Looks real neat kawi :+1: :+1:
Made a Nitecore TIP cover design and 3D printed it. It has raised edge around buttons to prevent accidental activation in pocket. It covers the micro USB port from dust. And it has a place for two magnets. Actually one enough to hold it in place.
No going for it didnāt work, those single post swivel head knurling tools wouldnāt get it for me either, here is a vid I found a couple years ago. I have the same set-up and tool post. It still took a couple tries before all was good! :person_facepalming:
Great, thank you
18650 extension tube for that dreadful Astrolux E01. Itās a E02 now. Almost.
Cutting square threads isnāt that much of a nightmare actually.
Since I wanted to make this light usable, I cooked up an an attiny85 driver with [1x7135][1x7136@2.5A]*
(* instead of a FET since I wanted to have _some _regulation on turbo; plus no room for stacking 7135s)
and put Anduril (in FW3A config) on it.
Some tweaking required , now itās fantastic. 1A is plenty for my EDC tasks and that should stay in regulation down to ~3.2V.
Lowest usable moon draws 2.4mA, quiescent current is 15ĀµA. Not bad.
It still has the stock XP-L @4000k in it. I got a few LH351Dās and Luxeon Vās on the way to see how they compare ( (both 4000K, CRI ~70 vs 90+ā¦. choicesā¦. ā¦ any ideas?)
No knurling yet (as I donāt have the proper tools) but I kind of like it this simple. Maybe Iāll pattern etch it, maybe it gets a rubber cover.
Weāll see how this holds up anyway, itās only AW-2007 aluminium which isnāt very corrosion resistant.
@kikkoman what tool did you use for the square threads? ā¦and why is the EO1 dreadful?
Nice mod anyway
A hand-dremeled carbide insert (started out as a 11ER 60Ā°), squared the end & sides, narrowed it down to ~.65mm, ground large side & end relief angles and put a tiny radius at the tip.
Could have started with a HSS blank too, I just figured grinding this would be quicker.
From there on it was just manual threading, 100rpm, 0.1mm depth of cut. That AW-2007 machines nicely.
Why dreadful? The driver, mainly. Terrible mode spacing (one mode low, the next three between 350 and ~1000 lm IIRC). No LVP either.
The UI wasnāt that bad (nice and simple) , good form factor too but the modes killed it.
Thanks!
Nice tip. Iāll try that one day. :+1:
I got the pair of Eagle Eye X6 hosts in the mail today, already had the quad board from Noctigon loaded with Samsungs and waiting, so I made a nice thick 36x12mm copper spacer/heat sink to fit the 33mm Noctigon board and Ledil Angie into the head of the X6. Worked out really nice, need to build a driver so when a new thermal compound getās here Monday Iāll be ready to assemble it.
Edit: I went ahead and built a 17mm driver with Bistro and assembled the X6 Quad, after polishing up the top surface of the copper sink. Didnāt use any thermal paste or glue in the sink as I am waiting on Arctic Alumina Thermal Adhesive and a new synthetic diamond thermal paste that will be here Monday. A quick initial test with the light dry assembled showed some 3400 lumens on an LG HE4.
Edit II: The epoxy came early, went ahead and re-flowed the 33mm MCPCB to the copper sink then glued the assembly into the X6 head with the Arctic Alumina Thermal Adhesive and assembled it allā¦.
Bistro was working fine on an LG HE4, but with a Sony VTC5A in place it glitches some of the time. And when itās not glitching? How about 4616.1 lumens out the front?
Edit II: Ok, so I applied the Bistro fix and recharged the VTC5A, now it works solidly and is really amazingā¦. 5171.55 lumens in Turbo at start. Pretty nice little light!
Also got my GT mini yesterday, modified it today. It now pushes 1683.6 lumens out the front on a Sanyo GA cell.
Samsung LH351D 5000K 80CRI emitter, domed, on the stock DTP 20mm copper MCPCB. Flashed Anduril to the driver, replaced the FET with an SIR800DP and put 18ga wires on it. 18ga spring bypass on the driver. Removed the pcb in the tail cap and fitted a copper disc with the large spring that came with the light, 20 ga bypass inside the spring.
Yes, I lost some of the tightness of the beam but the color and intensity is so much nicer I can live with the trade-off.
Some revisions to one of my Sipik 58s.
Bezel and optic same style as I had previous in this light, but now redone for a cleaner look.
This is the stock lens retaining ring with the interior widened with a cylindrical grinding bit. The LED-Lenser style optic is from a $10 zoom light from OSH.
The previous bezel and optic I had in this late used the same setup, but looked much messier because I ground the inside edge of the bezel where it meets the optic back. And Iād messed up with the glue and some had run down the backside of the optic creating blindspots in the spot beam. This latest attempt looks much more professional.
Minor revisions to the interior of the tailcap.
I replaced the momentary pushbutton I had in there with a bigger one with a more noticeable click. I also replaced the post in the tailcap with a wire-bypassed spring:
Previously, I had a spring at the head of the light and a post made from 2 copper disks at the back. That setup worked, but I noticed the light dimming or flickering after a minute or two of use. the problem was a bad ground connection. Adding the second spring fixed that problem by more firmly pressing the guts of the light together.
NOTE: This particular Sipik 58 clone is very heavily modified. Modifications include:
- All anodizing removed and bare aluminum polished up.
- LED mounted on a laminated copper post on top of a copper Noctigon.
- Stock 18mm aspheric lens replaced with LED-Lenser style zooming TIR optic.
- Driver replaced with e-switch FET driver from Mountain Electronics (moppydrv firmware. If I were doing the driver today Iād go with a FET+1 driver with D4 firmware).
- Interior of battery compartment widened to make room for a rolled up plastic sheet and brass sheet to serve as electrically isolated e-switch contact.
- Tailcap guts rebuilt with copper structure and momentary pushbutton switch.
- contact rings added at both ends of the battery compartment for e-switch.
- tailcap switch boot replaced with light-green GITD boot.
- LED replaced with XPL HI 5D
Whatās going on here?
Is that a DR. Jones RGB driver on the test stand?
Yes, yes it is!
More to come, off to ITCC finals!!!
And here it is (my ITCC event got pushed till this afternoon)!
After a stupid routing mistake cost me my $10 driver boards, and not willing to try, and wait for, boards again I switched direction on my triple Rook.
Dr Jones RGB driver! Itās his standard 17mm board with modded rgbw FW (to be 3 channel, using RGB for white). Each channel is 2x 7135.
I really like how well the flood optic works with the RGB and runtime should be ~1h on turbo āwhiteā, though itās more of a toy instead of a useful light so I may stack another 2 chips per channel later and sacrifice that runtime.
Looking sharp Dale !
Thatās one good looking Quad X6.
Is that the stock lens? It looks quite thick
I have the stock hostsā clear o-ring on top of the optic and the AR glass lens on top of the o-ring.
I just got the fix applied to Bistro, no more stepping down to moon from Turbo or Strobeā¦. the fresh charged Sony VTC5A yields a start value of 5171.55 lumens, amazing!
Edit: YOu can click on the picture to open it in a new window then click it again there for a larger look. The set-up then shows itself, optic/o-ring/lens.
In case anyoneās wondering why I drilled the outer two holes in the base of the copper heat sink when the center hole is used, itās to give torsional strength to the glued joint. I align the ~4mm deep holes with the original wires holes in the emitter shelf of the head so the glue has āpostsā to it, really limits the ability for the whole thing to slip and twist wires.
I love using the Arctic Alumina Thermal Adhesive as it sets up in minutes, itās stuck in about 5 minutes and pretty much cured in 12. Another thing I like about it is that if an mcpcb just has to be removed you can heat up the board with the soldering iron and break the epoxy joint loose. Canāt do that with Arctic Silver or JB Weld, once in with those itās just gonna stay there pretty much.
Looks like someone has a new favorite LED
