Got my GT-mini (NW) and it is a really nice well done light, even nice for actual use!
The beam is great, as perfect as can be achieved by a medium size smooth reflector and a XP-L Hi, perfect centering and focus, very nice distinct small hotspot with useful corona, no apparent tint shifts. Just the center of the hotspot shows some yellow, a common flaw of the XP-L Hi, has nothing to do with the quality of reflector or host (some leds cause it, other leds don’t, never got it explained by anyone)
The colour temperature I measured 3950K for both hotspot and spill, the hotspot a littlebit above the BBL, the spill on top of the BBL. So at least my copy is pretty exact 4000K.
If I could change anything, I would improve the feel of the switch, it is ok enough but a bit mushy. And a flat bezel from SS of course.
Hmm, fiddling with the light a bit more, and now I have switching problems, it seems that the switch does not make good contact, have to press several times to get the light on and off, and same for ramping. So possibly a mechanical thing. But it could be software too.
Maybe they didn’t get the press fit retaining ring pushed in all the way? Mine really works nicely, very reliable. The switch is mounted on the driver itself, the rubber boot is or should be in a fixed position relative to the switch, so if it’s acting weird it’s going to either be a loose press fit retaining ring or a loose switch on the driver. If your bezel isn’t glued that’s easy enough to find out and if you can get inside then you should be able to tell if the switch is mounted solidly on the driver.
Really odd how some are glued hard, some glued lightly, and some not glued at all. VEry strange. Mine had great gobs of Blue Loctite in the bezel, had to mount it in the 5” chuck on my lathe and use a pair of 16” channel locks to break it apart, even then it did not want to let go.
The dots line up fine. And the switch clicks fine as well, you feel a good click and you hear it too, the response to the click (or hold) is just not there, as if the contact surfaces inside the switch are very dirty or something. But I’m not going to solve this tonight, tomorrow there is another day!
Even after being removed the driver presses back into a snug fitting position, even after a few removals. So it at least doesn’t get all loose and floppy after the glue is broken at the driver shelf. And yes, there is that bit of like Elmer’s glue holding the driver in place, ears/tabs or not, the driver isn’t shifting around not even after being removed.
About the only difference I see is that the GT Mini has a bit tighter corona.
DrDevil, do you have a lux meter? Have you done a side by side candela measurement?
Seperate reports have shown they should be about 130kcd to 135kcd. It’s not like anyone could see that difference, but I was just curious to see both measured with the same meter and under the same conditions.
how would u do bounce test on your ceiling anyways? i have a few apps that shows lux but how actually do it proper? Would that even give an estimate on actual lumens ?
I’ve found it to not be very accurate at all due to lights having different beam shapes, etc… It’s also not comparable to anyone else’s numbers as you have differences in table heights, ceiling textures, paint colors, etc… I never used a phone app, only a $30 Dr Meter LX1330B.
Basically you find a table or something similar and mark you a little spot to always tail stand your light. Then I mark a spot about 6 inches to one side to put the meter. Using the same light and meter orientation will give you repeatability.
Since light is additive, I turn off most of the room light except for a little lamp. I read this ambient level and later subtract it from the total. Then I turn on the flashlight and wait for it to either stabilize or hit the 30 second mark, whichever comes first.
I’ve never tried to equate it to lumens, but it does show me small changes in a particular light. Such as doing an emitter swap, spring bypass or a resistor mod, etc…
It’s not very good for comparing different styles of lights. Throwy beams and floody beams of the same lumens can give pretty different results due to the way the light reflects from your ceiling back to the meter.
If you have similar lights it can tell you which is brighter/dimmer etc…
Of all the different ways to measure lights, the candela or throw distance is the easiest. If you ever wanted to try it, you just need a $15-$30 lux meter and a tape measure. Here is a video showing the procedure.
