Zanflare T1 came in today. Itās a cute little thing!
Some measurements
CCT range: 2600-5900 K
CRI Ra: 81-86
CRI R9 : 2-25
TM-30 Rf: 81-84
TM-30 Rg: 93-96
All the middle CCT modes are very nice in tint next to the BBL. The extremes are a bit above it, but not bad at duv 0.004 for the cool and duv 0.003 for the warm white.
Color and tint donāt change with brightness, which proves thereās PWM. Itās not an issue though, itās very fast and only visible to some cameras.
After getting used to the user interface itās very easy to use. Single tap of top to switch between cool and warm. Hold to change brightness. Double tap to switch to the adjustable CCT mode. Tap and hold to change CCT, release to set. Single tap to confirm, tap and hold to change brightness. I wish it did remember the brightness of the adjustable CCT mode after you go back to the CW and WW presets. Now it blasts full power when you return with a double tap.
Battery end cap gets very hot, some serious losses there. Thereās no marking on which way the battery goes in (positive in first).
CRI data in warm white mode
Cool white
Couple of modes in between
