✜Banggood deals≫ NC TUP ⚡Rofis TC1⚡$23.06⚡S41S ★★★ $34.65 BLF GT mini ★ ⚡ Fitorch P25 QUAD LED 26350⚡X1R angle light ★BLF GT70★
I would think you will need a specific charger for car batteries to prevent over charging.
I am thinking if I use a boost circuit that set the voltage to let’s say 13.5V, so it won’t charge the car battery to 14+V, will it still over charge the car battery?
According to article below, it is the maintenance phase, looks like it is not charging the battery anymore.
I really don’t know. I’ve got two new charger/maintainers on motorcycles and they tend to maintain at about 12.6v to 12.8v. They have advanced circuitry like in the link you posted where it goes through multiple phases to charge, monitor and maintain the batteries.
I know there are solar chargers for 12v RV’s and boats, etc… You don’t want to get one of them? If not, I would do some online research to see if these 5v units can be rigged and not ruin your battery.
Ya, I have two car battery chargers those do multi phase charging. I think this Blitzwolf is good product and if it can be used for multi purpose besides charging mobile phones, it will be even better. That is why I am not keen on getting those 12v solar for car, and not sure how is the quality/price compared to Blitzwolf.
I’m no expert either but from what I understand I’d say this should work and will not overcharge the battery. But this will reduce charging efficiency as you would have two converters in series (Blitzwolf already has some kind of converter for 5V), charge rate would also be reduced by placing the panels behind glass window.
Xiaomi Mi A1 MiA1 Global Version 5.5 inch 4GB RAM 64GB Snapdragon 625 Octa core 4G Smartphone
Use coupon code 7BGA164GCL to save $26 - price drops to $159.99
» Jump to First post quick links/deals list «
Xiaomi Mi A1 MiA1 Global Version 5.5 inch 4GB RAM 32GB Snapdragon 625 Octa core 4G Smartphone
Use coupon code 7BGA1432CL to save $26 - price drops to $149.99
LED Flashlights Clearance Up To 47% OFF
collection.
Coupon code 2017FNL has been renewed.
Check out all deals: Nitecore, Klarus, Jetbeam, Lumintop and others.
Convoy DIY 1288 Switch with LED Blue Light For Convoy C8 M1 M2 S2 S2+ Flashlight
It’s now in flash for $1.50 (25% OFF)
Offer ends in 15 hours.
Great Promotion for Outdoor Sports | Cycling Lightning
collection.
Includes front and tail lights, action cameras, bike battery packs and other outdoor accessories and lights.
Use coupon code ODLIGHT to get extra 20% OFF, other deals and preorders up to 50% OFF
Tour of France 2018 Fight for Honor
collection.
Another collection of bike related and other outdoor accessories.
Use coupon code 18TDF to get extra 20% OFF, other deals and preorders up to 50% OFF
BlitzWolf® BW-WP1 10000mAh Dual USB Lithium Polymer Battery Power Bank With Wireless Charger
Use coupon code 19WP1 to get $19.99 price (17% OFF)
This is a very advanced power bank with wireless charging:
  • 10000mAh capacity
  • Wireless QI charger (5V/1A)
  • USB Type-C input/output (5V/2.6A and 5V/2.7A)
  • USB Type-A output (5V/2.7A)
  • micro USB input (5V/2A)
  • LED power indicator
  • simultaneous 3 devices charging (2 wired + 1 wireless)
  • 6 types of safety protections (short circuit protection, output load test, over charge protection, over discharge protection, over current protection, no-load protection)
AMUTORCH TC500 XHP50/XHP70 3800Lumens 30W Dual Switch Brightness Powerful LED Flashlight 18650
Use coupon code 3403c9 to get $39 price ($19.69 for XHP70 / $28.69 for XHP50)
Haikelite SC26 XHP35 HD/HI 2050Lumens Modes Set Brightness Portable EDC 26650 LED Flashlight + 26350 Tube
Use coupon code ef3048 to get $42 price (-$13 / 24% OFF)
  • 20 color/LED combinations to choose from
  • XHP35 HD/HI CW/NW
  • included short 23350 tube
Ya, efficiency will be low unless tapping on the voltage before the 5V regulator. I wonder anyone measure the voltage before the 5V regulator.
I haven’t seen such data. Still it’s pretty save to assume there must be some step up converter because nominal voltage for single cell is around 0.5V and there are 8 cells in BW-L3 so at most ~4V if connected in series. Cells do not seem to be broken into smaller separate parts so higher voltage is rather not likely.
Convoy S2+ 7135*8 Driver XM-L2 U2 T6 1100LM 3/5Modes Super Bright EDC Floodlight Flashlight
Coupon code with nice discount is available.
» :email:Request via PM here«
3 NEW COLORS and 4 LED options = 12 new combinations :slight_smile:
The purple one looks especially suited to host UV pill - direct swap from Convoy S2+ Nichia 365nm UV LED
Code please Convoy S2+ purple w/ biscotti. Thanks Pete :slight_smile:
I don’t think BangGood has the S2+ w/ Biscotti. They only offer the old, and annoying, 3/5 mode group for the S2+ for some reason, even on the newer Desert Tan, Cyan, Purple, and Orange models. But the C8+ listed on BangGood does come with Biscotti (you can see it says “12 mode”).
One reason I can think of is that lighted switches only work with old firmware.
