the above is the OTR U18; followed closely by the Convoy S9 & Eagle Eye X2R, the others are a bit longer, with the SP30A being quite long)
Remember, the higher lumens flashlights can get much hotter (and if Mom isn’t careful, could conceivably get burned by the heat; eg. turned on flashlight in Highest/Turbo mode, puts it down on the table or somewhere to do something first [flashlight still on], later picks up the flashlight again, and it’s burning hot due to the high lumens…)
When I worked through this, the best option I found were either the Convoy C9, or the Eagle Eye X2R.
I would have preferred more output, but I preferred a tube-light for compactness, and was concerned about the thermal issues at 10W.
For a light with better thermals (convoy BDXX, maybe Eagle Eye X6R or X7R), 10W would be no problem.
I have always hated for someone to ask a question, and someone else answer that they do not want what they ask for. SO, I hate to say this, but I don’t believe people who are not into flashight should have 18650 lights. The potential problems with Li-on batteries would make them unacceptable.
I also don’t think they need 1,000 lumens.
Good quality AA lights would, I believe, do everything Mom needs or wants.
Sorry for the negative, and I’ll take the hit.
Jerry
Think you are right on that part. That Nitecore does throw pretty well.
Really? My mom has an iPhone and iPad with Liion batteries and built-in chargers. Should I take those away from her?
Good quality AA lights would, I believe, do everything Mom needs or wants.Sorry for the negative, and I’ll take the hit.
Jerry
Hi Jerry!
I will not try to make a point here, and in part I understand and agree with what you say, namely safety reasons related to the use of 18650s. :+1:
My parents never used those batteries and actually, that are not using it ! Why? Because the flashlight I gave them has a protected cell inside, because I know what they will use the light for, and because charging on that light is safe (well, we all know issues may occur, but I guess we, flashaholics, are somehow more exposed to those risks that people that may use “safer” options).
Again, about the lumens or the amount of light needed, I guess noone here is in condition to say what other people may need or not.
Specially when the amount of light can bring you some more “safety”.
To give you an example, if the “mom” in question needs a light to walk in a pitch black road or backyard or in other place where the amount of light is capable to let you see in a good distance and wide range, why not want or need to have 1000 lumens or so?
In the city we don’t need that much power if good outdoor illumination is provided, but in a small village without good street illumination, that makes the difference. And there, if we ponder the “safetyness” of using a 18650 (or other Li-Ion battery) VS the safetyness of being able to spot an assailant or animal…I’d prefer to see those coming than bothering with a battery or charging issue.
Things must be seen under different perspectives!
These are the type of roads I have around in the village and difference it makes when you have a 3500 lumens flashlight to walk around. 1000 lumens would be good, but not enough so…we all need different things And the lights being mentioned here are not “hotrods”
Could possibly look at the Olight offerings with the magnetic charger
‘Moms’ don’t generally need 1000LM li-ion lights. They just need lights that they can click to see what’s in front of them, while in the dark. AA lights are probably the easiest for ‘moms’, unless your mom is some ‘survival expert’. If she needs some 1000LM USB light, then something from Fenix, NiteCore, or others would be the suggestion, given the budget. Moms want reliability. Chris
Her most appreciated and used is a Fenix HL50, AA. Previous to that, she had an S2 and a good quality P60 type with protected Sanyos.
That was a few years ago. Today, I'd still go with a 1*AA headlamp but the high output handheld would be a Nitefox UT20.
Look at the negative reviews of both of those lights on Amazon, not the good ones.
That’s what I want my mom to have when things go dark, lol.
Unno, I got 4-5 F1s, EDCed one for quite a while, got 2 UT20s and am still EDCing one. No problems at all.
Especially since skeeter season started, I’ve been using the ’20 full-tilt quite a bit.
I don’t trust Amazon reviews much anyway. Clearly, when looking at SK98s (18650) and you see reviews describing SK68s (AA/14500), or v/v, it’s apparent they mix’n’match reviews.
Any 5×5050 194-type “bulbs”, you’ll see described white, amber, red, CW, WW, different mfrs, you name it. Like, whut’s the point?
Not too long ago, I went through all my F1 boxes (unlabeled CW vs WW except for the barcode thingy on the bottom) to make sure what was what, and physically tried all of them again. No issues.
I was gonna gift a few, ’til I heard all the oohing and aahing for Tac-Lights. :person_facepalming:
Forget it…
Coupla more suggestions, just to throw out there…
Convoy S9 is kinda throttled down, so it won’t turn into a curling-iron if left on high. I think it has a charger, not sure.
The Folomovs except for the Camp D4 (guess which one I got…) have built-in charging and ostensibly can be used as a power-bank in a pinch.
The plain white Xiauomi (oh, Hell, somebody fix the spelling…) doodad is also throttled down like the S9, but has a rotary selector-head to “switch gears”.
Hi, MascaratumB,
I appreciate the information, and I agree that unless one knows the details he cannot know the need. Having lived in small towns and dark dirt roads I can appreciate the need for 1,000 lumens.
Regards, Jerry
For close-in, a nice cheap Boruit RJ02 with swapped 60° TIR lens would be perfect.
Then just worry about a thrower…
This was my choice since we are talking about only one light and usb rechargable .
a headlamp probably makes more sense than any other single light except maybe a keychain light.
i’d forget about swapping an optic and just add a decent strength magnet and sell it as a right angle flashlight with a headband option.only other thing i’d do is make sure it had a brand new INRor LMR cell in it .
The problem with the question is …Who’s mom are we talking about . I’m old so my mom is way more un-tech savvy then your average 20 year olds mom who is 38 , wearing hot pants and a tube-top,smoking a lucky strike while taking selfies on her phone .
Is she a single mom?
Just kidding, happily married
Was also thinking, maybe something like a Utorch UT02 would be ideal for a mom. Most people are used to D cell Maglites, and may prefer that.
Really need to know what the use is. Purse use, shelf use, midnight bathroom use, scan a very large yard…
