Is memory effect a serious concern for NiMH batteries?
17 posts / 0 new
ksio89
I knew that nickel-cadmium batteries might suffer from memory effect if they are repeatedly recharged after being only partially discharged. However, after doing some research, I found out that nickel metal hydride batteries may also suffer from this. I have got a couple of genuine Eneloop batteries, which were very expensive, so I would like them to live as long as possible. Besides these batteries, I own a Panasonic BQ-CC17 smart charger, which is a good albeit slow charger according to a review by HKJ, thus I suppose it will contribute to extend my batteries longevity. For the experts here on BLF, would anyone be able to tell me if memory effect is a real concern for NiMH batteries? If so, are there any recommendations to lessen it? Thanks in advance.
Edited by: ksio89 on 08/03/2018 - 17:25
Pete7874
Pete7874's picture
Last seen: 1 hour 20 min ago
Short answer, no.
Lightbringer
Lightbringer's picture
Last seen: 59 min 49 sec ago
Yeah, not even serious, largely nonexistent.
ChrisGarrett
ChrisGarrett's picture
Last seen: 13 hours 52 min ago
Use ‘em and abuse ‘em.
Space aliens are a bigger concern.
Chris
NeutralFan
NeutralFan's picture
Last seen: 4 months 1 week ago
Agreed. From experience and from what I’ve read here, it seems the eneloop batteries are pretty much bullet proof.
I’d rather use my flashlight around the house than turn on the lights.
ksio89
Thanks for the replies, guys. Glad to know Eneloop batteries last very long when paired with a good charger.
gadabout
Probably worth adding that you should try to keep them in matched sets if you use them in series, especially in the 4-cell soda can type lights or other electronics. They are very robust but can be damaged by reversal if you pair an older cell with 3 new ones for instance, or if you put them in at different states of charge.
I use a MAHA C9000 to glance at the approximate amount of charge each cell takes. If I see one becoming vastly different from the others I’ll separate it and run a break-in cycle.
My Eneloops have been rock solid going all the way back to 2006. Some of my Imedion Powerex 2300s are getting a bit flakey. Mostly self-discharge issues. I think a few of them should be culled.
Other various cheapies are all over the place in terms of capacity and self-discharge. I don’t put them in anything critical.
The IKEA Laddas (White and the older greens) have been performing well so far.
teacher
teacher's picture
Last seen: 1 day 5 hours ago
Same here gadabout!! Got my first ones in 2006 also, & those are still going strong. Eneloops are the best thing since ‘sliced bread’…. Wink
Best investments (every time I buy more) I have ever made. Thumbs Up
Macka17
Last seen: 11 hours 6 sec ago
Early Ni-Cads carried memory. After a while whatever you ran them down became starting point for power retention.
and they became less and less a fixed capacity storer. Only used the top section basically.
They had to be drained waay down, regularly to keep them working at full capacity
These Eneloops though. seem to come from a different planet. enjoy them. I got a 6 pack aaa in my UHF hand held. at least 22 yrs old. Still works when guiding caravan backing.
plasma327
Is there a difference between the Eneloops pro’s and the standard version?
I bought the pros as when i made the purchase they had no standard versions
so i have nothing to gauge them too. The do work awesome though. I like them very much !
Pete7874
Pete7874's picture
Pros have higher capacity but shorter cycle life.
DB Custom
DB Custom's picture
Last seen: 3 hours 25 min ago
Have used and abused Eneloops for a decade. Take em out of my flash units at a wedding so hot I can’t hold em. Charge 32-40 for events, run the snot out of em, they just keep working. Have some new Pro versions both in Panasonic and Eneloop variety, as well as Imedion cells. All LSD, all abused pretty equally. Even use Imedion LSD AAA in my razor. It lives in the shower, (I think my wife steals it too) even that tiny little cell lasts a long time and just always charges up nice.
Won’t buy a NiCad.
plasma327
OK. Thanks Pete
d_t_a
Last seen: 9 hours 11 min ago
teacher wrote:
Same here gadabout!! Got my first ones in 2006 also, & those are still going strong. Eneloops are the best thing since ‘sliced bread’…. Wink Best investments (every time I buy more) I have ever made. Thumbs Up
I’ve also had Eneloops from 2006-2008 (AA and AAA), I was able to run a capacity test only last year when I got an analyzing charger.
So far, they have lost not too much capacity (1600-1700mAh for the 2000mAh Eneloop AA) — I haven’t used those batteries that regularly until about last year. And there were times when I just kept them in storage without using them for as long as a year or more.
However, their resistances are very high now (>1000mOhms on the SkyRC MC3000). And when testing the Eneloop AAA on say the BLF A01 copper flashlight (Nichia 219B), the High brightness mode isn’t that different from Medium brightness mode, indicating it doesn’t work with higher-drain devices anymore. But low-drain devices should still work fine.
gerasalex
gerasalex's picture
NiMH-batteries how it is better to store them if they lie without operation? Completely charged or discharged?
"... God is light, and in him is no darkness at all..." 1 John 1:5 (KJV)
Boaz
Boaz's picture
Last seen: 13 hours 9 min ago
  Doesn't matter .. Nimh has only a small odd tendancy to need re awakened . They nap and need to stretch a bit when they first wake up  so the capacity will increase slightly  during the first few charges .
   Seems like the point of low self discharge batteries is to charge them fully and have up to 75-85 percent of the original charge up to 5 years later ...Where as a non LSD nimh battery will generally be dead in a month or so.
   Interested in Diffuser film …  http://budgetlightforum.com/node/42208
Phlogiston
Last seen: 3 hours 10 min ago
The thing that kills Eneloops is reverse charging them in multi-cell devices (single-cell devices are safe).
When you have more than one cell in series in a device, one of them will always be ever so slightly weaker than the others. If you run them down to the dregs, that weaker cell will be driven into a reverse charge (it will have a negative voltage!) by the other, stronger cells. That will damage the cell permanently; it may even emit gas.
When your flashlight starts to dim, or your device starts to lose power, charge the cells as soon as you can. Avoid running them right down unless you really have to.
