How To Build a Flashlight With Perfect Modes (picture heavy)
Ahh - the good old P.O. - here we have a limit of around 15$ - above this value you get an additional 30$ in handling fee plus 25% VAT :-)
The BLF AA-Y4E worked fine with NiMH before I re-programmed it, so there must be another explanation I think ?
Oh, I smell Denmark here. Welcome, fellow countryman.
I think that the $ has risen so the limit is only $14 now
At least we are in the same "boat".
The NiMH matter could be an issue for Tido, perhaps initialization is wrong. Or there should be some form of charge pump to bring the voltage up.
Yes. Actually, that is exactly what I dreaded. When using Li-Ion, the driver is most likely in direct drive and not boosting. On NiMH it needs to boost, but the "on" periods are probably too short to allow the boosting circuitry to start up. Have you tried if it works with higher PWM levels?
Also, could you post a picture of the PCB's component side? Maybe there is no special driver chip and the ATtiny was used to switch the coil. In that case you're screwed when it comes to using NiMHs.
Nice - thank you - and "godaften til dig også" (sorry non-Danish forum members)...
The SKU S009742 from KaiDomain looks interesting - especially with the new XM-L arriving. I'd better place an order :-)
I could try make the BLF start in the lowest mode, and see if it will run with NiMH's again.
Btw: what is the PWM frequency when running the BLF-VLD firmware - I am very impressed with the flickerfree operation: I see no flicker whatsoever even in the lowest (1/255) mode
Tido: I think we cross-posted :-)
I'll grab my camera (and soldering iron) and upload some images in a minute...
I just tried making the driver have one mode only - 1/255 and 255/255 - but it still won't start on NiMH's :-(
Sure - here goes:
You should try the highest mode (255/255). This way there is a constant current draw from the LED and the boost circuitry should not be impaired by the output PWM.
If you used the fuse settings I posted yesterday, the chip is clocked at 4.8MHz. With phase corrected PWM this should result in ~9kHz PWM frequency. This gives me an idea, you could try setting the chip to 1.2MHz (9.6MHz and CKDIV8 fuse set), thereby reducing the PWM frequency. This would result in longer "on" phases, maybe long enough for the boost circuit to stabilize. But for this the driver needs to be recompiled and after flashing the chip might not be accessible any more with your programmer.
I use these parameters when flashing the chip - I took them from your post the other day:
avrdude -P /dev/tty.usbserial-A600aSmp -p t13 -b 19200 -c arduino -u -Uflash:w:BLF-VLD.hex:a -Ueeprom:w:BLF-VLD.eep:a -Ulfuse:w:0x79:m -Uhfuse:w:0xef:m
I am willing to try to lower the chip clock - could you give instructions on this ?
Should it fail, and my driver board becomes dead beyond repair - I will just put on a smile, wait for my AK-47/101 drivers to arrive and - most important - not blame you :-)
Hmm, the chip below the red wire is a candidate for a boost control circuit, but I can't really tell without knowing how it's connected to the other components.
One thing you could try is flashing the old program into the ATtiny to see if it will work again. This way we can be sure it's a problem with the software and not just a hardware defect. Of course we'll need a copy of the original driver software... sixty545, don't flash your BLF, we need to make a backup of its firmware first!
Well, it's getting late and need to get up early. We should continue with this tomorrow, maybe via IM or IRC.
Yep - I also need to get up early tomorrow - so lets call it the day.
Lets get a copy of the original firmware (from sixty545?) - it could be fun to see, if it will work again.
I guess the original fuse settings are also interesting - perhaps the original clock is set much lower ?
I won't, I have found another victim, my WF502-B with an AK-47 set to 3-level. I can understand that the fixed mode BLF-VLD2 has 3 levels, but which 3 of the 9 defined levels is it? Oh- I see it now, is it no. 3, 6 and 8 (MODE_LVL008, MODE_LVL064 and MODE_LVL255)?
I will do that. A problem is that today is my wedding anniversary, but I guess I can sneak out to dump the firmware if I have precise instructions on how to do it.
Yes - these are the modes used in the original BLF VLD as far as I know. I had to use some time, to understand how Tido sets up modes - but it is actually quite clever…
I hope Tido can help here, as I am not expert on avrdude and its many options :slight_smile:
sixty545, please try the following command to dump the firmware:
avrdude -pt13 -c usbasp -P com2 -u -Uflash:r:flash-dump.hex:i -Ueeprom:r:eeprom-dump.hex:i -Ulfuse:r:lfuse-dump.hex:i -Uhfuse:r:hfuse-dump.hex:i
This should create four files, one each for the program flash, eeprom, high fuse and low fuse.
OK, I can give it a try tomorrow evening. Then I need a way to pass the files to nkildal.
I just sent you a PM with instructions.
Btw: I just now spent 2 hours resoldering my SOIC clip - it turned out, that 5 of 8 connections had broken.
Some of the pins had pulled back yesterday - I guess I must have broken them in the process of pushing them out again - sigh :-|
I think the 6 pin ic is a PAM 2803 or similar ,DC DC converter which must start first to feed the atmel chip.
To start pin 4 must be in high state as in simples driver without modes.
I took another picture of the driver board, showing the 6-pin chip, but the number on it is not easy to see - it may look like CF80Q...
Is the same as in the C78 and Hugsby P31 , pam 2803, the last letters are year and month,
Two components was obstructing the clip. Had to unsolder them. Not an easy task for them old eyes.
But success!
4 files made:
flash-dump.hex
eeprom-dump.hex
hfuse-dump.hex
lfuse-dump.hex
Hope you can use them, nkildal.
The 6 pin circuit on my driver clearly reads: CFB0Q
! Edited dec.9:
The above dumps cannot be used because the chip prevent reading!
Hi sixty545
Thank you for the files - they have safely arrived.
If anyone is interested in the original files - they can be downloaded from here as a zip file.
I will now try to flash my blf driver board back to the original software and see what happens :-)
