If the same driver and emitters used in a super wide flood host and a thrower host results in about the same lumens measured in the TA tube, that clearly shows the TA tube doesn’t favor flooders or throwers. Really how difficult is that to understand? If you refuse to use reason and logic, there is no way we can help you get to the bottom of your issues.
Sorry sb56637, I was trying to give a few facts to help KG clear his misunderstanding of the TA tube but now realizes it is futile. I won’t continue this discussion further.
I just realized this light isn’t going to be like a brighter X65. I was hoping for a high lumen thrower like, “And f••• that guy in particular waaaay over there.” But looking at the reflectors it’s going to be more like an Emisar D1S is trying to escape getting eaten by an X80.
Still excited but maybe not the instabuy I thought it was going to be.
I was going through the throwers on parametrek when I realized the X65 had more throw than the X70 and I thought, “Wait wait wait. What?” And that’s when I finally looked at the head of the X70 and realized just how monstrous an X70 would have to be if each LED had a reflector like the X65 does. It would have to be vehicle roof mounted!
Where do I write the check out to? (Just kidding my wife would kill me.)
Edit: would be a great recommendation for all the people asking for a “self defense flashlight.” “Buy this thing, it’s a medieval mace with +3 fire damage.”
Isnt lights like this meant to just shoot tons of light like crazy vs throw very long? not really like throwers even tho this one is gonna go for like 1km it still impressive but u wont get that tight beam tho. Also u can take a swing at someone in case self defense would be needed lol… Im curious how the final version will be like and if they ditched the fans it means they had same issues olight had…
If neither acebeam or olight can manage to produce lights with active cooling then it seems something is wrong no? because waterproof fans etc exist so i dont get it ?
I doubt they can go fanless, even the x9r if i run for almost 3m it gets quite hot at the head, so that much more lumens is almost worthless if they go full passive since that light will produce more then what 220W of power ?
Maybe they can bundle one of those misting fans with each light. Put some ice in the bottle and every time it gets too hot you just spray it a couple times.
Edit: That was a joke, in case anyone thinks that was serious.
But i dont get it, acebeam showed earlier the prototype with 3 fans, same did olight so its weird if also they now ditched the fan design, the light will cost alot more then x9r so for that much lumens i think active cooling is a must if they want longer runtimes on max then a few min …
