The Manker U22 flashlight is the latest flashlight from Manker, continuing the U21 model launched in spring 2016. Manker brings some improvements to the new flashlight. The Manker U22 uses the Cree XHP35 HI LED, which has two color temperatures: 5000 and 6500K. The flashlight has a maximum power of 1500 lumens, and at 65,000 cd, the illumination distance easily exceeds 500 meters. The flashlight reflector is one of the lustrous aluminum alloys, so the beam is concentrated and the halo around the spot reaches a maximum of 100 meters. The base of the base contains four heat sinks for optimal cooling, with control buttons between the heat sinks on one side and a charging plug on the other. The control buttons illuminate and we can turn on/off or change the steps and modes of the lantern through various push modes. During operation, the button will change color based on battery level.
The lantern charging plug is USB Type-C, and can be charged from different devices: 5V minimum 1Ah adapter, portable charger, computer, car adapter. Charging the battery from the flashlight is at 1.4Ah when using a 2Ah adapter. The battery with which the flashlight can work is a new one, its type being 21700, and the battery power reaches 4800mAh. Due to the high power, the torch has a very good autonomy on every stage: in turbo mode at 1,500 lumens, the torch will work for 4 linear minutes, after which it will continue to operate at 630 linear lumens over three hours. The dimensions of the Macker U22 are much lower than the older U21 version, hence the lower and lower beats of the new U22. The torch's weight is only 254gr with the 21700 battery.
The new Manker U22 is much easier to wear in hiking, guarding / searching, or used daily around the house. In addition to generous autonomy, the U22 delivers high power and high beating distance at an affordable price.
$5 discount and free shipping coupon code of GearVita: MANKU22
Coupon price: $57.95
Coupon time: Aug 9 - Aug 17
Product link: https://gearvita.com/manker-u22-led-flashlight-1500-lumens.html
Flashlight Interface:
● To turn on the flashlight, press the button on the head, the torch will start firefighters, press the button for 2 seconds to stop.
● To change the light steps, press the button briefly until you reach the desired level, the torch will start firefighting and after the end of the cycle the flashlight will return fireflies like: firefighters - step 1 - stage 2 - high gear - stage 2 - stage1 - fireflies.
● To use the torch at the last used stage, hold the button for 2 seconds - when the torch is off. To stop, press and hold for 2 seconds, and to return to the initial step, press the button for 2 seconds.
● For direct access to Turbo mode, press the button twice quickly when the torch is off, so do whatever you want to activate Turbo mode.
● To activate special modes, quickly press the power button twice to activate turbo mode, every press on the button will change the available modes: Strobe, SOS, Flicker, Pulse Button. After flashing the button, the torch will go on the fireball.
● To set the intensity of the firefighting mode (general mode - engineer mode), in this way the engineer can set the intensity of the firefighting step by choosing from the four available options. Turn off the flashlight and hold down the button until the button lights up and then press the four-way button quickly, go through the four available options and to memorize an intensity press the lantern button a long time.
Main Parameters:
● Emitter: CREE XHP35 HI (choice of Cool White or Neutral White)
● Maximum output: 1500 lumens
● With Type-C USB charging function
● Power by 1x Manker 4800mAh 21700 rechargeable battery (battery has Included)
● Maximum beam intensity: 65000cd
● Maximum beam distance: 509meters
● Working voltage: 2.8v - 4.35v (over discharge protection)
● Driver: Most efficiency constant current circuit
● Material: Aircraft-grade aluminum body
● Surface treatment: Premium type III hard-anodized anti-abrasive finish
● Lens: Toughened ultra-clear glass lens with anti-reflective coating
● Waterproof: IPX8 (2 meter under water)
● Impact resistance: 2meters
Brightness Levels and Runtime:
● Moonlight: 1-5lm / 960h
● Low: 90lm / 25h
● Medium1: 250lm / 8.5h
● High: 630lm / 4.2h
● Turbo: 1500-630lm / 3min-4h
● Strobe: 1500lm
Related products:
https://gearvita.com/klarus-xt11x-led-rechargeable-tactical-flashlight-3200-lumens.html
https://gearvita.com/wuben-a21-portable-led-flashlight-4200lumens.html
Below is the picture of U22 and the comparing picture of U21 and U22:
