I had originally planned for the lantern to use 3 emitters per channel then went to four per channel. If three emitter will work better i can re-design the LED star for a 3 + 3 LED config, but like you said above, there is not much data & tests on how the 351D reacts to higher currents as its such a new LED.
Hey, youâre the one who said boost drivers are ârightâ AND youâre the one who said boost drivers are âeasyâ. Why would we need a name change if doing it right is easy for you?
Since the lantern is based on the Q8, I am assuming that it can only accept button top batteries right? Or will this lantern be designed with a battery carrier?
I understand the tint shift issue now. Iâm unlikely to have a problem with tint shift unless itâs truly dire - CCT and CRI are the things I notice - but I agree that we should have the best quality light for everyone, especially since this is going to be a high CRI lantern (the feature that sold it to me).
If the 7135 driver with high frequency PWM is the favourite among the rest of you to achieve that, then itâs fine by me. High CRI and ramping from 3000K to 5000K are my must-haves; Iâm not going to lose any sleep over the odd bit of efficiency here or there.
I must admit, I made an assumption. Usually when people talk about boost or buck drivers, itâs implied that the driver will function in a manner which delivers constant current to the emitters. Itâs uncommon for people to talk about the benefits of boost/buck drivers and then use PWM. But the two concepts are indeed independent, and I shouldnât assume.
It could even be possible to fix the level of boost current firmly in place and then use only one pin per channel to do PWM, turning the boost converters on and off. Maybe even give the boost circuits a regulated voltage source which bypasses the MCU, so it could still measure the battery directly on its VCC pin. Iâm not a circuit designer so Iâm not sure if it would work, but it seems like it might. And then instead of burning off a volt as heat, it might have a smaller amount of wasted energy.
This isnât a thing I can make though. So for now Iâll go with the assumption that the driver will be one of the designs Lexel already posted. Iâm particularly looking forward to trying out the new flashing connector at the edge of the board.
A few pages back I was going to suggest a poll of people that have gotten a spot on the around 1000 devices spoken for. If that can be done so that each person signed up for the lamp would be notified, it would provide insight on those so far "committed". ID and units "ordered" would distribute the results for multi orders. The poll should provide a place to show how many the participant is intending to buy. The results would be scaled by buy quantity. A good list of possibilities in the poll would allow a sense of what the majority wants.I believe there are a lot of people waiting for these lanterns, but not interested in the technical details. They should be heard.
Personally I am on the side of highest efficiency (e.g., battery run time). No color light changing. No other functions like USB charging ports for cell phones or charging the lamp and poking extra holes in the shell. With stick in rubber covers that will eventually fall off and/or leak. I never really agreed with the non-use of the most efficient power system in the Q8 (I have 3). Nor was I particularly crazy about very complex operational requirements. Yes - you can sort of avoid them, but mis-stepping is also real easy. I think I actually suggested back then that the Q8 be used as the base rather than starting from scratch that the initial device was doing. But the old brain sometimes makes things up. But, for whatever reason, it went in the good direction we see now.
When this project started (I am one of the earlier people signing up for several of the lanterns), my expectation was:
A waterproof lantern
Robust construction
Simple operation
Maximum light duration with the most efficient power system possible (I do care if it goes dark 10% or 20% or more sooner than is necessary)
I think emergency light not beer party (although I see no reason why beer should not be involved)
Preferably with the ability to dim the lamp
No rubber plugged holes for external devices - no external devices or sources
A low intensity visible light in the power button
That was pretty much it. That defines a lantern in my mind. It is actually what I would still generally like.
So there are essentially my poll answers.
A quick other thought - has anyone looked at the effects of low ambient temperatures. I would think that things will get warm quickly, but will all of the pieces work to turn things on in low temperatures (e.g., 0 F). And by that I mean, it is 0 F outside, and the lamp has been sitting unused in the car/garage/front porch for two days.
Do you remember what number you were on the list? ( nobody should be removed unless it was accidental. ) message sbslider to get re-added if needed, as he is handling the interest list.
Indeed the original V1 started out to be a simple lantern with 4 modes & long run-times, and good light tint, but over time it got developed into a more versatile design. Once we get the current V2 into production, we may work on a simpler, lower cost basic version of the same lantern for those who need just a simple, reliable off-grid light that will run for days with no bells & whistles for those seeking a âbase modelâ so to speak.
Itâs weird because there were more people? Maybe people backed out? I was 928, lol. So it looks like itâs an improvement? Add me back please
Looks like maybe people took things too serious. Iâm not expecting the PERFECT lantern, lol. Just an improvement of what is out there. From what Iâve read Iâm pretty excited. Beside, the âultimateâ lantern wonât be that way for long. Every light eventually gets dethroned. The lumen race, size race, etc. Nobody holds it longâŚ
