Im still curious how good or bad the battery life on total runtime will be, it cant be very high if its gonna use 8x18650 batteries 3000mahā¦ Compared to whats out there they cant really do magicā¦
I canāt think of something right, and I didnāt say anything about a device thatās being submerged.
There are really thousands different ādevicesā that are using fans and pretty sure that there are more than you know that are āIPā rated.
Really, a fan is nothing more than an electronic motor and those can easily work underwater. The only thing an electronic motor needs is a changing magnetic field and water doesnāt change that. All the other electronics can be even extern or coated to make it waterproof. The main problem is making a waterproof connection to the inside for the wires.
Yes a waterproof fan is probably expensive but not impossible.
You canāt reason with him. I believe in the tube thread it said he was given a partial refund which he accepted. From what Iāve read, TA was trying to work with him and even offered an addittional larger refund. He would rather bash TAās name and reputation and continues to do so. Iāve found in life when a single person continues to have problems they blame on others, often they have to look at themselves first.
Most of what Iāve read from KG seems so against what Iām used to at BLF, we have a great community here and I hope that doesnāt go away.
The other three dozen customers who bought the TA lumen sphere didnt experience the same issues you have. I posted my measurements with the TA sphere and they were in line with ratings from reputable manufacturers whether they are low powered lights or high power lights, flooders and throwers. You were the only one with issues so we tried to help you figure out the reasons but you werent interested in working with us and instead just interested in proving your accusations are right without doing it scientifically.
We are about to recive the Maukka calibration lights so we can verify scientifically how accurate the current calibration of the TA spheres are.
This is off topic, but itās possible to get accurate measurements with any lumen tube as long as you have a reputable lux meter and
Correct multiplier. The differser sheets are a nice addition to the tube.
