6. Batch "TA" 1S or 2S Bistro HD OTSM/NarsilM drivers 15-47.5mm size fit, S2+, C8, H03, MF01, MT03, Q8 Clicky or E-switch
307 posts / 0 new
beam0
beam0's picture
Last seen: 1 year 6 months ago
contactcr wrote:
beam0 wrote:
Thanks Jason and Lexel for the info and explanations, I think I’m really going to enjoy the GT NarsilM v1.2.
I’ll get a driver for my Q8 too if I keep it. I despise getting strobes by accident, it’s great you’ve got that issue resolved with this.
You can keep your Q8 stock and reflash it too. The bare minimum parts to do it are like $3-4
Swapping out to Lexels driver would be worth it to get the better regulated middle modes, but I’ll have to see how hard it is to change these battery contact rings, seems it’s a bit tricky, I’m glad he epoxied the components on the driver he customized for my BST, I’ve read already where someone who tried doing it with hot air had the topside components fall off.
But re flashing does sound interesting anyway, can you point me to those $3-4 parts and instructions?
Lexel wrote:
Strobes can be always disabled in NarsilM from the user
I have no expirience with Anduril, but as the GT version has far more useless features than the straight and easy Emisar Anduril I would not do it
“useless” features? Do you mean useful?
Can the strobes be disabled by user in stock Q8 Narsil?
"Over 2000000 hours (about 200 years) standby time"  (DQG Tiny 4th)
"27,157 results for zoomable flashlight" (ebay)
Lexel
Lexel's picture
Last seen: 5 hours 6 min ago
Lexel wrote:
Strobes can be always disabled in NarsilM from the user I have no expirience with Anduril, but as the GT version has far more useless features than the straight and easy Emisar Anduril I would not do it
"useless" features? Do you mean useful? Can the strobes be disabled by user in stock Q8 Narsil?[/quote]
original Emisar Anduril
Toykeepers enhanced GT Anduril
JasonWW
JasonWW's picture
Last seen: 2 hours 13 min ago
https://youtu.be/blNW_3VAcTE
Click this to go to signature links.
beam0
beam0's picture
Thanks, nice video. I also found the programming guide in the box that I didn’t notice at first…
Had to use one of these to read it!
ma tumba
Last seen: 1 week 5 days ago
lexel, is it possible to kill turbo mode so it can never be accessed? I happen to go to turbo all the time back from the lowest level and probably through some other sequence, and my LED would not survive that anymore.
Lexel
Lexel's picture
It is possible to flash the turbo to be like amy % FET PWM you want to reduce average current, even if you go backwards or enter thermal calibration
Removing from reverse modes should be possible but that needs more investigation how the code has to be changed
BlueSwordM
BlueSwordM's picture
Last seen: 18 hours 29 min ago
Well, I never thought I would find spam in this kind of thread.
JasonWW
JasonWW's picture
Spammers can target any thread. It’s usually the bigger ones, but small ones can also be hit.
JasonWW
JasonWW's picture
Hey Lexel, how are the boost drivers coming along?
Has anyone helped you to modify NarsilM to run on them yet?
wildstar87
Last seen: 9 months 1 day ago
Interested in the boost driver as well.
Mr.Poppy
Last seen: 10 hours 36 min ago
Looking for Q8 type driver (with 2Series) to replace burned Convoy L6 driver (30mm) .
Help me to choose right options.
Light Own: Convoy S2+ 4C FET, BLF X6v2, BLF Q8, BLF LT1, WildTrail D80v2, Convoy L6 TA Narsil, BLF GT, BLF-348, Convoy S2+ 18350 Nichia 219BT, Astrolux A01, Olight I3E tan
Gifted Away: Convoy C8+ Sand 4C FET, Pelican 2350, BLF D80 (due to flicker), BLF A6 (due to green tint), BLF X5
Built/Modded: EE X6 FET SST-40 N4 6500K dedomed, Two EE X6 FET XP-L HI V2 3A, Two Convoy C8+ Sand 4C + FET
JasonWW
JasonWW's picture
The main option is what you want it to do when power is first applied. Meaning what the tail switch does.
You can choose nothing, 2 short blinks, full turbo and I think moon.
Mr.Poppy
JasonWW wrote:
Mr.Poppy wrote:
Looking for Q8 type driver (with 2Series) to replace burned Convoy L6 driver (30mm) . Help me to choose right options.
The main option is what you want it to do when power is first applied. Meaning what the tail switch does. You can choose nothing, 2 short blinks, full turbo and I think moon.
I prefer that tail switch to be simply lock out ( do nothing ), it’s inconvenient to use anyways
JasonWW
JasonWW's picture
Lexel should be PM you.
You want something like:
30mm, 2S, L6, NarsilM, PO=(NO)
I think you can choose 2 channel or 3 channel. 2 channel is something new so I’m not familiar with it other than its supposed to improve reliability.
Since he uses NarsilM v1.2. he might be able to set the ramp to 80% with dbl clk for turbo. That’s a good option to have.
You can use the spring from your old driver or order a new one. Shipping is cheaper if you solder the spring. It ships flatter. Anyway, I’m sure Lexel will get you sorted.
-X3-
-X3-'s picture
Last seen: 3 days 14 hours ago
Hi Lexel, I’d like to but a 22mm 2S TA driver with NarsilM please
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
Lexel
Lexel's picture
I have ordered today new board including 20-22mm as those are out of stock right now
so it will take about 2 weeks till I get new boards
-X3-
-X3-'s picture
Lexel, what size do you have ready to ship ?
I need a TA driver, 2S, NarsilM for a Mag 2D with MT-G2.
AEDe
AEDe's picture
Last seen: 3 days 1 hour ago
Hi, Lexel
How can I buy those drivers?
I am interested in 17 (for ZL h600) and 21mm (for H03) boost drivers. Where can I find options for those drivers?
JasonWW
JasonWW's picture
AEDe wrote:
Hi, Lexel
Like I was saying in that other thread, his boost drivers are not for sale yet. I did hear that ToyKeeper has helped him to get NarsilM running on the Boost drivers, so hopefully they will be out pretty soon.
So for right now, everyone who wants a boost driver will just have to wait.
AEDe
AEDe's picture
Not quite understand you previous message, now it is clear, thanks!
Lexel
Lexel's picture
new boards are marked as my sideswitches
S-Switch
G-Ground
L-Lights MCU controlles
some drivers got LS for permanent LED light
*also most high current new drivers got filtering for better LVP, but this makes reflashing impossible
there is a solder bridge you can open next to small C3*
New generation of drivers releases now
replacing the at 2S unreliable AMC7135s
DD + small FET and resistors instead
MT03/09R XHP70.2
support of permanent switch LED plus MCU indicator with resistors
30mm for Convoy L6/ Thorfire S70S
20-22mm with 2 FETs and also 6+1 AMC
here with 1S configuration with 6+1 AMC
I had to drill out one via on the spring side partially that secures the switch pad from lifting if soldered too hot
17mm 2S with 2 FETs
17mm LX v1.0 FET+5+1
more filtering caps for very high drain builds
JasonWW
JasonWW's picture
Very neat. So you’ve added a second smaller FET. How does that work with bigger FET?
contactcr
Last seen: 22 hours 57 min ago
have no idea what any of this means. 2 fets, filtering?
JasonWW
JasonWW's picture
Yeah, it’s confusing. The MOSFET is like a remote controlled gate that can open and close many thousands of times per second to allow electricity to flow.
Filtering is what the capacitors do. They can take small ripples in current or voltage and basically smooth it or average it out. Or they can build up an electrical charge and release it very quickly.
Most of the components on these drivers are pretty simple. You’ve got a MOSFET (metal-oxide-semiconductor field-effect transistor), resistors, capacitors, an MCU (microprocessor control unit) which is like the brains of the circuit and then maybe some amc7135 current regulators. You flash your computer code (firmware) into the MCU to make it work.
I know a little bit about these driver designs, but when Lexel starts talking about them, I only understand about half of what he’s saying. LOL
Lexel
Lexel's picture
2. FET in addition with 1-8 13 Ohm 0.5W resistors replaces linear regulators like the AMC7135 on higher voltage than 1S
the driver produces switch on and switch off spikes of the input voltage, usualy a battery takes quite good job on this
but on very high currents its getting more and more a problem
such spikes made here for example reset the LDO voltage regulator and making the LVP not reliable on very high currents tripping to early
for those spikes capacitors were added usually at least 10uF directly parallel to the battery
a 2.2uF capacitor on the LVP pin 7
spikes here on new more powerful PSU went out of control damaged a few drivers and killed a couple of LEDs
here the spikes on very short time setting
yellow is at the Driver input
pink after the LDO low pass
blue on a capacitor on the Power supply
Mr.Poppy
Totally confused, so which pads lead to LED+, LED-, Switch ???
JasonWW
JasonWW's picture
It is described in post 4. I’ll post it here.
Led + comes from battery spring, not a pad.
Mr.Poppy
Thanks JasonWW,Lexel ! Restored my L6
KevinZA1988
KevinZA1988's picture
Last seen: 34 min 58 sec ago
Hi Lexel, will you be making a 17mmmm or 20mm boost drivers for clicky switch lights too? I have a convoy L2 host that I want to run an XHP35 HI on at least 2.5A Turbo, maybe 1.5A sustained high mode.
Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, Convoy L6, Convoy C8+ , Convoy S3, Convoy M21A, Convoy S11, Emisar D4, Fireflies E07, Jaxman E2L, Lumintop EDC18, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Nitecore HC65, Olight H1R Nova.
https://photos.app.goo.gl/JaJaDv4V838AEJf39
Maverick1947
Maverick1947's picture
Last seen: 1 week 2 days ago
Hello. I am pretty new to modding lights but have the basic skill set necessary. I want to put a FET driver with NarsilM on my Convoy L6. What will I need exactly? I want one 30mm driver (L6 size right?) with NarsilM and the Low Voltage Protection. That’s 15.5 $ correct? Plus 5$ for shipping tracked and insured. How about springs and wires? What’s the best option for me? Thank you.
There’s no replacement for displacement.
