✜Banggood deals≫ NC TUP ⚡Rofis TC1⚡$23.06⚡S41S ★★★ $34.65 BLF GT mini ★ ⚡ Fitorch P25 QUAD LED 26350⚡X1R angle light ★BLF GT70★
Klarus K1 USB LCD Display Smart Li-Ion/Ni-Cd/Ni-MH Battery Charger For Almost all Battery Types
It’s now in flash sale for $3.39 ($5.98, –43%)
» Jump to First post quick links/deals list «
Klarus K1 has an LCD display?
Clearly it does not. Maybe he meant “LED display”.
I just copied the original title. Must be an description error. K1 only has 2 red LED and 4 blue LED indicators:
// image taken form excellent(as always) HKJ review
DQG Hobi 10180 XP-G2 R5 NW Titanium/SS/Brass LED Flashlight
Use coupon code dfe643 for 20% discount.
Limited stock.
XTAR VC4 LCD Screen USB Battery Charger For 18650 26650 14500 Battery
Use coupon code 60a441 to get 17.99 price (additional 22% OFF)
*This one definitely has an LCD display and a couple of LEDs as well :slight_smile:
» Detailed review by HKJ «
Lumintop Ant Stainless Steel/Brass XP-G2 R5 120LM EDC Mini LED Flashlight
Use coupon code ae9853 for massive 46% discount (-$16.91 for steel version). Brass one is under restocking at the time of posting and should arrive in few days.
Jetbeam DDR-30GT XHP70 3680LM Outdooors Long Range LED Flashlight 18650
Coupon code 49909b is renewed and the discount is now even bigger: -$130.00 / –50% discount and final price is $129.00
Nitecore TM06 4x XM-L2 U2 3800Lumens Tactical Long Range LED Flashlight
Use coupon code 63b0a5 to get massive $100 discount (–50%) and final price of $99.99
MF02 - $ 46 ??? You are not mistaken?
Maybe you are looking at the savings and not the actual price?
Oh, in the title? That is $46 off the retail price. So still about $80 or so.
Exactly. MF02 -$46 means minus $46.
BlitzWolf® BW-L3 28W 3.8A Sun Power Foldable Solar Charger Dual USB with Power3S for iPhone 7/ 7Plus, iPad Air/ mini Camera and More
It’s now in flash sale for only $37.29. This is the lowest price to date! (even lower than recent mid season snap-up where the price was $39.99 for only 15 or so pieces).
Deal ends in 5 days and 12.5 hours.
This is the most powerful solar charger in Blitzwolf range. It’s capable of delivering up to 3.8A of current (it full sun) which is enough to charge at full speed high power devices (high-end smartphones or tablets). Even smaller Blitzwolf panels can charge smartphones in cloudy day so this should easily power more demanding tablets. Solar cells from SunPower provide unsurpassed conversion efficiency over 23.5%
Blitzwolf chargers offer best value/cost ratio on the market and quality is very good.
At the moment the most cost effective version (in $ per Watt) is still 2A BW-L2 15W for $17.99 - see here: 15W version deal
28W version is the most recent so more reviews can be seen on BlitzWolf® 15W 2A BW-L2 and BlitzWolf® 20W 3A BW-L1 versions.
I received mine some days ago. Well made product! It was a warm and bright day, although cloudy as well, so there was no direct sunlight. I got 0.3A @ ~5.15V, so it’s a slow charge for my phone, but it was charging nevertheless. Nice to test again with direct sunlight! :smiley:
Any accessories that can plug into this Blitzwolf solar panel to charge 12v car battery that parked under sun?
Or use a cheap boost circuit will do? Will it spoil the car battery?
Thanks.
I would think you will need a specific charger for car batteries to prevent over charging.
I am thinking if I use a boost circuit that set the voltage to let’s say 13.5V, so it won’t charge the car battery to 14+V, will it still over charge the car battery?
According to article below, it is the maintenance phase, looks like it is not charging the battery anymore.
I really don’t know. I’ve got two new charger/maintainers on motorcycles and they tend to maintain at about 12.6v to 12.8v. They have advanced circuitry like in the link you posted where it goes through multiple phases to charge, monitor and maintain the batteries.
I know there are solar chargers for 12v RV’s and boats, etc… You don’t want to get one of them? If not, I would do some online research to see if these 5v units can be rigged and not ruin your battery.
Ya, I have two car battery chargers those do multi phase charging. I think this Blitzwolf is good product and if it can be used for multi purpose besides charging mobile phones, it will be even better. That is why I am not keen on getting those 12v solar for car, and not sure how is the quality/price compared to Blitzwolf.
I’m no expert either but from what I understand I’d say this should work and will not overcharge the battery. But this will reduce charging efficiency as you would have two converters in series (Blitzwolf already has some kind of converter for 5V), charge rate would also be reduced by placing the panels behind glass window.
