I tried KiCAD within the last few months and did not really like it. I moved on to Eagle, and like it better but it’s not perfect either. If I had to pick between the two for the task I am doing (designing a round PCB for the BLF Ultimate Lantern) I would pick Eagle. Primarily because I could find no way to make a round trace in KiCAD, and Eagle has that capability. Both are lacking a 7135 model, and I had to fake the PIC model for the ATTiny85.
Below are images of the current state of affairs, hoping to move if forward a bit tonight:
Nah, there’s definitely a AMC7135 model for Eagle. In fact, there’s more than one because some people made them with custom size GND pads. I don’t know about PIC though. I haven’t tried PIC with Eagle.
Even if you don't go fully regulated buck and/or boost, why not a regulated MOSFET driver? No chance to blow up emitters this way, and no @#$% with regulation and lower efficiency because of high PWM frequency. PWM freq can be raised much higher if switching a proper MOSFET.
This is not mean to be judgmental at all. I believe we need and are ready for a new generation of drivers.
I’m not smart enough? Best answer I’ve got unfortunately. :person_facepalming:
I don’t know enough about electronics to design a good circuit, so I copy what other people have already made and just put it onto a different shape PCB for my own purpose. The AMC7135 is pretty well understood around here. We all know what it does. Plus, it’s cheap. :money_mouth_face:
Because the way you are (think, believe, etc) matters. I am responsible for my own beliefs, not of yours. Since this can be read by anyone there's nothing wrong with saying that, all is good.
Well, I found these two ways to convert stuff from Eagle to KiCAD.
The first is this set of conversion scripts. This is meant to convert a whole Eagle project to KiCAD. I don’t know if these scripts actually create new, separately accessible library parts or not. You can find the converter(s) on Github here.
The second thing I found was an online library conversion ‘service’ that can convert among many different formats, including Eagle to KiCAD. You upload the library in whatever format, then download it in whatever format. The website makes you register before letting you use the service. But, registration is free and the service is free as well. They also claim that you can use the service to keep up with your libraries and to share files with others, so it might be a repository of sorts. It is accessible here.
I have messed around a bit with both of these, but I haven’t gotten very far yet, so I can’t even tell you if it will work. I’ll try to remember to update here again once I get a chance to really dive into these.
Backstory on the PIC: the picture is of a MELD-X driver from tterev3. A while back, he said he doesn’t mind if people copy his board designs and/or build new ones based off his. He only cares to keep the PIC firmware to himself. So, I was planning to make a new driver board to fit in a specific light and never got around to it. Now, I’m trying to get started again, and I need the PIC footprint for the PCB.
No, I didn’t ask tterev3. I just decided to try KiCAD again a couple days ago, and I hadn’t got that far yet.
I originally was going to make one for TheOnlyDocc for his Wall-E light. but he was having trouble with other mods he was trying to make, and never did get me the measurements. (yet?) Now I have a light that I won from gchart’s giveaway here. It is a Brinyte B21 Complex and he did a review of it here but he said he thought it was a pre-production sample, so may not be exactly like the final one they eventually introduce to market. I have two MELD-X drivers from tterev3 so I can use one as a donor for a new driver if it is anything weird. I haven’t opened it yet to see the driver.
I haven’t used KiCAD but the PIC16F1575 is just a standard QFN-16 4x4 package that I’m sure exists in some standard libraries. If my Eagle files can be of any help let me know.
Thanks for the offer tterev3! Yeah, if you would give me the Eagle schematic I could take it from there. I was just trying to get started with KiCAD here but it seems KiCAD has too much learning curve still for me, especially since it lacks libraries for some of the common parts we use for drivers.
Here’s the board and schematic files. I think these will let you copy the microcontroller part without needing the whole library. If that doesn’t work let me know
