Lexels driver compilation
And the carrier contact springs too :wink:
The battery springs are from Copper alloy
but idnk why the carrier button spring is not, definately likes a magnet and has pretty high voltage drop
lexel, I finally got around to installing your GT driver in the XHP35 MT09R and WOW! It was only “decent” before but now serious. Stock led, smooth ramp 80% NarsilM v1.2. Got a little chirp on contact charge but good now. I took your suggestion and did not bypass the springs. Great driver! Keep up the super work!!
New generation of drivers releases now
replacing the at 2S unreliable AMC7135s
DD + small FET and resistors instead
MT03/09R XHP70.2
support of permanent switch LED plus MCU indicator with resistors
30mm for Convoy L6/ Thorfire S70S
20-22mm with 2 FETs and also 6+1 AMC
here with 1S configuration with 6+1 AMC
I had to drill out one via on the spring side partially that secures the switch pad from lifting if soldered too hot
17mm 2S with 2 FETs
17mm LX v1.0 FET+5+1
more filtering caps for very high drain builds
Lexel, what should I choose to drive an MT-G2 with 2*26650, e-switch only ?
(Maglite 2D host, big aluminum pill for high current)
30mm LX v1.0 with no AMCs
No AMC ? DO you use PWM on the FET to get lower modes ?
Not sure where the best place to ask this is, so I’ll give it a try here. I had some boards made using: your ‘new’ 17mm TA layout. I built one in a 1s configuration with an ATTiny25v with no LDO, Zener or bleed resistor using recommended components and resistor values.
I flashed it with the bistro-TAv1-OTSM-HD-attiny25.hex file provided in the Bistro-HD v1.7.1 distribution.
It works great, except for one thing. The voltage readout is wrong. It usually reads out 4.2. I may have seen it go as low as 4.1.
My understanding is that the firmware I am using reads the voltage from Vcc. So I am really at a loss as to what could be wrong. My understanding is that 1.7.1 is pretty well tested for OSTM configs, but should I be using v1.4.1instead?
Thx.
It depends on the voltage drop on the diode, there is also some variation from MCU to another
voltage readout can be off 0.1V this is normal
Hi.
How can I buy those drivers?
I am interested in 17 and 20mm boost drivers. Is it works with low current buttons?
I don’t think he is selling the boost drivers yet.
Here is the thread that you can order from.
Thanks. I should have been more clear though.
The problem is that it doesn’t just reads out 4.2v with a charged cell. It reads out 4.2v even when the cell’s resting voltage is closer to 3.7v.
I also realize I have no idea what value caps to use for C4 & C5 on the larger boards.
I got no idea what could cause this, I had never voltage readout making problems, sometimes the diode bridge was closed by solder paste and I got 4.4V readout
C3 10uF and C4 0.1uF on 2S boards
MF01 v2 3S 14A dual Buck driver with new MOSFET and now single sided
Thanks. I’ll have to refer to the schematics to better understand the extra caps.
I wonder if I bypassed the diode by mistake somehow. I cant remember how low I took the actual cell voltage. I know I haven’t tested it with low SoC cell, but I thought I’d check with a cell @ ~3.7.
Got my 30mm 2S driver today, I can’t wait to try it in my 2D Maglite !
Any chance you might come out with a driver for the HaikeLite SC26?
That uses a boost driver, yes? I think he should be selling them soon, but not at the moment.
Yes I believe it’s a boost driver. 28mm if I recall correctly.
Lexel, any hint as to what you may come up with for a SC26 replacement?
I got atm not enough time to get ahead with the Boost, I made some progress just to run into a problem again
I ordered version 3 of prototyp boards 10 days ago, with enhanced thermal path to cool the MPS chip as I ran likely on 50W output into thermal problems I hope the new board will fix it
