Will you have the spacers available soon?
Can you show a picture with the JST connector installed and hooked up?
Honestly, I’m a little disappointed. The fact that ANNA doesn’t use all potential. After assembly it will not look too good if the center optics will be “empty”.
@vinte77
Probably in 2-3 weeks, (unfortunately) it's summer vacation time.
@contactcr
Later today
@Chatika
I could make 7x pcb, this was initial idea, but spacer for C8 would be too complex to machine, it would cost a lot more than standard single central hole.
So 6x is better than existing cute-3x solutions for C8. And if you are worried about esthetics, there is ANNA-6 optic without central TIR.
Just for curiosity, what is the complex machining that would be required? I just realized that a 7x MCPCB would be great for RGBW, with 2x each red, green and blue, and the white in the center.
I think this was discussed hundred times about X6 triple and have same reasons here.
If you have central hole in pcb you dont care about rotating pcb to the spacer or spacer to the head.
If you have hole not in center, you need to fix both (to avoid wire cutting) so you need threaded holes in spacer (from both sides), holes for wires (remember that sometimes you need more than 2 wires).
Thanks kiriba-ru. I often miss those conversations because I don’t mod much. Plus, my memory isn’t very reliable. So it’s probably true that it has been “discussed hundred times” and I missed it or forgot it.
Example of fully populated 3XV-C mosX board:
Parts needed(for LD-B4):
First two "components" on the left are two small 0.6mm FR4 boards which are actual "LED" wire pads.
mosX boards are very thermally conductive everywhere which makes soldering wires directly to board very challenging, it's possible (but not easy) on 20mm size boards, but these boards are >30mm - soldering wires directly would be a nightmare. So these thin FR4 plates serve as very good thermal insulator - soldering wires should be easier than on standard copper DTP boards because those usually have 0.2mm FR4 thick laminate on surface.
For same reason there is small JST smd connector on board for signal wires (gate,NTC,moon) - in theory I could make 3rd FR4 plate for those, but I think connectors are simpler to use for end user, especially if wires with male connector are already soldered on LD-B4, in that case build is as easy as with any other normal 2-wire driver.
All parts placed:
Soldered, everything fits nicely:
Just tried it outside of flashlight with bench power supply, tint is absolutely fantastic (still can't believe it's only 70CRI,looks better than some 90CRI LEDs) complete uniformity across the whole beam, and brightness looks already impressive at just 9Amps. I think I will put this board in Kiriba-ru C8 head and drive it at 15-18Amps.
Seems very clever! Will the FR4 boards tolerate 25-35A? I want to use three parallel Luxeon MZs in direct drive (for short perdiods of time). I will also use the Kiriba-ru C8 head.
Wow! that looks very nice and professional!
There are many vias so electrical resistance is very low, that's really last part of whole flashlight circuit you should be worried about, springs will be the bottleneck for sure,even bypassed ones if not done properly.
Ok, good! I’m worried about everything!
Currently “working” on a suitable FET-switch with loneoceans, fady and lexel. Will I be able to route leads suitable for 30A through the hole in the middle of your new pcbs?
Springs are an important point. I want high spring pressure and low resistance. Maybe a multiple leads will be used for the bypass and the top of the spring might be covered with a copper or brass disc (gold plated).
LD-B4 driver has holes for up to 18AWG wires max., this is good enough for 30+Amps, there is plenty of space for wires in spacers. You don’t have to worry about switch
Soldered all variations(Luxeon V 4000K, LH351D 4000K 90CRI) just to check how everything fits, also tested them with bench power supply.
6x variants definitely put a lot of light at just ~10A, beam looks good with all optics, clear optics have some tint separation like usual, frosted cute versions bled light completely.
now we just need those spacers. :innocent: I plan to mix one of the frosted Cute4’s with 4000K and 5000K 90CRI LEDs if they blend well like you mention.
Demo build1 -C8 6xLH351D 4000K 90CRI (still not 100% finished):
This is how spacer will look like,a little unconventional and more complicated, but it has several advantages - build is easier once spacer is fixed and can't move, spacer is compressed with high pressure, and all wires can be soldered on driver first which is usually much easier. Hole in C8 should be ~8-8.5mm.
Driver LD-B4 18Amp for this build:
Those FR4 0.6mm thermal insulating boards are working as expected, soldering thick wires on them is very easy.
Moon mode:
I used common 1288 Omten switch and 30Q cell,so I didn't test light under full potential yet, but it's damn bright for 90CRI and it's size. Brightest 90CRI C8? Hm maybe even brightest single cell 90CRI light?
Of course big die dome led and relatively small TIR size (but much bigger than carlco optics) makes this light flooder, but it still can burn paper:)
And relatively big ALU spacer definitely works well as thermal storage because light didn't get crazy hot very fast, but it also took more time to cool down. If you are going to use this kind of light in <1min pulses with >1min pause,it is beneficial.
Only aluminium? Will it be also available in copper?
You don’t want that chunk in copper
And it will not help a lot for the heat path either.
Great work! You’re really churning stuff out lately! I’d like to see what the maximum potential for this build is. djozz? :smiling_imp:
6x Luxeon V or 5700K 90CRI MZ will be more potent,351D is not best LED for max. output.
