Neither did I.
Interested depending on the price.
Is there a beam comparison somewhere between the AT40 and the TWIN?
interested!
Coupon only ready yet. Most likely you will receive from me by next week .
question-is possible to use protected?
is it not too low output for 4 nichias? 1200 lumens?looks very nice this torch…
Interested
@vresto, it is possible to use protected cells as the current draw is not very high for 4x219Cs at 1200lm.
Seems inexpensive enough. I’ll take one.
Wait, the tube is titanium and the head is aluminium right?
If so, I am interested in having the light.
Interested.
interested
Deal is alive now!
Please wait for our pm...
Interested after all!
interested
I just finished running some errands. I will send out in 2-3hrs time. Our AT40 group buy price is $27.99!!
However, there are some things that you guys need to know about AT40 before you make your purchase:
- Light consume about 3A max from tailcap reading on HIGH.
- Actual output seems to lower than 1200lm when I compare to other 1000lm lights. Need to reconfirm again.
- Temperate reaches high temperature of ( XX°/ XX F) in few minutes time.
- Limited modes - Low, Mid, High
- Amutorch is known for their B grade finishing/ quality.
- Plastic aspherical lens. You might be able to look for a replacement if lucky.
- Bezel no sealed.
- Manual in Chinese.
I’m actually looking for a 3A light and not more, for using an Optisolis quad in it, so the limited power is an advantage for me.
With the lens as a flooding optic, scratching it will not be harmfull to the beam, it may even improve it over time.
It looks like the bezel can be sealed with 1 or 2 o-rings, a bit weird that it is not designed like that.
Isnt 3A too much for the Optisolis which Clemence said should be limited to 0.5A each emitter so we should be looking at 2A. I also wonder if the screw locations will fit the 21mm optisolis board. Freeme do you know the diameter of the pcb?
750mA per led is steep but my test shows that they can handle it, at least for a short while
I’m not going to use an Optisolis board but a 20mm XM-board, like I did with my S2+ with Optisolis.
[image] [image] This an output and voltage test of the new ultra-high CRI Nichia Optisolis leds. Thanks to Clemence who was able to sell some very early samples of these leds for very little money. A discussion thread on these leds was here. This post is strange enough not about the most important aspects of the Optosolis leds: the tint, CRI and colour reproduction, simply because I do not have the equipment for measuring that. I hope that maukka at some point can do tests on tint and spectrum,…
