Fireflies ROT66 Flashlight
973 posts / 0 new
JasonWW
JasonWW's picture
Last seen: 10 min 52 sec ago
Flashy Mike wrote:
One more question: can I open the switch bezel to get access to the switch board without scratching it?
The switch bezel looks to have the little notches on the inside edge. So it looks like it’s threaded. Whether or not you can unscrew it without scratching it depends on your snap ring pliers and your skill.
As far as it being glued as well, maybe someone can tell us.
Click this to go to signature links.
Flashy Mike
Flashy Mike's picture
Last seen: 50 min 6 sec ago
I’m able to tighten or loosen any protruding screwed (unglued) bezel with my sophisticated bezel tool:
JasonWW
JasonWW's picture
We were refering to the side bezel around the switch.
Wait, you are the one who asked about the side switch bezel.
On the Q8:
From etex
steel_1024
steel_1024's picture
Last seen: 15 hours 4 min ago
Flashy Mike wrote:
@Fireflies:
May I repeat my question:
How is the bezel fixed?
Is it just screwed, or glued, or pressed …
Can I open it without damaging the light?
Edit:
Switch bezel, No notches, not easy to open
Looks like interference fit
Driver’s bezel fixed by some glued.
You can disassemble the MCPCB first.
Then use the Needle-nose pliers to open.
Will leave some scratches on bezel.
Sorry for my poor english.
JasonWW
JasonWW's picture
Well that is great. I guess I was seeing little shadows on the ring that looked like notches.
So what do you do if the switch goes bad? Throw the light away?
Maybe with the driver out, the switch bezel can be pushed from the inside?
steel_1024
No, can not pushed from the inside too. Very small hole.
I will try the leverage……
JasonWW
JasonWW's picture
I’ve got a light with what may be a press fit bezel. I was thinking of sliding a dull razor blade under the edge to try and lift it. It may scratch the finish, so I haven’t tried yet.
steel_1024
Leverage principle, not difficult, but be careful
Will not hurt the rubber press, bezel
JasonWW
JasonWW's picture
Thanks. Thumbs Up
Flashy Mike
Thanks a lot!
Same principle as Emisar D4.
The black ROT66 has a black switch bezel though, painted, I guess. Probably more chances to scratch that one. I’ll try to print some plastic tool for removal when necessary.
Or I simply might remove the paint from the bezel, if scratched.
Flashy Mike
Thanks!
Just to check if I understand correctly:
1.) The lens bezel is screwed without glue?
If yes I would still like to see a statement of Fireflies if this remains true also with the production units.We have seen problems with glued bezels on later production units with other lights in the past.
2.) The driver board is retained by a screwed and glued ring?
But why do I have to disassemble the MCPCB first?
Would you mind to remove the driver boards retaining ring once more and make a picture of the board only (board can stay in place)? And what’s the inner diameter of the driver boards retaining ring? I intend to design my own board and would like to know if I can place the vias for a programming interface between spring and retaining ring.
steel_1024
1.) Mine is not glue on the lens bezel.
2.) Yes
The wires connecting to the MCPCB are very short.
The inner diameter of the driver boards retaining ring is:10.8mm
Here put a black plastic insulation ring
I re-solder the (+)spring so I removed it
Flashy Mike
Thanks again, Steel!
10.8 mm is narrow, might fit with a small spring, but I guess I can widen the inner diameter by 1 or 2 mm. The opening of the insulation ring has to be widened anyway.
I think I can start designing this board now. But there is also our first 3d printer waiting for launch, and the kids are pushing …
maukka
maukka's picture
Last seen: 5 hours 14 min ago
ROT66 received. SW45K R9080 confirmed, very pretty beam confirmed. Review coming up hopefully early next week.
d_t_a
Last seen: 18 hours 3 sec ago
Nice!
twisted raven
Last seen: 8 hours 30 min ago
How is the beam profile compared to the Astrolux MF01 Maukka? Is it a nice broad hotspot where all the lumens concentrated in that hotspot with minimal spill? Or is it slightly different?
Also when you do the review can you tell us what the highest fully regulated output is and if the light gets hot at all on it?
maukka
maukka's picture
I’ll take beamshots comparing it to the MF01 for sure. Highest fully regulated output would be the 7×7135 level, which should be somewhere around 500-600 lumens. However, you would have to switch to the mode groups from the ramping UI to reliably select that level. I ramped the light to ~600 lumens and I’ve been running it for over an hour and it is regulated.
twisted raven
The original driver designed by Lexel had much more of the 7135s, I wonder why Fireflies decided to use less of them? My guess was either to cut costs or they thought it wasn’t necessary to have the higher regulated output levels because the host couldn’t take the heat.
Can’t wait to see beamshots!
Lexel
Lexel's picture
Last seen: 2 hours 50 min ago
The ramping table is the same on both, on the Nichia they decided to use less AMCs total number after their tests
the XPL HI should be fully equipped
SKV89
Last seen: 2 min 8 sec ago
Thank you for confirming for us! Looking forward to your review! Good to know that the CCT is 4200k to 4300k. I was afraid the ultra low duv might make it overly magenta but lower CCT should make it more rosy than magenta. I might still get one to swap in 4000k 9080 though in the future.
BTW, how did you get it so early? Did you buy it or did they send you one for a review?
Wieselflinkpro
Wieselflinkpro's picture
Last seen: 16 hours 28 min ago
Maukka, you have good and similar Flashlights for comparison. But I think the Manker MK 34 would be the next similar Flashlight, not the next to the ROT but next to all the Flashlights on your picture.
maukka
maukka's picture
The MK34 was such a disappointment that I sold it.
toobadorz
toobadorz's picture
Last seen: 2 months 4 days ago
My ROT66 encountered some waterproof problem so I returned it to Fireflies for a replacement. The O-ring right between the lens and the SS bezel seems slightly too small and thus not really waterproof.
Just noticed that on my ROT66, the lens O-ring is different from that on maukka’s (translucent vs. red).
toobadorz
toobadorz's picture
Wow, on my ROT66, after Turbo (ramping) is activated, the default thermal step-down will kick-in in ~30 seconds (down to ~1500 lumens). And then within 1 minute it will step-down again to ~700 lumens and keep this output regulated. Maybe my reading is on the higher side?
Lexel
Lexel's picture
You can configure the step down tenperature in the BarsilUI
toobadorz
toobadorz's picture
Of course, but IMHO its default setting is good enough (short Turbo though). The max temperature around the side switch is ~45°C, which is fairly good. And after stepping down to the highest regulated brightness level, the max temperature is ~43°C after two hours.
maukka
maukka's picture
Just FYI, the default mode set group (4) with (moon) – 0.25 – 3 – 33 – full FET have both the 1×7135 and 7×7135 selectable. They are the middle modes 3 and 33. Makes testing the runtimes and efficiency easier since theyre’s no way to activate those in ramping mode. No default 1×7135 like on the D4.
edit: this is from the Q8 quick manual. On the NarsilM reference manual the modes are called moon – 2 – 10 – 40 – full.
twisted raven
Good mode spacing!
toobadorz
toobadorz's picture
Yeah, the default mode-set is:
Moon (7135 ×1, PWM)
7135 ×1, 20% ~10% (PWM)
7135 ×1, 100%
7135 ×7, 100%
FET only, 100%
right?
maukka
maukka's picture
Exactly.
What I don’t particularly like is that changing the batteries resets the light back to ramping mode.
