This is definitely an issue that I experience with mine too. During a minor emergency I literally spend 10 seconds turning the thing around and around and poking at all the different ridges and fins trying to find the totally flat button.
imalent dn70 - same issue - sold it
and that had TWO buttons i couldnt find
i prefer the imalent ‘UI’ to acebeams press and hold but not finding the buttons in the dark = useless product
Come on, guys, why pick on DX80 switch, I am sure it is really inconvenient since so many of you complained on this. But DX80 is mainly for lumens fun, not really reliable for emergency. I almost pulled trigger on it last week, but still many user complain about its hardware reliability or safety.
Anyway, this X80 GT is getting more attractive with 32500 lumens. Surprisingly Acebeam gives 5 years warranty for it.
I agree that the X80 GT was just created to beat the DX80. I wont buy it because of the upcoming x70. I definitely will purchase that light though. Even if it is $700 USD
i think so too but since since the dx80 isnt really a soda can light the purpose on gt i still wonder whats the point when they should focus on the x70, that beast atleat will be able to run more then a minute atleast on highest with 3 fans… even the imalent can run highest more then a minute, the x80 gt cant…
even the damn names are so similar, dx80, x80gt blabla…. way too confuse beginners…
At least Illumn is carrying both of these lights now, so short term concerns over the quality of these lights is mitigated by having a domestic vendor carrying these.
That’s like 80% of front switch lights for me. I never recommend them to people who may need them in a stressed situation (with a few exceptions like maglite etc).
I am thrilled to see the X80 bumped up though even if it’s only a few seconds sustainable. Acebeam is going to have to do more than jump the output to capsize Imalent though. The marketing on that DX80, slipping it into the hands of multi million subscriber Youtubers has really positioned it well in the market.
Ive seen dx80 used in some science demonstrations and non flashlight channels where there are millions of subscribers. Cant remember which ones though
Just found this one and it has some impressive numbers.
1.25M subscribers and 8M views.
That same channel has done like 4 videos with it. Crazy Russian hacker has also made one.
It would be capable of it with 4000K XHP50.2 emitters. If pushed to the max, this light could produce 60k lumens, but I’m not even going to dream of that at this point. No doubt it’ll get hot quickly, but that’s reasonable for a soda can light.
Keep in mind the current requirements for 60k lumen. 4 x 18650 will not do it. That is the limitation. I’m skeptical the X80 GT can do 32k lumen. Especially if it uses 4 of Acebeams 15A protected 18650.
a guy one CPF wrote,
I’ve just managed 29,000 lumens @ turn on against my X80 that measured 23,000 lumens.
so yeah not really 32k lumens even if its close its not…. U were right JasonWW lol…
That post was by KG_Tuning. If you read this thread, his recent posts about lumen measurements caused a bit of commotion. I wouldn’t fully rely on his measurements until he gets a Maukka calibration light.
Thread closed until tempers cool.
I measured 22,300 lumens using the Texas_Ace calibrating tube for the X80-GT.
For reference my X45 managed 10,100 and DX80 20,000 (I binned the garbage)
I suspect Maukka will get closer to my turn on reading of 29,000. Maybe a tad more in fact as he usually hits a little higher than me.
LMFAO @ you people that can’t find the hole. Seriously.
I would hate to see any of you try to clear a weapon malfunction if you can’t even find a button.
IT LITERALLY TAKES LESS THAN A SECOND
Eyes closed. Grab it. Finger opposite thumb. Rotate the light. Wow what’s that?
Oh.
The button.
Wow.
I don’t know about the DX80, but if you keep the handle on the X80-GT it’s comically easy. The button is opposite the handle.
I grab it like this: Holding X80-GT - Album on Imgur and then once I get it to the setting I want, I hold it by the handle.
If your hands are too small to hold it that way, keep the handle on it and scoop it up with your thumb like this: Holding the X80-GT part 2 - Album on Imgur and your finger naturally rests on the button.
I’ve made a new integrating sphere and turn on wise I get this:
MF01 9500
DX80 13200
X45 15800
X80 24000
X80-GT 36000
EDIT: I now have it down to 33,000 @ turn on after blocking a little spill from hitting directly over the sensor, the other lights remain the same as their flood wasn’t so wide.
Do you think it would perform any better if it had unprotected cells?
Another Imalent hater, I never mentioned my Acebeam X80 was faulty on my DX80 review.
Glad you matched my ceiling bounce figure dead on.
I’m not sure if its a direct drive or not. I measured about 18.6 amps at the tail with those (forgot to add that clip to the vid). I suppose I should probly own a set of 4 matching unprotecteds. What’s the best thing going in low resistance high discharge these days?
