The UM34C was sent to me by RD Official Store in AliExpress for review.
Here's the product's page: RD UM34C
The USB meter comes in a simple tin box with a plastic display window.
The meter is seated inside a laset cut foam mold to protect it during shipping.
The device itself is using a quite big 1.44 inch color display with quite a sharp, for the application, resolution.
I found the viewing angle to be surprissingly good.
The back side of the meter has just a plastic piece to protect the pcb's components from an accidental short.
The upper side of the device utilizes a regular microUSB port along with two buttons used for controling the displayed information and a Bluetooth switch.
The manufacturer recommends that the maximum current through the port shouldn't exceed 2A, but my tests showed that the port can withstand higher currents than the ones stated.
Following the previous pattern, the lower side of the device implements a type-c port alongside with two more buttons.
The max recommended current through the port is 4A.
Powering on the device, introduces the user to the basic info screen.
(The 5 available info screens can be scrolled through using the lower two buttons)
The basic info panel displays the following info:
Voltage (V)
Current (A)
Power (W)
Capacity(mAh)
Energy (mWh)
Resistance (Ί)
Internal temperature of the meter (C)
The second screen except from the basic readings, introduces the voltage measurements of the data lines along with the current charging mode.
The third panel is used for displaying the basic stats of a charge cycle along with with a recording indicator and the nominal amperage after which the data recording starts (0.10A in our case).
The recorded data can then be extracted in Excel format through the dedicated Android application.
The fourth screen is a quite interesting one as it's used for measuring the resistance of a cable.
In order to get a measurment, an adjustable electronic load is needed in order for the meter to record the voltage drop across the cable and thus its resistance.
The follow up panel shows a graph of Voltage against Current over time.
It allows for a graphical representation of a power supply's performance under different loads.
The final screen allows the user to adjust some parameters in the way that the data is represented as well as set the screen's timeout.
Using the provided Android application, the user can have live access to the live data as well as control the device.
As seen, the applications gains access to every piece of information that the meter can display and also allows the user to tweak some of the available parameters.
Also, all of the saved data can be easily pulled into an .xls document.
To sum everything up, I was pleasantly surprissed to finally see a budget USB meter that can provide such a wide range of information.
I double verified the all the recorded data with two other of my usb meters and every reading seemed to be on point.
Update
Here's a few Voltage / Current graphs I created using the UM34C combined with the LD25 electronic load.
Here's a quick clip to show you how to use the cable's resistance measurement mode of the meter.
www.youtube.com/embed/mY5AZ2KPL40
Thanks for taking the time to post your review. For my purposes, I just couldnât justify the offerings from YZXStudio (although Ive almost pulled the trigger more than once). RDâs offerings make far more sense at their price point.
Yeap, still absolutely pleased with it.
Recently I also used it combined with the companyâs electronic load to benchmark some of my chargers and powerbanks.
Tomorrow I hope to get some free time to post my findings
but YZX meter did not have ,
For UM34C, it support USB 3.0 and Quick charge recognition mode:QC2.0ăQC3.0ăAPPLE 2.4A/2.1A/ 1A/0.5AăAndroid DCPăSAMSUNG, support support OPPO phone VOOC, OnePlus DASH
Though UM34C and UM25C have Type-c port , but there is not trigger, only support type-c charge, not recognition
although for data or some function, it is not better than YZX meter, but for the price , it is already best âŚ
for USB load, there are many choice , LD25/LD35
If someone need more cheaper meter, but colorful display, there is also choice AT34
Since quite a few guys are interested in the meter, here's a quick video of the process you have to go through to measure a USB cable's resistance.
Not a representative of RDTech, but judging by the fact that the Type C port is rated up to 4A, itâs safe to assume that it will support VOOC just fine
I stand corrected! The device indeed passes through the fast charge signal (shown by the blue instead of ânormal chargeâ orange LED on the phone) at >15W.
It does display QC2.0 though instead of Dash/VOOC but thatâs no biggie.
Hi friend
I guess you misunderstand something , our meter show QC2.0 and QC3.O, for other mode , it only show unknow , but it indeed support , our device is a meter, not decide the mode, ok ? in fact , for any quick charge, you should check the voltage and current fit dash fast charger or not , ok ?
I donât agree with you , our meter can support , there is not any problem, but our meter donât show dash fast , because our meter only detect charge signal , ok ?
you can check the current and voltage fit that standard or not, ok ?
our meter is only a meter, not charger, donât put all charger problem on our meter, ok ?
for example ruler, it is just tool, not decide your length, you have different hair style , different shoes, stand straight or not . those can decide your length, not the ruler, only the ruler range can decide it support 2M, 3m, or 4M, understand ?
