Check the flux bin tho.
J3. 520lm at 3000mA.
It helps if you post that number comparing it with another led: the Cool white SST-20 that KD sells is L2 bin (1 after highest bin), which is 811 lumen@3A, so this L3 bin (1 after highest bin) ultra-high CRI 3000K version costs you 36% output compared to the low CRI cool version. This is very common.
Simple, make a triple : 245lm per LED (1A each) and you get 745 LED lumens
Yes, but isn’t the absolute number rather poor by the standards of some other, warmish, ultra-high CRI emitters? For example, in Texas_Ace’s test a D240 4000K 9050 (over) driven at 3A has about 800lm output.
eas:Check the flux bin tho.
Wouldn’t using a triple to achieve higher output and efficiency offset the SST-20s advantages with respect to luminous intensity?
(I’m still ordering 5 of these)
Still unable to login. Is it just me?
You have to create a new account with all your old account credentials. Use all your info as from the original.
I’ve been encouraged to post here as a quicker way to bring an issue to KaiDomain’s attention.
In short, I received another KD user’s login credentials to my email. I have sent an email to KD customer service with more details.
I had started another thread about the topic here: KaiDomain sent me another user's login credentials. [UPDATED]
Hi
Please ignore the previous email as for our system integration testing.
We had moved all of your order history that is created as before 1 July 2018 to the new system in a few day.
If you have any question, please feel free to contact us.
Thank you
Hello!
Peeking for insulation gaskets just found this:
17MM IRON INSULATION GASKETS (5 PCS)
Iron insulation gaskets…
I guess these iron insulators are for the top of small clicky switches.
BanL, could you add a filter by “date added” please ?
Sure.
I will add it on those Category page.
Thank you for your advice.
I’m wondering if These are real. I think I’ll grab a few if so. Wouldn’t these actually be XP-E2s? Opinions?
Eh, I don’t think those are XP-E2’s. It looks like HEW is a “XP-E High-Efficiency White”.
Product Info: http://www.cree.com/led-components/products/xlamp-leds-discrete/xlamp-xp-e-high-efficiency-white
Press Release (2010): http://www.cree.com/news-media/news/article/new-high-efficiency-cree-xlamp-led-can-reduce-initial-fixture-cost-for-lighting-manufacturers
Hi X3
I had added the sorting by ‘Release date’
Thank you
Ban
RotorHead64:I’m wondering if These are real. I think I’ll grab a few if so. Wouldn’t these actually be XP-E2s? Opinions?
Hi friend
This is not XP-E2 LED.
This is only the CREE XP-E (HEW) High Efficiency White with high CRI.
We just install some for our customer.
Thank you
Ban
~~X3~~:BanL, could you add a filter by “date added” please ?
Hi X3
Thank you
Ban
That was FAST !
Thank you very much BanL !
I would love to see those new XP-E HEW emitters tested, both the Q3 7A2 (3000K) CRI90+ and the Q5 5D2 (4000K) CRI80+. 1mm² die size? Kewl for small throwers, maybe.
Cheers :-)
Cheers :-)
Me too!
I've actually been wanting to make an edc triple using XP-E2s but could never find a good tint/CRI option. These (XPE HEWs) will still make a better spot and throw further than XPLs in a carclo optic.
I built one a couple of years ago using the xpe2 torch LEDs and it definitely puts more light on target at lower power consumption compared to XPLs (It's a more defined and focused hotspot) but the tint and CRI sucks on those torches.
