Im still curious what runtimes they will manage to pull off on the x70, i have the X9R which is a fantastic light but once it drops to like 50% battery or lower the max output is only at the third highest lumens, (6400), i guess its a limit of the low volt on the batteries so i asume similar will be on the x70 ? there is a reason they havent posted the spec sheet for all the runtimes etc….
I disagree with this. They used a badly designed driver in the EC50 II. The diode gets more current than it’s specified for which can lead to premature failure. There are also Bugs in the U.I. Their lights don’t have real PID thermal regulation even though some of them are redicouisly powerful for their size and get too hot to hold very quickly (again the EC50 II).
The build quality is standard fare, nothing special. There are many manufacturets offering this kind of quality. Of course there are always ones with worse quality…
I just recieved information that the light may be released in the next 2 months. This is my response to a question about preorder.
“Hi, Mr Patrick, X70 is currently in the process of being improved and could go on sale after at least two months. I suggest you try our new X80 series like X80-GT”
wow still, i think they try to improve the battery or performance of the light then now that the x9r is out then relate to the runtimes on that and that their light will do almost 15000 more lumens so they better do a good runtime because who wants a light for that price if its not even 1 hourmax?
My EC50 Gen II is one of my favorite lights. Been using it often over the last year. UI is great, build quality very good. Considerably better than the average chinese flashlight. Also have the EC35 which is very good too.
While comparing a friends older X65 to ours (from the latest run), we noticed some differences. This sparked an interest to see what other changes
were made that weren’t easily visible. This list was complied from a series of emails over a period of 2-3 weeks with both Acebeam and my dealer.
- Battery indicator light was moved from the switch to a stand alone indicator light forward of the switch.
- Improved switch. Earlier switches were soft with little feedback. The latest switches are firm and positive.
- Updated reflector design for improved beam quality and less artifacts.
- Updated battery pack. The newest battery packs have been improved for better performance.
- The screws inside the head used to be Phillips. They are now Tamper-pruf screws.
- Improved UI. The double click timing to access Turbo and Turbo Max has been updated.
- Improved tailcap to ensure the lanyard ring rotates freely after a drop or impact.
- Improved centering ring to ensure the LED’s are perfectly centered at the factory.
And how can we know if a X65 is one of the new or from older deliveries? Can we ask for the Serial number?But which is the first S/N of the new deliveries?
I think its more struggling how get decent battery life from 8 x 18650 batteries thats gonna power 40k lumens and 3 fans also… thats the problem i think. Not the fans alone why would those be a problem ?
The fans need to be water proof, rust proof, dust proof, etc… for 5 years (that’s Acebeam’s usual warranty period). Maybe in their testing the fans can’t last more than a couple years.
We saw where Olight designed the X9 fan to be in a removable cartridge for easy cleaning and replacement.
Maybe Acebeam is having issues with that? Who knows.
