Ended
I just recieved my two. They are working fine. Very nice design. They even have a blinking side light for when the battery level is below 30%. I have not heard that before, so I thought Iā€™d mention it.
My only minor issue is the coating on the springs is not fixed. On one spring I see several ares where itā€™s peeling. The other spring has a couple of barely noticable spots. Maybe the next time I have my soldering iron out Iā€™ll add a little bypass wire.
Got my T1 today as well. Figure Iā€™ll give it to my son on his 11th birthday later in the month. The tint ramping is pretty dang cool, pick your poison as it wereā€¦ :slight_smile:
Got my order today, neat little thing it is. Good thing I ordered 4. :smiley:
recā€™ed my 2, all I can say is WOW. Not that Iā€™d want my kids to lose more lanterns but Iā€™ve been supplying them
with the 3xAA lanterns; theyā€™re not worth the 3xAA Eneloops I put in them. And the Blitzwolfs, yea theyā€™d be good night lights :slight_smile:
Hope he likes it. ā™„
I just got mine as well, Used it a little bit and now I have it charging. With the risk of sounding dumb :person_facepalming: I have a question, to turn off the light can you do it from the top metal switch or do you have to do it from the bottom (next to the tailcap) switch? I tried to turn it off from the top switch but it just kept changing color or brightness, maybe I just havenā€™t got the hang of it yet.
So, can someone tell me How do you turn it off using only the top switch? :student:
Thanks!
Unfortunately, it can only be switched off using the bottom buttonā€¦
If you press and hold the bottom button to turn it off, it should memorize your previous color and brightness level.
I received my light yesterday and it seems to have some issuesā€¦
First is I canā€™t turn it off without totally removing the battery compartment cap (boy not having anodized threads for a lockout is annoying) but the bottom button doesnā€™t do anything. Seems like thereā€™s a bad connection at the driver / button or a broken wire inbetween.
I was thinking I could spray paint the threads to try to make it so I could just crack the tail to shut it off. I like the light and definitely want to be able to use itā€¦ Does that sound like itā€™ll fix it make it usable?
Second (and it may be related) is that I canā€™t ramp brightness in the tint mixing mode. Have I just not figured out the UI yet or does ramping brightness in tint mode require that bottom button again (which wouldnā€™t be fixed by my proposed solution for shutting it off above)?
I really donā€™t want to try to open up a glued together plastic bodied lightā€¦
The bottom button is used only for red modes and off, everything else is done by the top touch-button
I would open a ticket and ask for a replacement, never had a problem with GB when I received a DOA, they always refunded me
Coupon is no longer working. ā€œThis coupon has reached its maximum limit.ā€
I found that out!
Such a shame you canā€™t turn it off from the top button
Yeah, the whole UI is pretty wonky. Iā€™d much rather have an extra color temp button on the bottom. Then the top can be brightness and off.
Then they need to anodize the battery cap threads so it can be transported while easily locked out.
Interested in a couple!
Now it says ā€œdiscontinue.ā€
interested could I get a code.
thank you
agreed that the UI is wonky. Iā€™d carry 2 with me, one in each cargo shorts side pocket and accidentally turned
on both of them. Glow in the dark undiesā€¦ Iā€™d prefer the top button to be the only button, click to power on/off, tap
to change modesā€¦ but canā€™t complain about the performance and the magnet worked well hanging upside down.
My two ordered T1s have arrived. So far, everything works as it should. The only thing I would complain a bit about is this foggy, uneven light pattern when you look at the T1. I expected the milky glas to shine in the same brightness allover the lamp. Instead I see different shades of brightness. The top area is significantly darker than the side area of the lamp, no matter how much you turn up the brightness.
