Their springs are very unusual. Like none I have run across before. Here is a picture from one of their 21700 single emitter lights I have. It’s very thick and very stiff material. The one I have is not a FET driver but I would definitely bypass this spring on a FET light. Regardless of how good the electrical properties of the spring are i’m skeptical of the coating (if there even is one). Seems like it could tarnish and create resistance over time. All in all though I like a lot of things this brand is doing differently even if they have some room for improvement they aren’t just copying the typical designs.
I've heard/saw some inkling of the high readings, but I find it hard to dispute Rick and Rodney's initial calibrations based on many high end commercial ANSI/NEMA FL-1 tested flashlights. My PVC lightbox is a manxbuggy1 original, and we worked together on the calibration, and even using the same exact flashlights. I'll grant you 10% is well within the tolerance, but I rarely, if ever, get a reading higher that claimed, usually lower, again, on name brand supposed FL-1 tested modern lights. I'm still using the same meter and occasionally regression test it to my old lights and still seems on. I hope I've been in the ballpark because the Q8 rating is based on my readings, and I thought djozz's readings and mine were close at the time.
The LK cells do pretty darn well, though I think the VTC5D is the current 18650/26650 king, edged out by the 30T though. I'l like to see what the 25S does, available here: https://www.18650batterystore.com/18650-p/samsung-25s.htm. The old Samsung 20R used to be the hot cell, and was hoping for a 30R or 30S for a long time, but it never happened.
I agree this light does much lower than spec'd. Seems they, like many, just make the #'s up. In theory, doubling up the FET's should do better but I never heard of those FET's before, so could be low performers. Also fairly long 20 AWG for 3 low Vf LED's will be a bottleneck, but maybe those springs are the bigger bottleneck - same here, never saw springs like that before.
I think I recognize that reflector. I got one like it from either Fasttech or Kaidomain to use in a 3xSST40 build. It’s been slow going because I couldn’t find an MCPCB with the right spacing, and my first pass at using small Sinkpads soldered to a copper disc went awry just before I was ready to reflow on emitters.
How does the beam look?
I just received the NA40 SE Updated version today and it already failed :cry:
I popped in a NOT fully charged Shockli 26650 and took a measurement with my calibrated TA lumen sphere at 3,800 lumens at turbo 0s. It’s definitely brighter than the TC20 and equal to my D4s XP-L HI 5D.
The problem is the flashlight doesn’t turn off even when I hold the button. I had to unscrew the battery tube and screw it back in a few minutes later for it to turn off properly. I then took the battery out to charge and was planning to take a lumen reading with a fully charged battery. To my surprise the light stays in dim mode and doesn’t turn off. I took out the battery and reinserted a few times and noticed the spring on the usb charger driver scratched up the battery pretty badly. The spring itself is also crushed (spring has almost no resilience). Now I’m left with an unusable light. Very disappointing because the light looks great and the finishing is very high quality. It also has good potential for modding since you can swap out the driver and still retain usb charging. Sigh….
if I followed correctly you did report that to Neal too and he already sent you the replacement?
You helped me forwarded my request to Neal at first. I haven’t reported it to Neal directly.
Btw, which 26650 did you use with this?
Got my original NA40 updated with a piggyback'ed 17mm DEL driver running NarsilM - really nice now. Didn't take apart the switch but tied the red and green wires to the LED pin #3 and seems like I only got one working LED in there - seems to be RED but looks orange. In room light it appears only on one side of the switch but in the dark it's a definite orange and looks consistent throughout the switch - I like it .
It's a nice quality light all around - love the anodizing, SS bezel, square threads and separate charging circuit. At best I got about 17.5 amps out of it, 5950 @start, 4980 @30 secs (my lumens). Losing about 1000 lumens in 30 secs is excessive for sure. Not sure what's going on there - thinking the MCPCB mounting is not ideal. Maybe it's not tightly pressed down by the reflector, not sure.
The biggest issue I have is the weird battery tail (negative contact) setup. It's the oddest setup I've ever seen. It seems like a spring is just simply missing? stock LK's rattle and can't make contact. Typical magnets on the tail are too small in diameter -- totally weird stuff. Why??? Hope they fixed this up in the SE upgrade? I use solder blob top LK's with a magnet off centered on the tail - not ideal but no rattle and it basically works.
I stripped the stock driver to use as a contact board, epoxied the 17mm on top. Looks like the MCU is a ATTiny84, 14 pin surface mount, and some of the cap and resistor design closely matches the DEL driver designs. The 16 7135's are divided into banks, at least 3, maybe 4-5, not sure. Because the 84 has a ton of I/O pins, it makes it easy to do and you can optimize your mode sets to be full sets of 7135's at max output - no PWM's. I almost considered air-wiring in a ATTiny85 to use the existing 7135's and FET's, but would be a challenge for me.
Wish I knew the details of exactly what they changed in the SE model - for example "improved switch", well, what was improved? Could it be it stood out too far and was too stiff? Why was the reflector swapped and what's the advantages? I could speculate maybe it frees up space for the wiring - they had to epoxy up the exposed wires, so maybe there's some true interference going on there, maybe resulting in a poor MCPCB bonding to the shelf. Shame because it's a really nice light, great for modding. It's like a 26650 version of the C8F, but nice charging setup, better quality body, though the C8F isn't bad at all. The driver size of 32 mm is non-standard for us, sorry to say -- no one on BLF makes a 32 mm, or one that can be tailored to 32 mm as far as I know, but the piggyback works well.
Even with the issues, they are relatively minor. The original NA40 is a nice light for the money - I don't regret buying this one. The NA40SE hopefully improves on or eliminates these shortcomings.
I just tested all my 26650 batteries, all of them works fine with my original NA40.
Where did you buy this NarsilM driver?
Appearantly DEL built it for him. He made it himself based on Del’s design.
If you want to buy one ready to go you can see Lexels thread on them.
I just got the replacement tube from Neal. :+1: I think it was the springs. The springs on this thing can get crushed easily. Otherwise I really like this light. It has good mass for heat sinking. I measured 3,970 lumens at 1s using freshly charged shockli 26650 5500mah on my TA lumen tube with Maukka calibration.
I think the light output is being severely limited by the springs. They are probably phosphor bronze/BeCu short springs can carry quite a bit of current, especially if it’s really stiff, meaning it has very low contact resistance initially.
The problem however is that it takes into account if the light is new. Pure copper oxidizes very quickly, meaning contact resistance shoots up dramatically, and even faster with heat, which can great hot spots, and contact resistance goes up because of heat.
Using gold plated springs, or even better, dual springs, would help a ton in this regard.
You are probably right. The original springs that came with the NA40SE is very thick. The replacement is thinner with more loops, which I’m guessing is from the version 1 NA40.
Seems quite bright for 3 emitters. :+1:
My xhp70.2 (4 emitters) and FET driver with 2 x 26350 got 4100lm measured similarly. I bet using that single Shockli is way better than my 26350 cells.
This NA40 would be pretty sweet with a better UI like Tom E used. You retain the charging as well. That’s one advantage compared to building up a C8F 21700.
Did you happen to measure how many amps it’s pulling across the tail cap on turbo?
I don’t have the equipment to measure amps.
I’m waiting for my Nightwatch heavyweight XHP70 light to come from Enogear and see if the NA40 tube fits. That would add USB charging to that light.
If you ever want to:
For tail cap amp draws, all you need is a $30 UNI-T UT210E clamp meter. That's the model a lot of BLF folks use due to the big Group Buy back in 2016.
The process looks like this.
The UT210E can also measure voltage.
my NA40 pulls nearly 15A with fresh 26650 cell, so my wild guess is about 5000lumen
the light is also equipped with temprature control, because the turbo last much longer when using this light under water
For anyone who is waiting for this light, available stock is coming back on Taobao on 10th Oct 2000h, beijing time.
Anyway, more details and more pics can be found in the Taobao item’s review section, which number 410 reviews.
From my perspective a far more interesting question about this light is the power source. It is shown a single 26650 battery, and to deliver 6000 lumens, is going take 20 amps if not a little more, and there are not a lot 26650’s out there that can sustain 20 amps for a long period. The more output you want, such as from xhp50.2, the more power you need. 10,000 lumens is going to require 30+ amps, and if you thought 20 amps for a sustained period was difficult, 30 amps is much much worse, and in either case, the heat dissipation is going to be very big problem, very quickly. The Keeppower IMR 5200mah according to HKJ’s testing isn’t good for much more than 20 amps.
Yes, that’s probably the reason why folks aren’t getting much comfortably above 4000 lumens, much less hitting 6000 lumens.
A single cell gunning 6000 lumens at very high amps is going to place a lot of stress and emphasis not only on the 1 x 26650, but also on the springs, the cleanliness of contact points, all the components in the power path.
You cannot use the Keeperpower 26650s, they are like mid current cells only.
The best Keeperpower 26650 vs Liitokala INR26650 @ 20A “only”. I think we need to look at 30A (see subsequent posts).
And this is the VTC5A vs Liitokala INR 26650 @ 30A. Sony VTC5A wins
