When will BLF bring out their own Headlamp????
184 posts / 0 new
lohtse
lohtse's picture
Last seen: 8 months 1 week ago
thijsco19 wrote:
I’m currently working on a headlamp.
There are already some ‘balls rolling around’, but nothing serious yet.
But what does everyone wants to see in a headlamp?
This design I have right now might not be what everyone likes but will definitely be an awesome BLF style headlamp.
Excellent news.
For me a good tint,decent high lumens(1000 at least) great low to mid range settings eg 1,5,30,80,12,180,210 etc and good run times… We use our head lamps a lot for caving etc so runtimes and low to mid range brightness is important oh an ipx8 waterproofing.
Suggestions from my partner are… MAKE IT PRETTY and have a silicon strip on the headband(like the Fenix Hl15/30HM50r ).
She has got excited about the Nichia suggestion(so have I a little)
Caving, Climbing, Mountaineering, Kayaking, Diving etc any time anywhere!!! If you in the UK let me know and lets Play!
Current lighting
Olight X7R,M2R,S1 Baton,S10R Baton 3m,S2R 2, I1R EOS,SofirnC8T,Lenser P7'2,Lenser P14,BLF A6,Fenix HL50,HM50R,HL55,CL05,HL05,CL09,CL25,Nitecore HC30,HC65,NU12,NU32,Astolux K1,Petzl E-light,Tikka Xp3,XP3LED,DUO,Atomlight,Xtar Warboys H3,PL47 Manker E03H and many Chinese ones
lohtse
lohtse's picture
LessDark wrote:
I’d really like to see a tripple nichia headlamp that accepts protected 18650.
Don’t need crazy amount of power, just good hcri beam and UI.
Yep completely agree
Current lighting
Zulumoose
Zulumoose's picture
Coyotehawk wrote:
Possible to put a GT on a headband? Wink
I don’t think this would be a headband, more of a strap-on
oh, wait……
Beam me up!
AEDe
AEDe's picture
Last seen: 13 hours 32 min ago
Protected cells lead to long springs with hi resistance, and unprotected cells may work not stable. Also protection bord increase dimensions of headlamp at least for 5мм.
On the other hand, good driver has all needed protections.
Nice to see a colleague here! I am a caver too.
Tjohn
Tjohn's picture
everydaysurvivalgear wrote:
…Triple setup will get the best mix between longer run times on lower levels and high output when needed.
Wink
DavidEF
DavidEF's picture
Last seen: 5 hours 30 min ago
I’d like to see separate optics for spot and flood, so not just a triple or quad optic but two or more distinct pieces with different characteristics. Again, the Russian Special headlamp I linked earlier has this. Then, a driver that can switch between them and also have both on at the same time and at least three brightness modes with mode memory and/or starting on low (or moon) would make it just right. Would be kinda cool if it had two “triple” optics, one spot and one wide flood, with just one of the emitters under each optic being a red, so you have a third (and fourth) option, with all modes the same. Dual switches will probably be a necessity for all this. LOL! LOL
- The YKK Philosophy
Zulumoose
Zulumoose's picture
I have one of These Xanes D25 Headlamps got it with coupon for about $13.
It is a very good performer, my running light. If it had 2 different optics and a selector it would be close what you are describing, and it has a built-in USB charging circuit, behind an O-ring end cap, well sealed and secure. Wouldn’t it be nice to get something like that in a kit with a selection of different drop-in TIR optics, for whatever blend of beam profile you prefer.
Beam me up!
AEDe
AEDe's picture
Zulumoose wrote:
I have one of These Xanes D25 Headlamps got it with coupon for about $13..
It has very low build quality , large weight, bad anodizing, bad thermal interface, low IPxx rating.
thijsco19
Last seen: 12 hours 1 min ago
I should have mentioned that I can’t promise anything.
All I will say at this moment is that I think, looking at all the comments, it will suit BLF nicely. Big Smile
osb40000
Last seen: 3 months 5 days ago
Lightweight, plenty of low output settings, great runtimes, floody, waterproof, reliable/durable, high CRI, silicon strips on the headband but not overly so, just enough to keep it from sliding. I never use the higher output settings on my headlamps, at most I use the 400 lumen mode and usually lower than that.
For me personally, I don’t want a headlamp that’s super heavy and bulky and I suspect that most people that are calling for some big behemoth don’t actually hike, run, backpack, and use a headlamp on a regular basis. There are plenty of 18650 powered headlamps (for good reason), maybe make something that uses smaller cells? Just a thought.
Caleb
Caleb's picture
Last seen: 1 day 4 hours ago
What about something different… a larger diameter triple or quad that can be worn in the center of the chest (think Iron Man?) or on a lanyard… or worn on a waistband or armband?
CJW
Last seen: 6 months 3 weeks ago
I would like to see a single 18650 with a secondary red and or green led for walking to the deer stand
osb40000
huey18 wrote:
Since we are just throwing out ideas, I hope we can see a product similar to the Kogalla RA light.
I like the idea of a led light strip that can be be powered by a battery, hopefully a single 18650, because most led strips I came across requires a 12V source.
The 3 main things I like about this product:
1. you can attach the straplight to the backpack strap or sternum strap
2. being able to store the most of weight in your bag (ie battery)
3. the multiple leds can cover a wider area
Some potential improvements:
1. The UI
2. modular?
3. more minimalistic (too many magnets and is bulky)
This could actually be really cool. I’d love something that attaches to my sternum strap or belt properly.
lohtse
lohtse's picture
Tried a couple of those as client headlamps three trips undergroud (slightly damp cave) and they simply died……
Current lighting
lohtse
lohtse's picture
Well when your UK side drop me a message and lets go play!!!!
Current lighting
adam7027
Last seen: 10 hours 37 min ago
AEDe wrote:
The problem is that most of people on BLF not need a headlamp. For example on Russian flashlight forum fonarevka.ru obout 20% of discussions are about headlams(here I see 2-3% at the best), and I know about 7 custom made headlamps at small-scale production and only 3 such flashlights. There are a lot of people who use headlamps in work,outdoor , fishing, sking, caving and so on. On BLF I see only lumens fans(some of them are Hicri fans too and I like it). 100500lm and 2km FET controlled hot rod with stepdown after 10s on ones head are absolutely useless in real world.
Nevertheless I would be interested to see as BLF headlamp for example something based upon H03 with hi efficient buck or boost driver with one of BLF UI , hicri led and maybe good build in charger, or maybe something in more exotic form factor like Panda 3 . Magnetic control ring also is very interesting element which can be very convinient, but almost non existing headlamp use it.
I also think, that ‘hotrod’ (which is the most trending kind of lights here on BLF) is impractical for headlamp use. I think BLF should not specialize only in that kind of lights, any new designs (with its own application goals) could be highly welcome addition (e.g. DBSAR’s lantern). They don’t need to be maxed out regarding raw output and/or throw numbers. (Also, I would even happy to see some custom stuff, which would go to E27 lamp sockets, because in middle Europe, E27 light sources tops around 80 CRI – but that is a bit different story.)
For me, a multi-emitter headlamp could be one, which I would welcome, if I’d see that as a BLF project.
I think, some of us can agree, that a Nitecore HC65 headlamp could have been a very good one (some of us thinks it even IS), because it has multi emitters, thus, it can serve us good in a bigger variety of situations. I like good output levels, but I am mostly a tint/beam snob. So in this regard, unfortunately, the main light source of the HC65 falls under greatly. Also, as I remember, beams are a bit misaligned for the auxiliary light sources.
Since a bit more than 2 months, i started to fiddle with some Yajiamei PMMA TIR optics in Convoy S2+ lights, and I think, there is a great opportunity there to deal with. For most people, a very creamy flood is the best option in a headlamp. In most cases, I also highly prefer this kind of flashlight beam. However, most of the headlamps are still with SMO reflector, which are suboptimal in this regard.
While I fiddled with those Yajiamei optics (the ones for XP-L and XM-L, with the physical size of d=20mm and h=12.8mm, no stents), I recognized, that the greatest addition to headlamps could be these optics, as if the headlamp is designed to make optics swapping easy, we could have our headlamps just fine-tuned to the way we would exactly like it, regarding the beam.
And if there could be e.g. 3 emitters in the headlamp with this exact kind of optics with a d=16mm MCPCB base, the possibilities of customizations could not end easily.
For example, a specific combination (this could be one which would be on my head near all the time):
1. slot (emitter + optics combination): clear optics, 5 degree beam width: would be suitable for Nichia 319A R8000 5000K, which are rather R8320 in practice, and would give a decent output. 5 degree clear optics make a very dim spill (much dimmer, than with a same size of SMO reflector), so it would be a very efficient thrower, when it is needed to make out some reference objects far away.
Alternatively, 10 degree beaded optics would also suffice.
2. slot: beaded or frosted optics, 30, 38 or 45 degrees beam width: would be suitable for quad Nichia E21A R9080, 4000K or 4500K. Would be the ultimate reading/assembling/studying light, when accurate color rendition is very nice to have or even ‘critical’. Frosted optics provide the most creamiest flood, but they put considerable amount of light into the spill. If we would like to keep most of the light in that medium sized hotspot, beaded optics are better for this.
3. slot: beaded optics, 60 or 85 degree beam width: Cree XP-E HE Photo red (~650-660 nm), as this deep red could preserve one’s dark light sight pretty well.
Alternatively, a quad Nichia E21A of 2000K CCT could make a great service here (a big gain for detail recognising, but some sacrifice of the dark adapted sight).
Another one could be (this one could be good for CJW):
1. slot: beaded optics, 25 degree beam width: same Nichia 319A, as mentioned above, but now a wider, more generally usable beam with moderate throw.
Alternatively, if someone prefers to have a relatively strong, but wide spill, while still having a good throw, I could recommend 15 degree frosted optics.
2. slot: beaded optics, 38 degree beam width: XP-E2 green emitter.
3. slot: beaded optics, 38 degree beam width: XP-E or XP-E2 red emitter.
Again, I think, it is not needed to produce these exact variations, but the most important could be to make these possible, just the way I described them (top priority on modularity). I believe, many of us could make one or two distinctive set of requirements for their exact liking.
Regarding batteries, having 3 of these slots, I think, the best option could be single 21700. A sophisticated driver PCB design could even let chose max. current per each selected emitter to e.g. 0.3A, 0.8A, 1.5A or 3A depending on the power class of the emitter, which would be intended to be used. UI could be dual switch: one for the output levels/modes, one for the emitter selections (e.g. 1. first, 2. second, 3. both first and second, 4. third).
lohtse
lohtse's picture
Hmmm not sure what you mean by the “misaligned) comment…. I use mine for climbing caving walking etc and I also use it in my MRT/SAR role too(as does the team) and as yet can’t fault it…. Would love a few additional output levels but Honestly it just works and works well… Throw on a hill/mountain side is pretty damn spot on and the low levels and CRI are great when working close up to something or a casualty…. I have used a great many Fenix,Nitecore and Petzl lamps(and a few china cr*p) and too date the HC65 is pretty damn near to perfect…
This is of course my opinion.
Having said this I would still love to see what BLF can do!!!!!!!
Current lighting
Agro
Agro's picture
Last seen: 15 min 15 sec ago
Personally I’m severely disappointed with the headlamps on the market. Compared to regular flashlights, they tend to be mediocre and expensive.
I see literally 0 headlamps with BLF UI. And since nobody comes close to BLFers when it comes to UI, this is a major drawback.
The cheapest headlight of good quality is nearly $25 on a superb deal. And is not way better than $7 Convoy S2+ (superb deal as well, $10 more regular price). Or $1x Convoy S9.
Cheap XHP70.2 headlamp? $70? Cheap XHP70.2 flashlight? I own a $45 quad cell, a smaller light would cost less.
I’d love to see a BLF flashlight that would be:
  • 18650 + 18350 with a tube swap (compatible with 18700 so we can use cells with built-in chargers)
  • lightweight
  • efficient
I agree that hot-rodding a headlamp is just not necessary. But good UI and low weight is key.
kiriba-ru
kiriba-ru's picture
Last seen: 11 hours 26 min ago
Im sure you have ikea in your country. They have many hi-cri light bulbs.
ZozzV6
ZozzV6's picture
Last seen: 3 weeks 2 days ago
My best headlamp so far is Nitecore HC65. If we want to design a headlamp then be a headlamp not a multi purpose thing. The strap holder plastic has perfect curve and the light itself is great. It need to be very very good to say the BLF headlamp is better then that.
Or if it is a multi purpose headlamp and it has magnetic tail and else. It need a head strap at least like the Skilhunt H03 not like the Imalent HR20 and Nitecore HC30/33. They are fiddly and not comfortable.
leaftye
I don’t see the need for a BLF headlamp. I almost certainly wouldn’t buy one. Sure, the UI would be nicer, but it’s less valuable than on a flashlight since I don’t adjust output of headlamps nearly as often, and on a headlamp I really like modes with distinct levels so I can better manage battery life on long backpacking trips. For it to be a guaranteed buy, it’d have to be nearly perfect. It would need all of the following: a monster turbo mode, a super low moonlight mode well under 0.25 lumens, be very efficient from 0-500 lumens, have distinct modes with tested battery life at each level, a 4500-5000K tint, a spot+flood beam pattern with zero ringiness in terms of output and color, a smooth transition across the beam pattern, and either no switch light or can be disabled, and priced competitively with Zebralight and Armytek. A bonus would be a safe magnetic charging system. That’s too much to ask for unless a company already makes something that comes close.
The one feature that could make me compromise on my list is a fantastic control ring UI that compares to the Jetbeam RRT01 rather than the rubbish that Imalent and Nitecore have.
The low mode should be lower.
Reviews: Efan IMR18350 700mAh 10.5A, <a href="http://
scottyhazzard
scottyhazzard's picture
Last seen: 1 year 4 months ago
The RRT01, my most used light. Love that little guy.
As for need… It would be cool!
High CRI, flood and spot like the lupina concept but in a BLF format and price range. Maybe a battery pack on the back of the headband or a cable to the belt as an option.
"Those who hammer their guns into plows will plow for those who do not."
anycolourfloyd
Last seen: 1 year 5 days ago
  • lightweight
  • efficient
Yes! I also thought this is one type of light where having 18350 tube available is a BIG benefit, big weight saving if you want to run with it on. Agree light and efficient very important.
Other things I like
- regulated
- 4000-4500K tint
- true firefly mode
sgt253
Last seen: 1 hour 40 min ago
I would really like a BLF headlamp. The regulation, the tint (NW), the UI would be what I am looking for also not a “hot rod”.
SKV89
Last seen: 50 min 20 sec ago
I have a bunch of different headlamps already from Armytek, Olight, Acebeam, Skilhunt, etc.
I really like rotary brightness control on a headlamp, which is by far the most intuitive for one hand operation. Also I would love to see a quad E21A 4000k or maybe even double quad E21A if you go with two lens.
BurningPlayd0h
BurningPlayd0h's picture
Last seen: 1 hour 36 min ago
My dream headlamp:
-18650 with 18350/16340 tube option, runtime or light weight based on current need
-Anduril or another “BLF-endorsed” UI (Someone should honestly make a competitor to Zebralight’s UI, the shortcuts are great but there could definitely be more options still)
-High CRI emitter version available. Triple Nichia (< too much heat maybe?) or whatever that new Samsung that could be in the FW3A would be cool but even high-CRI XHP50 with frosted optic like ZL’s offerings would be cool.
-ATTACHABLE/REMOVEABLE diffuser/optic Imagine taking it off for use as a throwier EDC light, and putting a frosted lens attachment on for use as a wide-beamed headlamp?! Skilhunt tried this but it was a weak attempt IMO. Clip-on or screw-on seems like they could be much better.
LessDark
LessDark's picture
Last seen: 2 weeks 5 days ago
Maybe a hcri xhp70.2 would be nice as well Thumbs Up
zak.wilson
Last seen: 4 days 5 hours ago
No, it would not. Not necessarily, anyway. Sure, it’s less metal for the body, but a four-cell light can use a buck driver with large components. A single-cell XHP70.2 light must use a boost driver with small, high-performance components. We see an example of this in the new mtnelectronics 17mm boost driver: it costs $25.
Ceilingbounce – flashlight testing and runtime graphs for Android
zak.wilson
Maybe, but I have my suspicions about anything from that generation of Cree products actually being nice.
I’m not sure where to get a 90 CRI XHP70.2 in small quantities, but I did recently pick up an 80 CRI from Arrow. I still haven’t managed to get the bezel off the light I want to put it in, so I have no idea how it looks. Previous-generation 90 CRI XHP70s look good.
BurningPlayd0h
From my understanding 50 vs 50.2 and 70 vs 70.2 is just the gaps between the different quadrants of the emitter filled in, but also bad tint and shift because of that? Also frosted/diffused optice would solve the issue of seeing those lines in the beam pattern on the original non-.2 versions right?
