Led4power.com : LD-4 CC linear drivers, ILC-0/1 illuminated tailcaps, optics, MOSX, copper DTP MCPCBs...
1330 posts / 0 new
vinte77
Last seen: 22 hours 20 min ago
I wasn’t able to check last night, but I will definitely check today when I get home. As for batteries, I use Liitokala and Shockli. Here are tests of the cells:
http://budgetlightforum.com/node/56542
http://budgetlightforum.com/node/53998
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 1 day 18 hours ago
I assume the PLB 55A cell, e.g. Keeppower 6.000mAh or Shockli 5.500mAh should be the best high drain cell for 26650 size.
“Everyone, deep in their hearts, is waiting for the end of the world to come.” (Haruki Murakami, 1Q84)
vinte77
I thought KP wasn’t a high drain cell.
contactcr
Last seen: 24 min 55 sec ago
Vapcell/Aspire/iJoy/Golisi 4200-4300
Shockli 5500
led4power
led4power's picture
Last seen: 2 hours 9 min ago
That table is great,only internal resistance is missing for complete information.
What is best reliable source (China or EU) for Vapcell/Aspire/iJoy/Golisi 4200-4300?
contactcr
I think both Banggood and Gearbest sell Golisi though I have never ordered a 26650 from either site, only US vendors.
vinte77
I saw that lion wholesale is having a clearance sale on the Aspire 26650 for $6.99 per cell for those of you who are in the US.
The_Driver
The_Driver's picture
Last seen: 5 days 12 hours ago
This one is the best 26650 for basically every application.
For maximum current the Samsung 30T (21700) might be a little bit better, but is has a much lower capacity.
vinte77
Ok, I misunderstood I was thinking of the older KP batteries. So the KP 6,000 mah is the same as the Shockli 5,500 mah cells.
Gravedigger1
Last seen: 1 year 8 months ago
LEDIL ANNA-40-7-S 7x TIR Optics – Spot
What leds go with optic?
C8?
Spacer?
vinte77
led4power wrote:
vinte77 wrote:
led4power wrote:
I meant switch PCB size and switch hole threads, could you check?
Ok, I will check tonight after work.
Did you maybe check it? I just bought one MR C8.2 host,looks interesting enough for extreme power.
What is currently the best 26650 cell for high discharge (25-40A)?
Ok, I checked the switch board and here are the measurements: thickness = 1.3mm, diameter 20.2mm . They are the same ones that Simon used to carry on his Convoy store with HGJ stamped on it. The host comes with the high amp forward switch that Simon sells on his store as well:
https://www.aliexpress.com/store/product/Special-flashlight-switch-125V-...
I don’t have any tools to measure the switch hole threads but I posted pics below. I’m not sure if that even helps. Let me know if you have any other questions about the tailswitch.
!1“>20180727_194301<sup class=1“>!
!1“>20180727_194247<sup class=1“>!
maukka
maukka's picture
Last seen: 7 hours 40 min ago
I got mine from 18650.uk. Out of stock at the moment and very expensive though. Nkon also has them.
edit: misread, you said 4200-4300… disregard my post
led4power
led4power's picture
Gravedigger1 wrote:
LEDIL ANNA-40-7-S 7x TIR Optics – Spot What leds go with optic? C8? Spacer?
I have 34mm MCPCBs for 6x 3535 and 4040 LEDs that are compatible with ANNA optics and Convoy C8. I will offer assembled PCBs with LEDs I currently have in stock, LH351D 4000K 90CRI and Luxeon V 4000K 70CRI.I need to do basic tests and build few "demo" lights to see if everything is ok. I will have spacers too, but it's summer vacation season so there is little delay.
led4power
led4power's picture
vinte77 wrote:
  Ok, I checked the switch board and here are the measurements: thickness = 1.3mm, diameter 20.2mm . They are the same ones that Simon used to carry on his Convoy store with HGJ stamped on it. The host comes with the high amp forward switch that Simon sells on his store as well: https://www.aliexpress.com/store/product/Special-flashlight-switch-125V-... I don't have any tools to measure the switch hole threads but I posted pics below. I'm not sure if that even helps. Let me know if you have any other questions about the tailswitch. !! !!
Thanks for measurements, too bad it's not compatible with Convoy.
led4power
led4power's picture
After looking a little bit more about those high drain 26650 cells, I 'm little bit disappointed they don't outperform 21700 30T, they actually have higher IR than 30T.
The_Driver
led4power wrote:
After looking a little bit more about those high drain 26650 cells, I ‘m little bit disappointed they don’t outperform 21700 30T, they actually have higher IR than 30T.
Well they are Chinese cells. If Samsung made them, they would be better. Also they contain much more total energy. The 30Ts are very specialized, they have a very low energy density.
Enderman
Enderman's picture
Last seen: 3 hours 35 min ago
Looking into buying the LD-B4HV driver soon,probably in the next month or so.
Having 3S input and using a 6V LED (XHP70.2) won’t be an issue, right?
Also, is there any chance of pushing more current through the driver past 12A? It will be well heatsinked of course, not like in a regular flashlight host.
I’m willing to pay significantly more than the 12e base cost if I can get something like 14 or 16 amps or even more.
led4power
led4power's picture
 LD-B4HV is linear driver,in theory it would work with 3S and XHP70.2,but in practice power loss/dissipation would be immense, basically energy from one battery is wasted.
One solution is to use dummy cell, so that you have 2S, other solution is to use LiFePO4 cells.
LD-x4 can be modified for different currents,up to 30A shouldn't be a problem, if I remember correctly, few guys used LD-2/3 up to 35Amps.
khas
Last seen: 4 weeks 16 hours ago
When will the 31.4mm mosX 3× 3535 and 3× 4040 for CUTE-3 MCPCB’s be available ?
led4power
led4power's picture
Very soon.
The_Driver
led4power wrote:
LD-x4 can be modified for different currents,up to 30A shouldn’t be a problem, if I remember correctly, few guys used LD-2/3 up to 35Amps.
You mean they had regulated 30/35A?
led4power
led4power's picture
Yes, in a few days I will have 15-24Amp versions of LD-B4 for new 3x,4x,6x mosX boards, 30-35Amps later when Sofirn releases 21700 C8F.
Enderman
Enderman's picture
So if I was running 20A that means I would have like 80W of power loss at the driver?
I guess I need to look for a buck driver then :/ it needs to work with 3 lipo cells for sure.
Thanks for your help.
led4power
led4power's picture
Yes, linear is not solution when cell and led voltages are far apart.
led4power
led4power's picture
Added new big 3x,4x,6x 3535/4040 CUTE/ANGIE/ANNA optics mosX boards:
https://led4power.com/product-category/mcpcbs/?orderby=price-desc
Also LH351D 90CRI 4000K Samsung is now available on all DTP boards (16mm,20mm,triple,quad):
https://led4power.com/product-category/leds1/
Tomorrow I will add big mosX boards with soldered LEDs and rest of the parts.
vinte77
Will you have the spacers available soon?
contactcr
Can you show a picture with the JST connector installed and hooked up?
Chatika vas Paus
Last seen: 3 hours 44 min ago
led4power wrote:
Added new big 3x,4x,6× 3535/4040 CUTE/ANGIE/ANNA optics mosX boards:
Honestly, I’m a little disappointed. The fact that ANNA doesn’t use all potential. After assembly it will not look too good if the center optics will be “empty”.
led4power
led4power's picture
@vinte77
Probably in 2-3 weeks, (unfortunately) it's summer vacation time.
@contactcr
Later today
@Chatika
I could make 7x pcb, this was initial idea, but spacer for C8 would be too complex to machine, it would cost a lot more than standard single central hole.
So 6x is better than existing cute-3x solutions for C8. And if you are worried about esthetics, there is ANNA-6 optic without central TIR.
DavidEF
DavidEF's picture
Last seen: 3 days 13 hours ago
Just for curiosity, what is the complex machining that would be required? I just realized that a 7x MCPCB would be great for RGBW, with 2x each red, green and blue, and the white in the center.
- The YKK Philosophy
