Iām just thinking he may want a light that has either a good choice modes or ramping. Iām not real sure shinning a light down a enclosed duct with a couple of thousand lumens is gonna make a good pick that isnāt flooded with light. Using ramping you could get the light amount just right for the camera. I do this very thing taking close up pics with a variable brightness control ring Sunwayman V10R modded with a high cri led. Most pics only need 5 to 20 lumens close in, I can dial the light in to produce the best pic as to what the camera needs. Iām just guessing 500 to 1000 lumens maybe the sweet spot.
Just my 2 cents
Thatās a good point. If the duct is clean, a lot of the flood area will probably bounce off the walls and continue along the tube. Throw will be artificially increased by the hall of mirrors effect. So something floody may be feasible in that case.
I was picturing a dirty old duct with gunk all over the sides, which would absorb the light instead of bouncing it along. Because the last duct I needed to look into was a clogged laundry exhaust. I needed something really throwy for that.
The area his trying to illuminate is only close to equal the area of a small bathroom. A 60 watt light bulb does pretty good there at around 500 lumens.
on the other hand moderator, you can adjust the camera settings to take the right exposure almost regardless of lumens in use. Even if 25,000 lumens were firing it upā¦ a 1/50,000th of a second shutter would adjust. Tit for tat, as it were.
So what we are getting to is the big question, are the HVAC tubes typically clean or quite filthy? I would think that even very dirty weāre only talking about 30ā away, a $3 zoomie can do that. So in the end a variable brightness as in ramping, and enough cell capacity to use the duration of the job at hand, be that a 15 minute inspection or a dayās worth of those.
Maybe the newer D4S with 26650 cell would be a better answer over all? Fully capable of the distance, the brightness level, and the duration of use? Next step up may be something like the SupFire M6 with 4 18650ās for capacity. (or a Q8 for that matter)
Another question comes to mind, would it be important to be able to highlight something in the tube at a distance, say if there were an obstruction on one side at 20ā away, would it be important to be able to point that out for the photo? Then a spot might come into play. So a zoomie may indeed come in handy with the ability to go from a broad flood to a tight zoom to cover whatever arises. Something like the Jaxman Z1 for example. It uses an 26650 cell for run time, yet can do flood or spot or in between.
Edit: I should also point out that the camera will have different lighting requirements the length of that tube, dependant on the quality of the sensor, the quality of the glass in the lens, and the use of f/stop and ISO ability. The focal point for the shot will determine, after all other things are considered, how much light is needed at that point. (or, more precisely, the amount of light reaching that point will determine the settings neededā¦ provided the equipment is up to the task)
I donāt have a way of measuring output, and I donāt have a clamp meter to measure current.
I built this D4 knowing that it wouldnāt be a powerhouse. Itās running ToyKeeperās AndĆŗril UI, which has a customizable ramp ceiling. Iāve set it to 50 levels below turbo, which visually appears to me as roughly half the brightness of turbo. Even so, Iāve been keeping it in muggle mode, which limits the highest output even more.
I admit that Iāve run the R9080 D4 in turbo a few times for just a couple of seconds.
My D9080s are from Clemenceās most recent group buy. Theyāre NVSL219BT-V1 sw45kD220L2R9080 according to the boxās label. Click to embiggen:
I also modded one of my D4s with 219BT-V1 sw45k-D220-L2-R9080.
The tint with the 10623 optic is beautiful. In my eyes itās perfect. :partying_face: Itās my daily driver now.
One easy thing with stock V2, to not worry about Amps and turbo is to use a low drain battery (GA, 35E etc). Of course it isnāt so bright, but doesnāt makes you nervous if you want to use turbo.
Some whitewall shots, 5200K WB. All D4s are 1x7135.
Great comparisons. The more recent batch of 5D XPL-HI in the flashlights I got from Intl is much more yellow than the older pure rosy 5D XP-L HI that I got from him.
Also that 219c 5000k looks wonderful, which Iām guessing is probably from an older batch because Hank said half a year ago that his current batch at the time had a lot of green in the tint.
I modded my D4 to sw40 9080ās, but it didnāt do it for me and I changed it back to 5D xp-g2ās. Usually I always like these emitters, probably the optic set the tint off a little???
Very happy with the 5dās Again, gonna keep it this way. Now off to find an other host for the sw40s
I also noted a tint shift with the quad TIR of my D4.
When I installed 4 LH351D 4000K 90CRI, I found them quite greenishā¦ but in other lights I love them.
Thank you guys for your suggestions and various considerations. The ducts are old drywall & cement made, very uneven dotted with cement irregular dark inside wall surface, somewhat dirty, with some pipes running inside the ducts, definitely not smooth bright aluminum ducts. Access to the flashlight is limited once inserted into the duct via a narrow hole made in the duct wall. That makes it more difficult to adjust flashlight to zoom on a particular spot along its length. A portable endoscope camera with a circle of mini lights around its glass is inserted into the duct in a plastic protection pipe to push it through the duct. So the cam adjustability is limited too. What would be the best flashlight choice for these conditions? I tried an ordinary $5 CN flashlight, and it illuminates the duct just around its mount point, but the remote light is all consumed by the duct walls, so useless. The purpose is to assess pipes condition running inside the ducts mounted along the duct side and bottom walls.
Hmm, that worries me a little. I tried 3xLH351D 5000K 80CRI and found it also looks greenish. I figured the 90CRI ones wouldnāt have that issue though.
Maybe Iām just not running it at a high enough power to get good tint. Djozz noted the LH351D tends to get a bit green at low power, and most of the time Iām using only the 1x7135 power channel on a triple or a quad. So itās 87 to 117 mA per emitter, and that might be low enough for the green effect. Not sure.
Most emitters are more white when running at higher power levelsā¦ but the range I care most about is under 150 lumens. And on a triple or quad, thatās only 40 or 50 lumens per emitter. So I guess I tend to select emitters for their tint at low levels like that. I should probably use single-emitter lights instead, but triples and quads seem more popular lately.
The LH351D 4000k 90CRI version is yellowish on the verge of green. It does get better at higher brightness but still not nice like the 219B 4000k. The two groupbuys for the LH351D used the T7 and T6 bin. If we can somehow get our hands on the T3 or T4 bin would be ideal for the FW3A.
I see green at low levels it seemsā¦ so it would be normal for this LEDs, and not due to optics then ?
I guess Iāll have to try the 3000K SST20 95CRI in my D4 when theyāll be thereā¦
My 219c 5000k is from December. It has some green from moon to 1x7135 (only if you see it in comparison with other white/rosy tints on a white wall) from around there and up to turbo is a nice white.
Just received my silver/white D4 directly from Hank. Took 17 days from day of order . My first Emisar and loving it. The more I use side switch lights the more I think they will be the only type I buy from now on , especially with ramping. The UI is perfect and the thermal step down works flawlessly. Being able to get momentary on is also a plus. Tonight I get to put it through itās paces if it would stop raining every single day. Emisars are actually more attractive than pictures do them credit. I see more in my future.
The HVAC pics are a tough situation. Needs to be small for insertion and control, yet needs to make enough light for a demanding job, while not getting hot or stepping down. Most of the lights that can produce enough light to do this will step down in short order, or are too large for the situation. So Iām thinking the D4, the new D4S, or the DQG Tiny 7 XP-G2 lights are probably more inline with this odd situation. The new D4S will have the large cell and some programability, the DQG might get too warm and at higher levels will step down, maybe too soon. The D4 at the necessary power levels will probably get too hot.
An Raysoon F13 modified triple with CUTE-3 also uses the 26650, can be fit with a nice heat sink, would offer output and run time with program options through firmware selection, but of course this would be a build and not a readily available light.
Mateminco has a triple X6 coming out, quite floody, makes around 3000 lumens, can run quite long in the 6th of 7 levels without getting too hot, might be a likely candidate as well. Run time would be more limited due to the smaller cell size (18650)
Sofirn C8F triple? Decent price, not too large, in the 3000 lumens vicinity. Tends to be more throwy than the Mateminco X6 at similar output levels, both use the 18650 cell.
Emisar D4S
Sofirn C8F
Mateminco X6 triple
Check those out Zamar and see what you think, none of them should be extremely pricey, all are worthy fairly high powered lights. The Mateminco might not be available just yetā¦
Thanks again. What battery makes & models do you recommend for these flashlights? Are they sold anywhere on cheap? Some 50mm diameter flashlights I seen require 4x18650 batteries. Are these any better for my purpose than 1x18650 flashlights above, and which models?
