Exactly as instructed, with the smallest ring that fits the Q8 head. Maukka measured 4716 FL1 lumens with his stock Q8 using 30Qs, so 3330 for yours seems rather low. That’s also a huge drop for 30 seconds; do you have the thermal throttling set really conservatively?
Last night I took apart my Q8, made sure everything was spotless, and resoldered the MCPCB leads on both ends. After putting it back together I got exactly the same result in the TA tube.
4300 lumens at turn on seems plausible. My measurements on the stock Q8 ranged from 4700 to 5200 depending on battery. At 30 seconds it depends on the thermal limit set in the config.
Bypass the springs, solder blob some Sony VTC5D’s charge them up to 4.25 and you’ll probably hit 10,000 lumen maybe more, or we’ll never hear from you again?
You slackers…… With my ‘stock’ Q8 I got 16,132.516 Lumens using my ’Bathroom Mirror & Fixture Bounce All Around Test’. :+1:
That’s BMFBAAT for short……
It goes liks this.
1. Place light sensor in a zip lock sandwich bag. This has 2 purposes…. to difuse light & hopefully waterproof the sensor in case it slips from it’s mounting position…
2. Open toilet lid… both lid & seat. Mount baggie enclosed light sensor on back wall of toilet basin right above the waterline.
3. Turn on Q8. Shine into BR Mirror at pre-calculated precise proper angle.
4. Light bounces into BR Sink on to Overhead light fixture.
5. From Light fixture back to sink, then up to mirror & over to tub.
6. Then back up to light fixture & into toilet basin
7. The light sensor, covered by a baggie; is waiting to record the lumen number of this highly recommended method.
I just had an Epiphany—-I recently had a new Modad system installed at my camp—upon looking at this diagram I realize i can use the unused upper half for a perfectly calibrated HIGH LUMEN measuring system—I’ve attached a diagram—Teacher this method seems much easier than yours—i just have to go in the front yard and remove a couple clean out covers
Wow, I stopped getting emails about replies to this thread for a few days and it blows up naturally. :person_facepalming:
I skimmed the last few pages of posts but am not going to bother to respond to all the posts as most things have been answered by others already.
I will start watching this thread again now that I know there are new posts.
KG, while I am happy to help you work on my sphere, what you have now is clearly no longer my sphere. I think it would be best to move it to it’s own thread if you want help dialing it in. There are many people on here (including myself) that are willing to help educate you if you are willing to learn.
Wiping contact points with alcohol really works miracles. Today I received my Mini GT. At first I kept measuring about 500 lumens with every battery I thought I got a dud. Then I wiped down the springs with alcohol and got 1,140 turn on lumens! This worked several times on the TC20 when turbo stopped working correctly.
Sorry my friend… pictures are a strict no - no. This method is such ’secret & refined double naught spy type stuff’…. I dare not share pictures or video at this time.
