*BLF LT1 Lantern Project) (updated Nov,17,2020)
I’m really hoping these are available during this seasons fall/early winter camping season! Summer camping is a no-go here. Too humid. Good luck sleeping in 85+ weather with 98% RH.
so finally added thermal viases, 1A and 1W is pretty much fine as it was, but if people want to go higher they need more cooling on the MOSFETs
also rearranged the common ground for the OPAs and MCU
That’s a nice looking driver board. Thanks for your work, Lexel. I hope your hand is healing nicely.
Looking good! Any thoughts or ideas on what the maximum “factory” amp draw on high is set? assuming it will depend on the sense-resistor ohm value? Also the button LED still has ability to change or be programmed from TK’s UI?
Oh look, another Wagon.
Please put me down for 2.
Thanks!
If “simple” version would be I am in. Simple , efficient, durable. That is I really need, no powerbank, no color change and so on.
The original concept for this project was just that. single color, 4 modes, basic built in 1 am charging, (as i built the V1 of the first lantern.
I have to agree on this. Especially if it falls under the 39$ category.
4000k, over 90CRI, no color change, no need of powerbank. Just plain eyecandy lighting with longish runtime. One moonlight, one superlow, one low, one medium, one high. Nothing more, nothing less.
Preferably in silver color so scratches won’t show up and Nichia Optisolis leds with R9 over 90, and CRI over 95. which is a led that we apparently forgot about. LED test / review - Nichia Optisolis 3000 / 5000 K - ultra high light quality, even with high performance in mid-power class
YOU need 4000K.
I want 3000K.
The next one hates WW and opt for 5000K.
Sofirn will sell probably only one lamp without tint ramping from the three above.
It makes a lot of sense to have tint ramping.
If you want a cheap one (with a few flaws) you can search BLF for the Zanflare T1.
Maukka did a short test here: Ended - #477 by maukka
T1 is excellent, but it does not have 95+ CRI. And a LED swap is notoriously difficult.
Otherwise it would be extremely useful.
It can be 3000K or 4000K, or 5000K. It does not make a difference as long as the CRI is above 95 and R9 is above 90. Try it, you will see.
And I like this. I don’t need even charger, but IPx8
I can reflow leds easily. So I like 4000K, but can agree with any CCT.
T1 is not simple , not efficient, and not durable. I already have butch of such lamps.
It is worth investigate interest to simple version. And may be launch it after main project. This allows not to split the efforts, and second version would be born much faster.
The beauty of this UI is that you can have those modes, and I can have ramping. 3000K is mandatory for a lantern, and with temp changing we can have that and 5000K, and everything in between.
Yes, exactly. Especially since it’s pretty much already implemented.
That’s why the temp ramping is so wonderful, no need for LED swaps (unless you’re wrong and prefer cool white, lol).
I still think that LED swaps will be made even on the Full version, because the Samsung LEDs are inferior to Nichia Optisolis.
That’s fine, but it’s not needed for most since a wide range of temps are covered. Those with the ability can, and those that can’t still have a good range. With the ramping, even with swapping the LED’s you get a more versatile light.
The Nichia E21A is the better choice. It has a similar CRI (R9080), a tint under the BBL or on it, is available with every conceiveable CCT (2000K-6500K) and is more powerful compared to the Optoslis (less LEDs required). Here are Maukkas tests. This would require the use of a pcb with a special insulation material that has a low thermal resistance like Clemence and led4power use (should not be a problem cost wise since we need to get a pcb made anyhow). It would have the added benefit that we can put the FET onto this pcb to improve its heatsinking substantially (like led4power does). In my eyes this is the most elegant design.
As djozz has already mentioned tint is more important than ever higher cri ratings. The E21 R9080 LEDs offer a great tint.
yup the hard truth, tint > CRI
CRI9080 (CRI90, R9 over 80) and a tint below bbl is a lot better than CRI9050 and over bbl.
Optisolis has 9090 and near bbl, which is also amazingly excellent.
The Optisolis’ lower output / lower max amps can be fixed by using more of them. Spreading the emitting surface is not a problem for a lantern….quite the opposite in fact.
That said, I’m not voting for any emitter change, I’m fine with LH351* as well as E21 / Optisolis.
You can’t really see the difference between R9080 and R9090. Thats a tiny difference.
Also, the 5000K Optisolis that Maukka tested was above the BBL. So even these aren’t perfect.
Yes, but if we don’t use a boost driver we would have to put all those LEDs in parallel. Since they all have slightly different Vfs they would all be driven at different currents. With so many LEDs in parallel the lifetime of some of them might be reduced.
Good point.
