That should not be effected by glue around the driver.
I think we need clarification on the driver design. I canât tell if they mean the driver retaining ring will be glued or it doesnât use a retaining ring and the battery tube is what presses it into place.
It looks like the switch might be attached to the driver and that is why the driver has ears on it to keep it orientated in the right direction.
Then it looks like the battery tube is what pushes against the driver. If that is the case, they might be gluing the battery tube into place. It would also mean you canât swap drivers.
