Very cool! I have had that happen to 2 Mtn FET+1 drivers, I quit using them after that, just the straight up FETâs since. Thanks for figuring that out! :+1:
I got my noctigon quad mcpcb and angie optic today. So I made an aluminum spacer and got it mocked up in the light. Iâm just waiting on the 351dâs from the GB to arrive before finishing it up. The optic is a bit small and doesnât fill up the head but itâll work just fine.
Looks good vinte77!
[quote=vinte77]
Nice work! Sharp host too, what light is that?
Thanks, itâs a Manta Ray C8.2. Itâs a nice 26650 host with a c8 sized head. The shelf is very thick, I was surprised it took me so long when I was drilling the center hole.
No kidding, Manta Ray, that is a sweet looking light, 26650 too, I want one now!!! Thank you! :+1:
Happy to help, also itâs nice because it takes 22mm sized drivers.
Well it just gets better and better!
I like that you turned the ano off the bezel end like that, sets the whole light off, very classy look! Or is that a stainless bezelâŚ
Kewl, I gotta look into MRs now.
But donât forget, the F13 takes 26650s and has a 22mm pocket. Nice host.
The MR fits the convoy c8 stainless bezel and MR also makes their own stainless bezel too. The one on my light is the convoy one.
This host is noticeably better quality than the F13. The fit and finish is much better, and the host is a lot heftier for better heat sinking. It also comes with a/r lenses, but of course the price isnât as good as an F13. But you get what you pay for.
Nice mod on the Manta Ray, I too love that look and will probably hunt it down and bag it.
Made a heat sink for the hollow headed Sofirn SF34 9x XM-L T6 today. (just got the light today) It made 1800 lumens stock, I then put a Q8 driver in it flashed with Anduril. A bit over 5000 lumens now. But the thin aluminum MCPCB was totally not sufficient for this, they had the reflector drilled and tapped for two screws to secure the MCPCB to it but they didnât use any screws, actually just taped it together and added a couple of thin pieces of folded cardboard as spacers to keep it from rattling.
With a fairly thick aluminum heat sink and two screws snugging the assembly together, it works pretty well. I have to get some more 10mm SinkPADâs to be able to use the new Samsung emitters but thatâs nextâŚ
Mmmm, 2500 lemons sounds nice in that form-factor.
Where do you buy 10mm mcpcbs?
Mt Electronics sells the 10mm sinkpads.
Re the MantaRay C8.2. I havenât pulled the trigger, but, I inquired with the Ali Express shop to ask if theyâd sell the host with an extension tube. They said they would. I wasnât confident though whether it was an extension tube that mated with the stock 1s tube, or a one-piece 2s tube, which is what I think they use for their 2s XHP50 C8.2.
Itâs not finished yet but I spent some time on a triple Rook conversion today. Built the new MCPCB shelf out of 18 & 22G copper I cut into rounds then soldered together. First I built the Puck then reflowed the noctigon onto it and reflowed the emitters onto the noctigon at the same time.
The tir is the deeply dished, pebble finish Cute. Emitters are what I had laying around.
Waiting on driver boards now, may piggyback something onto the stock driver as a contact till then but Idk what FW to use. Itâs designed with a 25, 7135 + FET (if it were a click itâd run bistro), what do you guys suggest?
4 disks make up the puck (3 18G, 1 22G for proper thickness)
Press fit into light, center hole for 20AWG wires.
Finished head
Nice work on the Rook C_k ! But wouldnât the XP-L because of the higher Vf not be sub-optimal parallel to 2 219Câs ?
Edit: just checked the curves and it is not too bad, in fact the XP-L could well be putting out about the same amount of light as the 219Câs at the same voltage (but at less current so more efficient).
Pretty sure that textured CUTE-3 is a wide angle, if thatâs so then itâs going to rob you of almost 33% of your output. I built a triple for a bike riding friend a couple of years ago and he put one of those on the light then complained that it wasnât very bright anymore. When I got it back from him I tested it against the standard SS honeycomb pattern CUTE-3 and it (the sharkskin textured wide angle) was costing 1100 lumens!!!
Neat idea, but run-time is going to be pathetic on the Rookâs 3 14500âsâŚ
Yea definitely sub-optimal but, as I hinted to in another thread, Iâm just kinda getting back into it. The only money Iâve spent this go around is on EDC lights I NEED, all these old hosts / stalled out projects are just to âsample the goodsâso to speak, see if itâs just a short lived rekindling of the old hobby or if Iâm really back before buying new âtoyâ lights / hosts / parts I donât really need.
I had two each XP-Lâs and Nichia, this is just my preferred non-ideal combo knowing full well what Iâm getting (such a large vF mismatch).
Dale, thanks for the heads up, Iâve literally had this optic for YEARS and always wanted to use it, didnât realize it was THAT bad. Definitely intended for it to be an up-close light, weâll see if I can live with it once the drivers done or not, I have some of the spot optics as well and with the MCPCB soldered / pressed into the head itâs cake to swap optics.
Runtime, well yea⌠I debated making is 3s NiMH vs 3p Lion, this way I can run those 840mAh cells (still get decent current since theyâre 3 in parallel dividing the load) and end up with 2520mAh total (or 2.1Ah with efest 700âs for a higher drain option), either choice trumps the 1900mAh 3S eneloop option.
Not getting my fill of moddong on the rookâs head this morning I also fixed up an sk98 that had a good driver & led but suffered from another plastic press in tail.
Couldnt find a suitable retainer ring to do this one like I did the Zuseray a couple weeks ago so back out came the Cu sheet and shears for round 2.
Huge shout out to Old Lumens, his willingness and unhindered ability to take on the big projects with only hand tools is one of the things that made me realize I could try it too! Seriously if it wernt for him building amazing lights from raw materials, by hand, I wouldnât even have started to take on the miniscule projects I do and all Iâm doing is cutting & stacking flat sheet copper, he was making sheet into tube and building whole lights!!
Started as Cu sheet, made a washer with a step bit and a pair of knipex, pretty dang happy with how it came out (and the fact I didnât leak one drop in the process, usually I cut the crap our of myself trying to drill a hole in the center of a round thing)
You are on a roll CK. nice work.
