And itās gone
5050 LED Gaskets for 9mm Reflector Hole
5050 LED Gaskets for 9mm Reflector Hole 9_6mm x 0.8mm
And itās gone
x95, please keep this forum about flashlights and related hobbies.
(edit: x95 deleted some more posts)
These might work for you
https://m.banggood.com/5PCS-Convoy-XPL-Insulation-Sheet-For-9mm-Reflector-Hole-p-1033479.html
I had some troubles with the gaskets as well since my original op reflector was 7mm, and the smo is around 9mm. these worked for me.
I have sanded it down, since its quite thick though.
Thanks, but I needed XM sized ones. I have some of those XP sized ones and ended up just modifying them by increasing the emitter hole size with a small square file.
Maybe these?
Nice mod F.i.l.a.s., welcome to the insanity.
Today I am trying to fix a long standing problem once and for all. A member here uses a light for work at night and I fixed up a Shooter 2X for him a while back. Problem is, the guy has a rough job and heās broken the Shooter multiple times. So this time, a new approach. MagLiteās are known to be tough and durable through all sorts of abuse, so today I modified a 4C MagLite for him using the XHP-35 and driver from his Shooter. Made a heat sink, carved down a 16mm BLF copper DTP MCPCB to fit through the reflector hole of an Mag D LED reflector (much deeper and parabolic, compared to the bowl shape of the shallow Xenon reflector)
The heat sink has a pillar with the MCPCB mounted on top so the light is still focusable if flood is needed. I tested it with my power supply and know that it works, but I need 4 26500 cells to be sure the tail spring is at the correct height and then get output numbers and lux.
He should be able to use this one as a club with little or no affect on the light.
Oh, it was 104Āŗ on the mercury style thermometer a couple of feet behind my lathe. In the shade.
Maybe these?
Thanks, those should work according to the specs. I appreciate you looking.
But I did end up modifying the XP centering rings successfully. I got around to switching in XHP50.2 emitters in my 7xC8 light . After a few short bursts with some old liitokala 26650s 4 of the 7 XHP50.2s have 2 dies dark. All the emitters came on MCPCBs from mtnelectronics and are well sinked to the aluminum plate with thermal compound. It should be less than 5A per XHP50.2. I was aware of this issue with the XHP50.2 (half the dies going dark) but I guess I thought I would get lucky. Bummerā¦ :weary:
Not really a hard mod to say, but right before I was going to reflow my Samsung LH351Ds in my BLF Q8, I had an idea to use with a tofu cylinder container as a big diffuser.
And it fits the Q8 perfectly, and has a much more diffused beam than all of my diffusers. Probably has the best beam of all diffuser I have:
And it snaps over the fins perfectly
Now, if it was flashed with Anduril, you could just hit candlelight mode and pop a cork, have a nice romantic evening by Q8light.
Yeah. It would be so awesome with LH351D 4000k 90CRI and Anduril.
Iām going to reflow them tomorrow when itās morning, and Iām going to flash Anduril when I get the necessary hardware from China.
Good night.
Built a 532nm stainless steel laser, forward clicky tail switch, 10180 cell.
Made a rechargeable 10180 cell for my DQG titanium green laser.
Hmm, thatās not exactly safe is it?
What is its power level?
Nonetheless, great stuff.
I live dangerously :laughing:
Do you mean with the switches? Or the battery? The charger is actually soldered to the cell.
These are only around 1.5mw, fully potted, they do get warm.
For my personal use only.
Oof I was scared. 1.5mW is perfectly fine and legal to use.
In Quebec, that was the case until a few weeks ago when any kind of laser were banned if you are close to an airport.
Yeah Iām scared of the powerful lasers, thought about getting one many times but no.
These wee green fellas are plenty bright and pocketable, can actually see the dot outside during daylight 100m or so and the beam at night is great.
Sometimes when a project fails it opens a door to something that works pretty nicely. Thatās what happened hereā¦ I was going to build up a 4C Maglite with an XHP-35 but it just really didnāt want to handle the power. I even stepped up to a thicker heavier copper heat sink, in testing that one I burned a black pit in a 35. Ok, so, moving right alongā¦ Decided to do something else with the 4C Magā¦ chopped it this morning.
Here is the Black 1C (26500) Maglite next to a 2D for size referenceā¦
Here is the 1C Mag next to my early purchased light, got this way back when I was first getting into lightsā¦ JayRob from CPF chopped the Red Maglite, ChicagoX from here finned a head, Elektrolumens made the triple insert, and of course, I tweaked it all somewhat.
The new threads and o-ring landing cut into the chopped off 4C tubeā¦
Ah, Maglite! Robust construction throughout, look how thick the tubes are!
Made the copper (Te/Cu Alloy) sink on the lathe with a bit of a column to allow for focus like Magās are known for, hand cut the opening of the tube to allow an LED style Mag reflector to fit into the mouthā¦ I like the head to be screwed almost all the way down
I inset the tail spring and bypassed it, while a full sized 26650 cell is fatter than a C and wonāt fit I may bore it some day for the higher capacity full sized cell, so itās already set up to accept it if/when I do thatā¦
A wall shot on low in my Limo Room, we have 5% tint on the windows as my wife used to have bad migraines. I used a Samsung LH351D 5000K 80 CRI on a hand carved 13mm BLF/ Alex Wells DTP copper MCPCB, reflow soldered together. Built a PZL driver with 12 of the 350mA 7135 chips, tail amperage shows 3.35A on a Red Efest 26500 at about 97% charged. (This is a 4 year old cell)
This light really fits my hand nicely, with Bistro as the UI itās pretty versatile and an automatic win for me, also have an AR coated lens in place. This is just one of those satisfying builds that gives one the feeling if a guy could only have one light, this one would definitely be a contenderā¦.
WICKED hot today, my thermometer was showing 100Āŗ by 9:11AM. Same thermometer shows 116.8Āŗ on the porch, a different thermometer with a probe right outside my window shows 108Āŗ. We tied a record yesterday with an official 106. Blistering out there, and sultry boiling hot at the lathe. But I love it that way, lol.
How remiss of me! It pulls 3.35A at the tail with the old 26500 not quite holding a full charge. (shouldnāt matter with the regulation chips)
1. 0.6355 lumens
2. 9.35
3. 54.855
4. 170.43
5. 250.47
6. 472.305
7. 986.7
With an 18ga spring bypass in the heavy steel tail spring it makes 1045.35 lumens
For the noobs out thereā¦ Iāve built hundreds of lights, and yet when I built the PZL driver last night it was direct shorted. I gradually removed components until the board was bare and still, it was a direct short! So I started over and built a new one with the same components, this time fully successful. Sometimes things just go wrong, it is what it is. Donāt be discouraged, take the time and check it out, start over if/when you have to. All part of the game.
PZL is a puzzle of a driver, the componentās placement are listed on the mask under the MCU, you have to leave the MCU til last to see where everything goes! lol It has dual channel capability like our FET+1 drivers, but instead of using an FET itās got multiple 7135 chips. I stacked 4 extra for the little more power. This driver was done by Alex (Wight here ) in a jovial moment.
The other side is 6 of the 7135 regulation chips, the one to the right of āBLFā is the moon channel. (With BLF TDC)
Love the light Dale. Theres a few great names from the past in your build. :+1:
Old Lumens showed me how to stack chips.
And I have all his kit, so a lot of my Maglight mods are based on stuff from Justin.
Thereās been a LOT of people help me out along the way here, donāt ya know?! I think I about drove Comfychair crazy back when we were starting the FET craze. lol
Very nice.
Itās been 29Ā°C here sometimes lately and I can hardly move.
