Got my T1 today as well. Figure I’ll give it to my son on his 11th birthday later in the month. The tint ramping is pretty dang cool, pick your poison as it were…
Got my order today, neat little thing it is. Good thing I ordered 4.
rec’ed my 2, all I can say is WOW. Not that I’d want my kids to lose more lanterns but I’ve been supplying them
with the 3xAA lanterns; they’re not worth the 3xAA Eneloops I put in them. And the Blitzwolfs, yea they’d be good night lights
I just got mine as well, Used it a little bit and now I have it charging. With the risk of sounding dumb :person_facepalming: I have a question, to turn off the light can you do it from the top metal switch or do you have to do it from the bottom (next to the tailcap) switch? I tried to turn it off from the top switch but it just kept changing color or brightness, maybe I just haven’t got the hang of it yet.
So, can someone tell me How do you turn it off using only the top switch? :student:
Thanks!
Unfortunately, it can only be switched off using the bottom button…
If you press and hold the bottom button to turn it off, it should memorize your previous color and brightness level.
I received my light yesterday and it seems to have some issues…
First is I can’t turn it off without totally removing the battery compartment cap (boy not having anodized threads for a lockout is annoying) but the bottom button doesn’t do anything. Seems like there’s a bad connection at the driver / button or a broken wire inbetween.
I was thinking I could spray paint the threads to try to make it so I could just crack the tail to shut it off. I like the light and definitely want to be able to use it… Does that sound like it’ll fix it make it usable?
Second (and it may be related) is that I can’t ramp brightness in the tint mixing mode. Have I just not figured out the UI yet or does ramping brightness in tint mode require that bottom button again (which wouldn’t be fixed by my proposed solution for shutting it off above)?
I really don’t want to try to open up a glued together plastic bodied light…
The bottom button is used only for red modes and off, everything else is done by the top touch-button
I would open a ticket and ask for a replacement, never had a problem with GB when I received a DOA, they always refunded me
Coupon is no longer working. “This coupon has reached its maximum limit.”
I found that out!
Such a shame you can’t turn it off from the top button
Yeah, the whole UI is pretty wonky. I’d much rather have an extra color temp button on the bottom. Then the top can be brightness and off.
Then they need to anodize the battery cap threads so it can be transported while easily locked out.
Interested in a couple!
Now it says “discontinue.”
interested could I get a code.
thank you
agreed that the UI is wonky. I’d carry 2 with me, one in each cargo shorts side pocket and accidentally turned
on both of them. Glow in the dark undies… I’d prefer the top button to be the only button, click to power on/off, tap
to change modes… but can’t complain about the performance and the magnet worked well hanging upside down.
My two ordered T1s have arrived. So far, everything works as it should. The only thing I would complain a bit about is this foggy, uneven light pattern when you look at the T1. I expected the milky glas to shine in the same brightness allover the lamp. Instead I see different shades of brightness. The top area is significantly darker than the side area of the lamp, no matter how much you turn up the brightness.
Got mine in the mail today and it worked fine for about 5 minutes .now it only works in one mode and won't go to warm white or adjust between CW and WW ...and of course it has to be stuck in CW ..of course that just makes sense . the upside is it turns off with just a click from the top button ..but sadly turns back on again on high instead of keeping the output memorized like it does if shut off using the bottom button :( I'm also guessing it's not really off and probably running a huge parasitic drain . Overall i like the build .It feels well made and the magnet works well with the light just sitting on the metal filing cabinet ..Aruggh .. I want to test the warm white tint... time to contact Gearbest.
