What did you mod today?
8710 posts / 0 new
goshdogit
goshdogit's picture
Last seen: 5 hours 47 min ago
Lightbringer wrote:
The one with the splootch of white paint? That’d be pin 1. Bottom-right would be pin 4.
That’s the ATtiny85. I dot them with a silver Sharpie to help me align my SOIC clip.
To clarify, I thought it was nearly universal that ‘dimple = pin 1.’
I was surprised to see the Infineon FET not adhere to that.
I did some reading and it appears that it isn’t a hard rule. Some chips don’t even put pin 1 in a corner! Silly
joechina
Last seen: 6 days 5 hours ago
The rule is: Look it up in the data sheet.
A QFP like the Altera has often a dot in middle.
DB Custom
DB Custom's picture
Last seen: 1 min 5 sec ago
That wire to the signal pin of the MOSFET is not connected correctly, looks like. The signal pin should be pin 5 (6?) from theMCU. Hence, you only have one mode….
Move that right hand side of the wire up to the (right) end of the 470 resistor and your light should function normally. Wink
Edit: The three legs on the left , on the MOSFET, are all ground pins. The right hand pin is the signal pin coming from leg 6 of the MCU. You have the signal pin grounded, or powered on a positive trace, but not connected to the MCU for mode changes.
Cereal_killer
Cereal_killer's picture
Last seen: 1 month 4 weeks ago
Dale, looks to me like the wire is correct. If you look the R4 (470 ohm) is the gate resistor, you can follow the trace from pin 6, the 10k resistor @ R3 is a pull down. His wire replaces the bad trace from the R3/R4 junction to the gate pin on the FET, hooking to either where he has or the right side of R4 would be the same thing.
goshdogit
goshdogit's picture
Yes, I measured continuity between the right sides of R3 and R4, but that was after I destroyed the trace. Big Smile
Mark M
Mark M's picture
Last seen: 2 days 9 hours ago
I am pretty sure that diode is part of the voltage divider circuit checking the battery voltage level. Since you report that the microprocessor is still working, it is a good bet that you either fried input pin 7 or there or there is voltage leaking in the divider circuit and it is measuring higher than the 1.1v that the microprocessor can read on that input pin not allowing ADC to take place. I am not sure how the firmware responds to not being able to check the battery voltage, but it probably is not good. Measure the voltage to the input pin on the divider circuit and if it is higher than 1.2v check the diode.
goshdogit
goshdogit's picture
Thanks, Mark. I had forgotten about your previous post about the diode.
As I mentioned, I’m a complete beginner with drivers, and electronics in general.
I measured pin 7 of the ATtiny85 as you suggested and got 0.16V with the LED connected and lit. I measured the other pins as well, in case that could offer a clue.
ATtiny85 pin voltages with LED lit, cell at 4.0V, switch removed from circuit:
pin 1, 3.65V
pin 2, 3.73
pin 3, 0.18
pin 4, 0
pin 5, 0
pin 6, 0
pin 7, 0.16
pin 8, 3.85
I ordered a replacement driver from Hank, but I’m more than willing to continue troubleshooting this one if y’all keep making suggestions! Smile
Mark M
Mark M's picture
Measure pin 7 with your multimeter ground on pin 4. Also measure both sides of the diode using pin 4 as your ground reference.
goshdogit
goshdogit's picture
That yields 0V with the emitter connected, and 0.40V with it disconnected.
The diode reads 3.96V on the left, and 3.85V on the right with the emitter connected. Left 4.03V and right 3.92V with the LED disconnected.
goshdogit
goshdogit's picture
Yes, my DMM has a diode test mode.
I removed the diode from the board and it reads OL in one direction and 0.22V with the leads reversed.
Mark M
Mark M's picture
I have nothing then, as it is testing fine. Do these driver not utilize pin 7 for ADC low voltage protection? Anyone with more knowledge want to chime in?
goshdogit
goshdogit's picture
I appreciate your help! Thumbs Up I enjoy learning and troubleshooting.
Mark M
Mark M's picture
You could do some continuity and resistance testing and see if all the resistors are intact. I know you said you did some testing, I am just not sure if you tested those.
DB Custom
DB Custom's picture
Modified my new Emisar D4S with Samsung LH351D 5000k 80CRI emitters and 18 ga leads. With a new LG HG6 20650 freshly charged it makes 5920.2 lumens. Big Smile
Cereal_killer
Put an LH351D 5000K in an V11R but most of my hobby time today was spent making this thing.
@DavidEF knows what it’s for!
MRsDNF
MRsDNF's picture
Last seen: 8 hours 40 sec ago
Looks like a reflector in an optic.
eas
eas's picture
Last seen: 1 month 2 days ago
Looks like The Terminator.
g_damian
g_damian's picture
Last seen: 5 hours 41 min ago
Today I put together:
Very nice, floody beam pattern, without any visible tint shifts. On the highest mode after 5 minutes flashlight body is warm, but not too hot to hold.
The tricky part during the build – centering ring goes flat side towards the shelf, included oring (in the set from kiriba-ru) goes under the lens, stock oring goes above the lens, under the bezel.
Album with pictures
Left: stock D4, 219C 5000K, Carclo 10622 (~350 mA); right: M2, Optisolis 4000K, Carclo 10623 (~450 mA):
djozz
djozz's picture
Last seen: 8 min 40 sec ago
Modded my mini GT with a dedomed XP-G2 S4 2B.
My mini GT was in pieces. It started with a severely unresponsive switch, and Neal asked me to find out where the problem was. So I opened the (unglued) bezel and because the centerpiece was so tight in the reflector opening, the unscrewing of the bezel twisted the led from its solder pad. So I had the mini GT in pieces with two problems now. I ordered a batch of new switches from aliexpress, which will be a separate project, but in the meantime I tried a dedomed XP-G2 S4 2B in it, recovered from a Emisar D4 in which I swapped the leds for warm white ones for a friend. The XP-G2’s seems the good old stuff. I reflowed one on the miniGT board and made a complete mess of the hot dedome (I started it too hot) lots of silicone left on top of the phosfor. So I heated the board up again, took it from the hotplate and started rubbing off the silicon from the phosfor with a wooden toothpick, trying to stay clear of the bond wires (hail my quality stereo microscope). Got most of it off with rubbing and blowing, but have some doubts if remains will shorten the lifetime of the led. Anyway, the led lives and worked surprisingly well in the miniGT, a perfect beam and 229 kcd on a 30Q at 30 seconds. Just the switch is still broken, it did not fix itself by disassembling the driver Sad .You can see in above picture that the centerpiece tries to shear off the led again, but perhaps my reflows are stronger than Lumintop’s. Wink
The_Driver
The_Driver's picture
Last seen: 1 hour 42 min ago
Nice, though at First I was hoping that you put it into a full size GT. Wink
djozz
djozz's picture
That would have been a centering hell Sick
(edited above post: forgot the calibration error of my luxmeter, corrected the throw to 229 kcd)
The_Driver
Definitely, at least few hours.
LichtAn
My USBasp arrived today, so I decided to take my Emisar D1 apart. Worked like a charm. Stupid thing is I’m still waiting for my SOIC8 clip. So I’ll probably order one from Amazon with evening express, cause I caaan’t waaiiiit now. Big Smile
CRX
CRX's picture
Last seen: 2 min 17 sec ago
Swib
Last seen: 2 days 5 hours ago
That Meteor looks awesome,, ah who am I kidding, they all look awesome. Silly
If you don’t like what it looks like on the wall, take it outside.
djozz
djozz's picture
Today I wrapped 3 30Q’s from NKON with clear wrap (also from NKON), the first time I used the hot air thing for anything, it went easy Smile
As you can see they are going to live in the ROT66, with the wraps it is a very snug fit, no rattling (was not a problem anyway).
DB Custom
DB Custom's picture
Always a good idea to number the cells and date them, so you can keep track of the characteristics and see if some rotation helps keep em balanced. I also like to write the IR on them from the first charge to be able to see if they are degrading over time and hard use. Wink
contactcr
Last seen: 8 hours 1 min ago
Do you guys typically wrap over the top of the existing wrap or remove and re-wrap?
djozz
djozz's picture
Good idea, should have done that before the wrapping. Next time I will think of that Smile
DB Custom
DB Custom's picture
I usually leave the factory wrap on. Almost always fits.
But then, I don’t exactly re-wrap… I cover the writing (mine) with a piece of 2” wide heavy duty packing tape and call it good. Usually works… Wink
