The dimensions is 74.5mm (length) * 20.4mm (diameter) * 20.4mm (head diameter).
Thank you
Tank007 E10 flashlight is a powerful outdoor mini flashlight that can power up to 120 lumens. Mini of light weight and small size, convenient for outdoor activities, it is a very practical addition to any pocket. Head, tail and tail cap are made of 304# stainless steel, combined with the black color of aluminum body, the flashlight looks extraordinary.
Product Features:
● Mini flashlight of light weight and small size working with only 1xAAA battery.
● Head, tail and tail cap are made of 304# stainless steel, combined with the black color of aluminum body, the flashlight looks extraordinary.
● Stainless steel tactical head which can be used for glass breaking.
● End click switch, convenient and practical. The flashlight can stand on tail.
● Bio-direction pocket clip can work as penclip or capclip under different circumstances.
● Three lighting modes for use in different circumstances.
● Intelligent memory function.
● Constant current circuit chip for constant brightness.
Product link: https://gearvita.com/tank007-e10-outdoor-mini-flashlight-120-lumens.html
If you think that a flashlight over the size of palm is a burden for you, then this mini flashlight will be a great choice. It satisfies your general demands for flashlights with its small body. If you don't want to spend too much money on a flashlight, it just happens to meet your need. With the price of $24.88 at GearVita.com, it is really your helpful small assistant for outdoor activities.
Related products:
https://gearvita.com/tank007-ec01-mini-magnet-flashlight-400-lumens.html
https://gearvita.com/fenix-ld02-mini-led-flashlight-100-lumens.html
The Tank007 E18 flashlight is an ultra compact everyday carry torch which can deliver up to 180 lumens on the highest setting.
It can be powered by one CR123A lithium non-rechargeable battery, or one 16340/RCR123A rechargeable lithium-ion battery. Two brightness settings and strobe are available, which are cycled through using the simple twist switch head of the torch.
The tempered optical lens lens that sits in front of the Cree XP-G R5 LED combined with the orange peel aluminium reflector provides a beam range of up to 100 metres.
Weighing only 19 grams and measuring 65 mm in length, you won't even notice you've got this handy piece of kit in your pocket.
Main Parameters:
Luminous Flux: 180lm
Throw Beam: 100 meters
Lens: Tempering optical lens
Construction: Waterproof to IPX-8 standard
Impact Resistant: Anti-drop height of 1.5 meters
Battery Quantity: 1 x 16340 or 1 x CR123 battery
Input Voltage: 0.8V - 4.2V
Burn Time: High light for 0.8hours, low light for 2.5 hours
Product Features:
● Candle finger-sized, very convenient to carry on with a keychain, when you travel, outdoor, camping ect.
● Using aluminum material, it is non-slip, waterproof, and abrasion resistance.
● Powered by 1*CR123 or 1*16340 rechargeable battery.
● LED will give you stable and bright light, nonthermal radiation, safe and reliable.
● Anti-slip pattern on the light head, convenient to secure grip and switch mode.
● Head rotation switch, which is durable and easy to operate even with single hand.
● Six square light anti-roll body, it will not roll on flat surface.
● Capable of standing up securely on a flat surface to serve as a candle.
● Constant current circuit chip maintains constant brightness.
● Waterproof to IPX-8 standard, anti-drop height is 1.5 meters.
● Three modes of lighting can be applicable to your lighting requirements for different environments.
● Mode selection: rotate head repeatedly to select the mode needed. Then light memorizes the last mode which continued for at least 2 seconds. For example, when you switch the mode to low light, keep it for at least 2 seconds, and then restart the flashlight, you will get the low light again.
GearVita offers this compact flashlight for you: https://gearvita.com/tank007-e18-camping-flashlight-180-lumens.html
Related products:
Wuben E01 flashlight uses aluminum alloy material, it is non-slip, waterproof, and abrasion resistance. It utilizes Cree XPG3 LED, powered by AAA battery, with 3 output levels, maximum 100 lumens, all controlled by the tail switch. High, medium, low, SOS, four modes, so many brightness options are convenient for us. LED will give you stable and bright light, nonthermal radiation, safe and reliable. It is suitable for camping, fishing, hunting, hiking, searching, working.
Brightness Levels and Runtime:
High: 100lm ( 1h )
Med: 20lm ( 5h )
Low: 1lm ( 20h )
SOS: 20lm
Product Features:
● Hard anodizing hoursing
● Utilizes Cree XPG3 LED, lifespan of 100000h
● 100 lumens max output
● 40m max beam distance
● Powered by 1* AAA battery
● Intelligent hybric circuit
● 99% high transparent rate lens
● Precise vacuum plating reflector
● IP68 Water proof( 2m beneath water for 1 hour )
● 3 output levels
Wuben E01 is the first mini flashlight powered by 1* AAA battery among all Wuben flashlight, total length of 82.5mm, weights 29g with the included battery. Simple design and easy operation makes E01 a perfect EDC flashlight, you can check and purchase it at GearVita.com if you are interested in it: https://gearvita.com/wuben-e01-mini-portable-led-flashlight-100-lumens.html
Related products:
https://gearvita.com/xiaomi-minimalist-portable-flashlight.html
way too long for a 1xAAA!
wle
Tank007 PT12 flashlight is a high power tactical LED flashlight with high brightness and medium volume, suitable for military, police, seaqrching, outdoors, camping, riding, etc. Powered by high power Cree XM-L 2U2 LED with life time 100,000 hours, relatively longer burning time can meet you long time lighting need. With a specially desgned stainless steel attack point at the tail, you can broke glass and other objects to save you in emergency. Anti-incorrectly inserting battery design can protect the flashlight, even the battery is incorrectly input, the flashlight do not get hurt.
Main Parameters:
Light Source: Cree XM-L U2 LED
Battery Required: 1 x 18650 battery ( Not include )
Input Voltage: 3.0V - 4.2V
Run Time: Up to 10 Hours
Brightness: 800LM (max)
Beam Distance: 300m
Operating Modes: High / Low / Strobe
Burn Time: High - 1h 30min, Low - 10h
Impact Resistance: 1.5m
Waterproof: IPX-8, 1.5 meters underwater
Product Features:
● Made of durable aircraft-grade aluminum T6061.
● Premium Type III hard-anodized anti-abrasive finish.
● Steel optical glass.
● Relatively longer burning time can meet you long time lighting need.
● With a specially desgned attact point at the tail, users can broke glass and other objects to save themselves.
● Orange-peel reflector, high efficiency, perfect even spot.
● Scientific structure design, exqusite workmanship.
● Constant current circuit chip to maintain stable and continuous brightness.
● The circuit uses anti- incorrectly input battery so as to protect the flashlight.
● High power Cree XM-L 2U2 LED, with life time 100,000 hours.
This is really an interesting flashlight, right? If you are also interested in it, you can check the details at GearVita.com: https://gearvita.com/tank007-pt12-high-power-tactical-flashlight-800lm.html
Related products:
Tank007 UC17 flashlight is a stylish and compact rechargeable flashlight. Only with a 18650 battery achieving 800 lumens of brightness and a range of up to 300 meters, UC17 will meet your needs such as camping, riding, and searching etc. In addition, with 5 model of high med and low strobe SOS, it could suit for everyday lighting perfectly. It can also be used as a mobile power source to provide powerful lighting support for outdoor travel and emergency. With anti-slip texture and prevent overheating design, you will love with this exquisite fellow.
Main Parameters:
Emitters: 1* Cree XM-L2 LED
LED Lifespan: above 100,000 hours
Battery Type: 18650
Max Brightness: 800 lumens
Beam Distance: 200-300m
Max Runtime: 30h
Input Voltage: 3.0 - 4.5V
Impact Resistance: 1.5M
Mode: 5 modes (High - Med - Low - Strobe - SOS)
Waterproof: IPX-6
High: 800lm - 100% power ( 1.5 hours )
Med: 400lm - 50% power ( 4 hours )
Low: 200lm - 25% power ( 30 hours )
Product Features:
● Charging with indicator function, red is not full of electricity, green represents a full charge.
● Constant current circuit chip for constant brightness. The flashlights has memory function to memorize the last mode.
● Max 800 Lumens, can meet the requirement of high power lighting.
● The United States imported Cree new generation of LED lamp beads, energy saving, life of 100,000 hours, brightness of 800 lumens, battery life of up to 30 hours, meet your lighting needs.
● Constant current circuit chip which maintains constant brightness.
● Made of durable aircraft-grade aluminum T6061, hard-anodized anti-abrasive finish
● Head rotation switch, which is durable and easy to operate.
● 5 modes of lighting can be applicable to your lighting requirements for different environments.
● Powered by 1 x 18650 2600mAh rechargeable battery.
● IPX6 waterproof design, can satisfy daily waterproofing requirements.
● Intelligent memory gear position automatically remembers the gear position when it was last turned off.
● Body is light and compact, the distinctive head button design makes it easy for you to control with one hand.
Tank007 UC17 in its class is an ideal cost-effective USB charging flashlight with high quality on the market. Thanks to the practical features, it is a practical luminaire for outdoor activities and everyday use. GearVita offers it for you via this link: https://gearvita.com/tank007-uc17-usb-rechargeable-flashlight-800-lumens.html
Related products:
Tank007 E13 flashlight is a mini portable led keychain flashlight with pocket clip provided, weighs only 10g, very easy to carry everywhere, can be used as an emergency light. It is powered by 1*AAA battery, which is easily obtainable, but with 120 lumens brightness. It is switched on by simply revolving the head, with one mode design, easy to operate.
Tank007 E13 is well protected, resistance to falling and waterproofing are inherent characteristics. 1*AAA battery is enough to make it last more than 1 hour of lighting. Especially small, such as the usual small clips. If you go out or camp, it is very convenient to hang on the bag.
Main Parameters:
LED: Cree XP-E R3
Light Source: 3W LED
Power Source: 1*AAA battery
Power: 10W
LED Lifespan: above 50,000 hours
Max Brightness: 120 lumens
Beam Distance: 80m
Input Voltage: 0.8 - 3.7V
Output Level: one mode
Burn Time: high light - 0.6hours
Waterproof: IPX-8
Anti-drop Height: 1.5m
Product Features:
● Mini Portable
E13 is a very small flashlight, like keychain.
● Aluminum Material
● LED Source
● Small but Powerful
● Convenient for EDC
Keychain and clip can attach E13 to pocket, bag, belt, hat or anywhere you want.
● Simple Operation
● Wide Usage
It is suitable for camping, fishing, hunting, hiking, searching, working. Thanks to its much portable feature, it can be with you anywhere to work as an emergency light.
This mini keychain flashlight has a small body but contains great energy. You can go to GearVita to feel its charm: https://gearvita.com/tank007-e13-mini-portable-flashlight-120-lumen.html
Related products:
https://gearvita.com/olight-i1r-eos-led-keychain-flashlight-130-lumens-rechargeable.html
https://gearvita.com/nitecore-tini-rechargeable-led-keychain-flashlight-380-lumen.html
Tank007 PA01 flashlight is a mini portable flashlight with pocket clip provided, which has finger size, short and exquisite, easy to carry everywhere. It is powered by 1*AAA battery, which is easily obtainable, but with 90 lumens brightness. Professional and user-friendly design make you comfortable and convenience.
Main Parameters:
Emitters: OSRAM LED
Power Source: 1 x AAA battery
Max Brightness: 90 lumens
Throw Beam: 80m
Burn Time: High light - 0.8 hours; Med light - 3 hours; Low light - 15 hours
Output Level: one mode ( High) or three modes ( High - Med - Low )
Waterproof: IPX-8
Product Features:
● Tank007 PA01 is a portable mini penlight working with only 1 x AAA battery, with waterdrop shape knurling in the tube, natural and beautiful.
● Adopt the Hard-anodized to finished the body, which makes it hardly to be scratched or faded.
● One mode or three modes for your choice, constant current circuit chip for constant brightness.
● End clicky switch with feel comfortable.
● With a pocket clip, it be can be put in your pockets, which is very convenient to carry.
● Unique golden ring embedded in the connection between battery tube and the tail part, harmonious, graceful and royal.
● With diffusers specially designed, it can work as a camping lamp, signal stick or bracket light.
● Very brightness with a small size, a good choice for no matter outdoor or home use.
Carry the PA01, its beautiful design and powerful light will make you outstanding in the crowd. Of course the price on GearVita is as cheap as ever, only of $14.99: https://gearvita.com/tank007-pa01-pocket-led-flashlight-90lm.html
Related products:
I have copied the “quote” from above the OP, so technically is was not in previous post.
And there was no mentioning of using it as a caplamp in the post before this one.
But: how can we use it as a caplamp, when there is only one groove in the body: at the tail side.
Unless the body can be reversed, of course
The bio-direction clip makes the flashlight a caplamp or pen light, Tank007 official website is written like this.
I’ve read that. Question remains: is the body reversible? Because there is only ONE groove for the clip.
This clip is bidirectional, which means that the grooves at the head and tail are all available as clips, so that the body don't need to reverse. I think this sentence should mean this although I don't know if this is feasible.
The Fenix CL23 is the first multi-directional camping lantern from Fenix. It provides impressive power, with a max output of 300 lumens. This new camping lantern is powered by 3 AA batteries, however, in emergency situations it can be powered by 1 or 2 AA batteries. Featuring compact size and a light weight, the lantern not only delivers the needs of campers but also satisfies backpackers' requirements. The multi-directional design is great for both camping outside or for inside of your tent. With good-looking appearance, IP66 rated protection and multiple ways of wearing, the CL23 will make for a stylish and more enjoyable outdoor life.
Main Parameters:
Output Modes: 3+ brightness levels, red laser
Beam Diameter: Max 20 meters
Impact Resistant: 1 meters
Light Source: LED bulbs
Compatible Batteries: 3 x AA
Product Certifications: IP66
High : 300 Lumens/7.5 hours
Med : 150 Lumens/13 hours
Low : 40 Lumens/ 45 hours
Down-1 : 2 Lumens/350 hours
Down-2 : 25 Lumens/80 hours
Red Light : 1 Lumen/150 hours
Red Flash : 1 Lumen/300 hours
Product Features:
● Compact and fashionable, max 300 lumens
● Powered by 1, 2, or 3 AA batteries
● Multiple-direction lighting for camping and tent lighting
● 65.5 ft./20-meter beam diameter
● Dual lighting sources - white and red
● Reverse polarity protection to protect from improper battery insertion
● Top positioned tripod socket for effective light directional control and fastening
● One-switch control for easy and fast operation
● IP66 rated protection (dustproof and waterproof)
The CL23 is available in 2 colors: vibrant red and fresh green at GearVita.com. With it you will always be ready for adventure: https://gearvita.com/fenix-cl23-compact-camping-lantern-300-lumens.html
Related product:
https://gearvita.com/supfire-t1-waterproof-rechargeable-outdoor-camping-lamp.html
The Fenix LD05 V2.0 flashlight is a easy to use dual lighting source penlight with warm white light and UV lighting also. The all new Fenix LD05 V2.0 uses a 90 CRI CREE XQ-E HI LED and a 365nm UV LED. Operating the Fenix LD05 is simple, the stainless steel tail switch controls all three warm white light outputs and the UV light output. A single click turns the Fenix LD05 on, and half clicks allows you to increase the outputs. The Fenix LD05 V2.0 is powered by two AAA batteries which deliver an amazing 100 Lumens of output. This light is perfect for doctors and dentists as well as helps with medical inspections in low-light areas, the powerful UV light also provide easy detection of counterfeit currency.
Main Parameters:
LED Type: Cree XQ-E HI LED (90-CRI / 3000K warm white)
Battery Type: AAA
Switch Mode: High / Medium / Low
Max Lumens: 100
Lighting Distance: 50-100m
Max Beam Intensity: 730 cd
Beam Color: 3000K warm white / UV
Waterproof and Submersible: IP68 / underwater 2m
Impact Resistant: 1m
Max Run Time: 70h (Alkaline batteries)
High - 100 lumens ( Alkaline Battery - 1 hr 40min / Ni-MH Battery - 2 hr 10min )
Mid - 25 lumens ( Alkaline Battery - 7 hr 50min / Ni-MH Battery - 6 hr 40min )
Low - 5 lumens ( Alkaline Battery - 70 hr / Ni-MH Battery - 36 hr )
UV Light - 200mW ( Alkaline Battery - 9 hr / Ni-MH Battery - 7 hr )
Product Features:
● 90 CRI CREE XQ-E HI LED with a lifespan of 50,000 hours
● Fitted with 365nm/200mW UV light
● 100 lumen output of warm white light
● Powered by two AAA batteries
● Digitally regulated output maintains constant brightness
● Color temperature of 3000K
● Color rendering index of 90
● Tail switch for one-handed activation and output selection
● Made of durable high-strength and oxidation-resistance aluminum and stainless steel
● Soft smooth beam
● Premium type HAIII hard-anodized anti-abrasive finish
● Stainless steel pocket clip
● Optimal quality optical lens
● IP68 rated waterproof, can submerse to 2 meters/6.5ft for 30 minutes
The versatile portable penlight like Fenix LD05 V2.0 is essential in our daily lives. Get it from GearVita today, let it be a part of your life, you will find your life much more convenient than before: https://gearvita.com/fenix-ld05-v2-0-led-penlight-100-lumens-with-uv-lighting.html
Related product:
https://gearvita.com/manker-pl21-led-penlight-200-lumens.html
The Acebeam PT10 penlight is ideally meant for use by Law Enforcement professionals, mechanics, and as a general-use EDC, due to its small size and bright output. This handheld flashlight, though it measures just over five inches long, which is about the same as an average-sized pen, offers an incredible 360-lumen High mode. Compare that with other 2 x AAA penlights and you'll quickly see that the Acebeam PT10 is clearly the brightest of the bunch! This LED penlight is equipped with a Cree XPL-HD LED, which delivers the latest in illumination performance and efficacy. Over time, Cree has developed and optimized their lamps to deliver the most amount of lumen output from the smallest-sized lamp possible. The Acebeam PT10 runs on two AAA batteries, which power the LED penlight for approximately 48 minutes, when in High mode. If longterm use is your focus, you'll be happy to learn that this flashlight can run for 10 hours in Medium mode (30 lumens) and up to 36 hours in Low (3 lumens).
Main Parameters:
LED: CREE XP-L HD W2 high density LED with a lifespan of 50,000 hours
Max Output: 360 lumens ( 2*AAA NiMh or Alkaline battery )
Peak Beam Intensity: 1046cd
Max Beam: 65 meters
Compatible Batteries: 2 x AAA
Working Voltage: 0.9V - 3.0V
Impact Resistance:1.2 meters
Waterproof: IPX-8 standard
Mid: 30 lumens ( 10 hours )
Low: 3 lumens ( 36 hours )
High: 360 lumens ( 0.8 hours )
Product Features:
● Durable aircraft grade aluminum construction.
● Toughened ultra-clear glass lens with anti-reflective coating.
● Copper base plate for more efficient heat distribution.
● Orange-peel reflector broadens the beam throw.
● Tail switch on/off push button for one-handed operation.
There are three colors for options on GearVita - black, silver, and gold. With a small gift-wrapped package box, PT10 is an ideal gift for you to send your family, friends, customers, etc. if you are looking for a compact pen style light that can be used for first aid, other medical and EDC: https://gearvita.com/acebeam-pt10-led-penlight-360-lumens.html
Related products:
Acebeam M20 flashlight may not be the biggest, but it is a high-powered keychain flashlight and lives up to Acebeam's legacy of quality products. Featuring a CREE XPG3-S5 LED and powered by a single AAA battery, this diminutive dynamo can produce up to 150 Lumens of incredible light output. An intelligently designed and highly efficient printed circuit board improves the performance of the equipment and maximizes its operating time, automatically providing protection against damage caused by high temperatures. By twisting the light head, you can select middle, low and high three unique lighting modes rapidly that can adapt to indoor or outdoor use. With the included keychain mount the Acebeam M20 can be hooked to any set of keys or even clothing for a portable hands free carry, it is your ideal partner whenever and wherever you need light.
Main Parameters:
LED: CREE XPG3-S5
Working Voltage: 0.9 - 1.5V
Max Output: 150 lumens
Max Runtime: 25 hours
Peak Beam Intensity: 628cd
Peak Beam Distance: 50 meters (164 ft.)
IPX Rating: IPX-8 waterproof (2 meter submersible)
Impact Resistance: 1.2 meters (3.9 ft.)
High: 150 lumens ( 0.8 hours )
Medium: 30 lumens ( 4 hours )
Low: 2 lumens ( 25 hours )
Product Features:
● Use CREE XPG3-S5 LED light temperature of 6500K, maximum brightness of 150 lumens, maximum intensity of 628cd, wide beam of 50m, LED life of 50,000 hours.
● Crafted from durable, lightweight aircraft grade aluminum.
● Premium type III hard-anodized anti-abrasive finish is hard-rusted, heat-resistant.
● 2mm toughened ultra-clear glass lens with anti-reflective coating reduces glare, provides 98.3% light transmission evenly at all brightness levels.
● Special gold-plated contact system for maximum power impact strength of 1.2m.
● Waterproof to IPX-8 standard at 2 meter depth.
● Copper base plate for efficient heat management.
● Moderately texturing finished reflector disperses light for a smooth, even beam.
● High-performance circuit design, low power consumption, voltage 0.9 - 1.5V, use AAA alkaline batteries.
● The ability to stabilize the flashlight on a flat surface to fulfill the role of a candle.
A flashlight on your keychain can be negligible but until you suddenly need light in a dark room, on the side of the road, etc, you will thank its great role. Acebeam M20 is such a keychain flashlight that is inconspicuous but can play a huge role at a critical moment. It is available in three colors on GearVita, including black, brown, and silver. If you're looking for a daily use flashlight with powerful capabilities and a long service life, as well as the smallest possible size, it will be an invaluable companion for you: https://gearvita.com/acebeam-m20-led-flashlight-150-lumens.html
Related products:
https://gearvita.com/acebeam-uc15-keychain-light-1000-lumen.html
The Tank007 F2 flashlight is a great practical light with special feature of double LEDs for both white light luminating and UV light. There are one white high power 3W LED and one high power 1W UV LED in its head. The maximum white LED output is 160 lumens and the range is 130m and the UV LED operates at a wavelength of 365 nm. The white light is used for portable lighting and the UV light is used for fluorescence detecting, application mainly in banking, police, metallurgy, jewelery, antiques, etc.
The exception of the Tank007 F2, except for the use of 2x LEDs, is that it is focussed and very small dimensions. The luminaire features a simpler focusing (zoom optics), and with one finger in a second, you change the light beam scatter. There is an aspherical lens in the head. By shifting the head, the light cone can be concentrated to a small square to achieve an excellent long-lasting lighting to light far distance, or extend the light cone into a very wide, uniformly illuminated circle without focus, which is suitable for illuminating the wide space in the vicinity. Control of the lamp is secured by the rear switch. Using a hanging clip, you can hang the light on your pants pocket, the shirt pocket.
Main Parameters:
White Light:
- LED: high power 3W LED
- LED Lifespan: above 50,000 hours
- Max Brightness: 160 lumens
- Max Beam Distance: 130m
UV LED:
- Power: high power 1W UV LED
- Wavelength: 365nm
- LED Life: 10,000 hours
Power Source: 1 x AA alkaline or NI-MH battery
Burn Time: 0.7 hours
Modes: Two modes ( white light LED and UV LED )
Input Voltage: 0.8 - 3.0V
Lens: Glass convex lens
Waterproof: IPX-7
Product Features:
● Adjustable Focus
It can be focused and zoomed, concentrate light to light far distance and cover large space with flood light.
● Portable Design
Small size with metal pocket clip, easy to carry.
● Convenient Power Source
Powered by one ordinary 1.5V AA battery or NI-MH battery, which are easy to get.
● Tail Button Switch
Designed with the button switch on the tail, easy to operate making it have tactical feature.
● Wide Application
This flashlight has double LEDs, with both white light and UV light. Its UV light can be used but not limited to:
- Counterfeit and banknotes distinguishing
- Fluorescent agents in various clothes and commodities detection
- Fluorescent reflection of special materials detection
Thanks to white and purple double light source, it is multi-purpose, really practical. With it, some small problems in life can be readily solved, come to GearVita to get it now: https://gearvita.com/tank007-f2-double-led-flashlight-160-lumens.html
Related products:
Tank007 TC18 flashlight is a high power and brightness multi-functional rechargeable LED flashlight. It is powered by 3 AAA battery or 1 x 18650 rechargeable battery and features focusing, directly charging, and magnet and is designed and manufactured according to Chinese police flashlight standard, best for military, police, outdoor searching and rescuing, camping, vehicle and machines maintenance and repair. The flashlight is with a 350 lumen output and 400 meter range is focused. It has three flash and two flash modes, the battery can be charged directly in the lamp body. It also can be used as a backup power source with a charged battery.
Main Parameters:
LED: Cree XP-E2
LED Lifespan: Above 80,000 hours
Max Brightness: 350 lumens
Throw Beam: 300m
Output Level: 5 modes (High-Medium-Low-Strobe-SOS)
Power Source: 1*18650 Li-ion batteries or 3*AAA batteries
Waterproof: IPX-7
Anti Dropping Height: 1.5m
Product Features:
● Tank007 TC18 can concentrate light to throw long beam as well as light close in wide angle.
● There is a high power LED light in the middle surrounded by three red, green and blue different color lights, which can meet some special requirement.
● The equipped signal diffuser can turn the flashlight to a signal lamp easily.
● With the white diffuser, it can be used as a table lamp for repair, camping and so on.
● Thanks to the magnet in the tail that can be strongly absorbed to metal surface, it can easily be fixed when users need to repair vehicles, machines, elevator, etc..
● Attack head can be used for self-protection in emergency, which can easily break automotive glass.
● This flashlight is specially added fluorescent silicone ring so that is can be easily found in darkness.
● No need of removing battery for charging for it support directly charging and charging in the car.
● This TC18 is also a power bank which can charge mobile phones, cameras, and other products.
● With battery box, this flashlight can use three AAA batteries as power source.
● Five modes to adjust the lighting type can meet different lighting needs.
● IPX7 waterproof design, suitable for hunting, cycling, climbing, camping and other outdoor activities.
● It is super bright maximum 350 lumens and has strong power, the throw beam can be up to 300 meters and the light still not be reduced.
You went on a trip and you have a weak smartphone - no problem if you have the Tank007 TC18 that purchased from GearVita handy! Complete with a flashlight is an adapter and a USB cable, thanks to which you can recharge your gadget directly from the lithium battery of the flashlight.
Have you decided to have a dance party? Tank007 TC18 will be very useful, it's not just the presence of the strobe mode. In addition to the main LED, 3 additional color LEDs are installed in the flashlight - red, green and blue, which simulate light-emitting music in one of the flashlight modes.
If you also think it is a multi-functional and useful flashlight, you can check it here: https://gearvita.com/tank007-tc18-rechargeable-flashlight-350-lumens.html
Related products:
