Guys, looks like Chatika Vas Paus needs help on advice to get his stuff from the custom in Poland. Any help from Poland BLF member will be greatly appreciated. Please PM him.
Many thanks,
Clemence
Many thanks,
Clemence
Not sure about Poland but if they behave like other customs in Europe he will need a proper invoice from you so they can calculate the customs fee.
The situation is just a bit complicated (at least for me). The point is that Clemence has issued an invoice for me to a lower amount than the one that is on the payment confirmation with Paypal (yes, I must also send a payment info from PP). Should I just send them, or what?
Just send or take both. Let them decide what to use.
You did nothing wrong, not your fault that the amounts donāt match so just play innocent ignorance and all is well.
Might have to play a little higher tax but still should get your stuff.
I think so to. You have the $51 real invoice vs the $46 they asked (although I wrote it $50)
- Clemence
Some R9080 goodies arrived on Friday, and today one of my Emisar D4s got loaded with rosiness. :heart_eyes:
Hereās a comparison with an early D4 with 219C 5000K 80+ CRI emitters. Click photos to embiggen:
Hereās a comparison .gif:
Both tints are pleasant, and I get accustomed to either one after a few minutes. Only when compared to each other in person are the differences very obvious. I prefer the 219B.
The photos were taken with a custom white balance for each tint, so they look nearly identical to the camera. I think the reds get redder with the 219B, as expected.
I put a 219B 4500K R9080 in my AA-powered Zebralight H51w about a year ago, so Iām used to seeing only about 150 lumens of this tint. :partying_face: This rosy D4 will be the perfect companion to the rosy headlamp when hiking.
Thanks again for all your hard work, Clemence! :+1:
EDIT: Photos updated due to white balance issues.
Thanks for posting the comparison. Tint looks really good.
Iām afraid to risk the ones I have coming in on a FET light; I plan to put one in a AAA light and hold onto the rest until Iām ready to do a triple; probably either series boost or just plain linear.
Iām a bit nervous too, but Iām running ToyKeeperās AndĆŗril UI with the āramp ceilingā set to a reasonable level.
Iāve bumped it up to turbo a few times just for a moment though. No smoke yetā¦
Received. This time itās all right :+1:
Thatās quite fast. I havenāt received my order yet.
Woohoo! Got mineā¦
Scared the crap outta me for a while. Got as far as ISC San Francisco and then the SF Dist Ctr, ātransfer to next facilityā on the 23rd/24th/25th, thenā¦ nothing. Vanished into the Ʀther. Not a peep from then ātil just yesterday.
I gave the USPS a āwhereās my package?ā holler, and either that jiggled something loose or it was just coincidence, but that same day I finally get a notice that itās at the local PO, then next morning out for delivery, then delivered. Whew!
Still quite odd, because usually it makes stops at various distribution centers (Stamford, Brooklyn, Queens) along the way, but nothing. Bypassed all those intermediary stops? Odd.
Anyway, now I can breatheā¦
Still donāt have mine, and no notice of shipping, etc. Looks like it has been almost a month since the post saying that theyāve shipped. Worried
Iām currently out of the office. I can only access online informations. But I just noticed that your usual address is different from the last one. I sent it to your Eden Prairie address while your address from the last payment was in Edina. Please check if it received in Eden Prairie.
EDIT: the shipment address was correct (Edina)
- Clemence
Mine arrived yesterday in Germany.
Thank you Clemence!
The packing is also awesome.
The remainder of my order arrived today. Thanks again Clemence! :+1:
Indeed!
BTW, there are small bits of foam included to protect the robotsā eyes and mouth. I removed them for the photo. :partying_face:
I just received my order today!
Yes, the packaging is very impressive!
Thank you again, Clemence!
After comparing tints of the various emitters, Iām VERY pleased to report that the SW40 from this batch seem to be like the SW45k in pinkness of tint, but a bit warmer!! This compares favorably to the original SW40 from over a year ago, which were a bit warmer than these new ones, but notably significantly yellower in tint. I already really like the new ones, and Iām glad I ordered as many as I did!
I, too, have been leery of FET driving 219Bs. But Iāve gotten used to running my EDC D4 on LiFePO4 18650s. The estimated 1500 lumens are almost always enough light for me, and itās way more efficient with a lot less heat. If I want, it can usually be run at Max indefinitely until the cell voltage falls too far. Only downside is more frequent recharges needed. Iāll definitely do that swap when I get a chance. (Although, I do have other D4s that wonāt get the mod).
We use pretty good quality and safe li-ions these days but another advantage of LiFePo batteries is that the chemistry is safer than Li-ion.
True. When I was just starting to move from NiMH to LiIon as my primary lights I did worry about that, and the batteries werenāt as good then either. I think using LiFePO4 cells in a D4 or similar would be safer for a āmuggleā using the light, and could take away some of the worries they might otherwise have, and regarding the heat issue as well. It would probably also drive less current through the light should the battery be reversed.
With my 219B D4 mod, not wanting to inadvertently damage the glorious LEDs I might somehow mark the light āLiFePO4ā or something like that.
