Details and operation please see the 1st picture below
Battery Configurations:
1x 18650 Li-ion battery (Both protected or unprotected) (Not included)
Working Voltage:
4.2V
Switch Type:
Clicky
Switch Location:
Tail of the Flashlight
Material:
Aircraft-grade aluminum alloy
Impact Resistant:
1 Meter
Waterproof:
IPX8 waterproof
Reflector:
Specially high reflectivity smoothreflector
Carrying Strap:
Lanyard
Color:
Sand color
Weight:
145g (Excluding battery)
Size:
142mmx 44.5mmx 25.2mm (Lengthx Head diamemterx Body diameter)
Specification:
1. LED : XPL HI with 1100 lumens high performance
2. C8+ runs on 1pcs 18650 lithium battery (protected or unprotected) ,easily buy and recharge
3. Specially made high reflectivity smoothreflector
4. Waterproof : IPX-8 waterproof
5. Expert level design with 12 goups & 55 modes dimming for your daily use and research needs
6. Big diamaond knurling
7. U shape tail with self-protection defense tactical tail
Can you please help with pricing on the new Emisar D4S that I am keen on? I already have a login to your website but can’t access Neals pricing for it (needs password). I also sent you an email directly, but not sure if you have seen it?
Ordered 2, just arrived. No 2xAA tubes.
The second light doesn’t ramp, click to ~75-80%, and double click to turbo. :cry:
Some of the screws around the switch not tightened enough and the heads feel sharp enough to slice a finger, otherwise good quality construction, nice tint, but likely my last BlitzWolf purchase.
Does your order look like this? Mine was ordered 4 months ago in mid-April and you can clearly see on the image of my order page, that it came with the free 2xAA extension tube,
On the current listing, looks like BG has removed it, and have even listed the 2xAA extension tube as a separate accessory. No idea when this took effect. Perhaps Martin can check with BG, but I suggest it will be a good idea to remove any mention of the 2xAA extension tube as included from now on to avoid disappointment.
Package included:
1 x BlitzWolf® BW-ET1 LED Flashlight (Not including spare aa battery body tube)
2 x O-rings
1 x Lanyard
1 x White Diffuser
1 x Manual
Any chance Neil will sell the protected 18350 from Keeppower like the one BG links to in on their Mini GT page? Banggood doesn't ship batteries to Canada anymore so need another way to get them.
