(prototype) the GT Mini
1637 posts / 0 new
nkresho
nkresho's picture
Last seen: 5 hours 59 min ago
Here’s my formula reference:
Lux to candela calculation with distance in feet
The luminous intensity Iv in candela (cd) is equal to 0.09290304 times the illuminance Ev in lux (lx),
times the square distance from the light source d2 in square feet (ft2):
Iv(cd) = 0.09290304 × Ev(lx) × (d(ft))2
Source is here: https://www.rapidtables.com/calc/light/lux-to-candela-calculator.html
nkresho
nkresho's picture
JasonWW wrote:
I wish I could see your pictures, but they are not showing up. Your sphere sounds a lot like the ones from Josh K. Is that what you have or is it just similar to it?
Keep in mind that the Catapult V6 uses an xhp35 Hi which is a bigger LED than xpl Hi.
Sorry, hosted to imgur, since photobucket and imageshack are garbage nowadays.
My sphere is a semi-copy of the “match sphere” Started with a ~17” bouncy ball, paper mache’d it ovfer and over for a few weeks, then did a few layers of fiberglass for strength. Cut it open, sanded the inside and painted it with BaSO4. Two baffles using pingpong balls, also BaSO4 coated, were added. One to catch direct light between the source and the sensor, and a second to catch the primary reflection directly opposed to the source. It uses an interchangeable light plate similar to the newer TA tube design, so each plate can be the right size for the light and I can swap them easily. They are also BaSO4 coated. Sphere is also calibrated with Maukka lights and have a variable multiplier correlated to color temp. Warmer lights get a slightly lower multi, due to how my DrMeter reads.
JasonWW
JasonWW's picture
Last seen: 13 min 48 sec ago
I think you are making your calculations way more complicated than necessary. I would just use a simpler method such as 10 meters. There’s no need to reinvent the wheel.
Click this to go to signature links.
nkresho
nkresho's picture
It’s all in a spreadsheet. I just plug in the lux reading and it does it by itself.
I work in excel all day long at work. It’s only complicated once.
But, if it’s not accurate (the math involved), I am happy to change it up.
JasonWW
JasonWW's picture
Very nice unit. Thumbs Up
nkresho
nkresho's picture
Thanks. She’s kinda ugly, but does the job well as far as I am concerned. Lumpy like a big black meatball on the outside. Was so sick of paper mache-ing that I didn’t really sand the outside to a body shop quality finish like I originally planned. Business end (inside) is baby-butt smooth.
JasonWW
JasonWW's picture
Newlumen wrote:
Mine thrunite v6 measurement are similiar to nkresho. If that is true, mini gt cw have more lumen than nw .. i was told mini gt cw led are high bin. anyone can verify ?
I can’t understand what your saying here. Are you saying that the Mini GT cool white has more lumen than the Mini GT neutral white?
Where does the Catapult V6 fit in?
DB Custom
DB Custom's picture
Last seen: 3 hours 10 min ago
Jason, I think he’s saying that he gets similar readings as nkresho on the Catapult as a reference to accuracy, then says his mini gt with cw has more lumens than the nw which it should. Given the same power bin a warmer tint will always read lower output.
Nice work nkresho, the complication is that you are using feet instead of simply staying with meters as per the industry standard. Aside from that the calculations are the same. I really don’t see any need to convert with that 0.09 number, as distance is distance regardless what you call it. But then, what do I know? (no answer required, I get it…)
<— zip experience with spreadsheets and/or excel. Wink
Newlumen
Newlumen's picture
Last seen: 1 month 1 week ago
Yes .. I measured my v6 with shockli.
thrunite catapult v6. 2050 turn on. 1970 30 sec
Blf gt mini 1390 turn on. 1300 30 seconds.
LloydV
Last seen: 2 months 4 weeks ago
received mine (from the group buy) today!
something to fiddle with when it gets dark…
mortuus
mortuus's picture
Last seen: 40 min 14 sec ago
is your gt cw or?
...where Frugal meets with Flashlight!
joechina
Last seen: 3 days 9 hours ago
JasonWW wrote:
Newlumen wrote:
I do not know how to measured amp draws nor have a device to do it.
This is very easy to do. Most folks on the forum prefer using the Uni-T UT210E meter. There was a group buy as well as coupons a while back. It’s usually around 30 bucks. You can take off a lights tail cap and connect the battery with a loop of wire to the battery tube. Then clamp the meter to the wire. The light works normally and you can measure the amperage. This is how you would estimate output if you didn’t have an integrating sphere.
I don’t know who posted this to make tail cap measurements one handed.
Delta_V
Last seen: 3 days 10 hours ago
So I’m probably going to be the last person from the pre-sale to receive their light…..
Quote:
August 29, 2018, 5:08 am
Departed USPS Regional Facility
QUEENS NY DISTRIBUTION CENTER
Your item departed our USPS facility in QUEENS NY DISTRIBUTION CENTER on August 29, 2018 at 5:08 am. The item is currently in transit to the destination.
August 29, 2018, 1:11 am
Arrived at USPS Regional Facility
August 28, 2018, 12:39 pm
Inbound Out of Customs
Inbound Into Customs
August 22, 2018, 1:55 pm
Processed Through Facility
ISC NEW YORK NY(USPS)
Origin Post is Preparing Shipment
August 3, 2018, 6:27 am
GUANGZHOU EMSCHINA
August 2, 2018, 4:51 pm
Acceptance
CHINA
Had an ETA of Monday the 27th, and then when Monday came and went, it suddenly changed to stuck in customs. And all of that after the 3 week delay in China.
Brainsick67
Brainsick67's picture
Last seen: 3 months 2 days ago
GUANGZHOU EMSCHINA
Acceptance
CHINA
Well that blows..sorry man…hope it comes soon.
I'm ThatCrazyFlashaholic 67
Brainsick67
Does anybody elses make a ticking sound?
teacher
teacher's picture
I have not noticed it on mine.
@Delta_V….. Darn… you have had worse luck of any of us it seems. Facepalm
Hopefully it will get there soon.
Brainsick67
Hmmmm…prob cant hear it outside..but it sometimes does it..then like 3 sec later drops output from turbo.
Newlumen
Newlumen's picture
is your gt cw or?
Yes it is cw.
d_t_a
Last seen: 10 hours 9 min ago
!{width:80%}http://abload.de/img/dmmclampmeterclamp28396ina.jpg!
That looks quite similar to the one shown by djozz in this video (at around 03:40 minutes mark)?
lexvegas
What Anduril setup is good to flash on the GT mini? D1S? GT?
teacher
teacher's picture
Less than 3 days and the lighted switch on my Mini GT quit working. Facepalm
It got dim first, then flickered from dim to bright for a while; then died. Dead as a door nail…… Sad
Anyone else have this problem??
What is the proper course of action to resolve this??
DB Custom
DB Custom's picture
Give it a Cat scan…
Brainsick67
It got dim first, then flickered from dim to bright for a while; then died. Dead as a door nail…… :(Sorry man..mine still works..but when i take the head off i hear a rattle.
M4D M4X
M4D M4X's picture
Last seen: 49 min 43 sec ago
if you bought from Neal please write him a mail:
CS@m4dm4x.com
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
teacher
teacher's picture
CS@m4dm4x.com
I bought it in the Group Buy, so I’m thinking that was from Neal. Thanks Martin…… Thumbs Up
JasonWW
JasonWW's picture
Sounds odd. That led is mounted to the driver, so it should be getting real good connections unlike the seperate switch on the early Q8’s.
Normally I would say pop the driver out and touch up the solder contacts on each side of the LED, but the glued bezel makes that pretty hard to do.
Since it was flickering, I guess that rules out that it accidentally got turned off in the UI. I remember that happened to some people on a different light and they reset the firmware back to default and it started working again. That’s a very easy thing you can try just for the heck of it.
lexvegas
My bezel was barely glued. I didn’t realize it wasn’t just tight until I looked at the threads.
teacher
teacher's picture
You hear a rattle in the head if you shake it??? . Question
That don’t sound promising…… Sad
teacher
teacher's picture
Thumbs Up … Yep, I guess “odd” is one way to describe it. Sad
And I agree, it “should” be solid as a rock the way it is mounted…. But something ain’t right, cause it don’t work.
Yep I checked, and my bezel is glued tight as a drum. Facepalm
Situations like this, yet another reason I hate glue….. Wink
I had also tried the reset…. but no joy. Sad
Oh well… stuff happens. I’ll wait to see what Neal has to say. Smile
Brainsick67
Yes..but whwn i press Button down its quiet..and when i put batt in its quiet..odd..
