I have to agree on this. Especially if it falls under the 39$ category.
4000k, over 90CRI, no color change, no need of powerbank. Just plain eyecandy lighting with longish runtime. One moonlight, one superlow, one low, one medium, one high. Nothing more, nothing less.
And I like this. I don’t need even charger, but IPx8
I can reflow leds easily. So I like 4000K, but can agree with any CCT.
T1 is not simple , not efficient, and not durable. I already have butch of such lamps.
It is worth investigate interest to simple version. And may be launch it after main project. This allows not to split the efforts, and second version would be born much faster.
The beauty of this UI is that you can have those modes, and I can have ramping. 3000K is mandatory for a lantern, and with temp changing we can have that and 5000K, and everything in between.
Yes, exactly. Especially since it’s pretty much already implemented.
That’s why the temp ramping is so wonderful, no need for LED swaps (unless you’re wrong and prefer cool white, lol).
That’s fine, but it’s not needed for most since a wide range of temps are covered. Those with the ability can, and those that can’t still have a good range. With the ramping, even with swapping the LED’s you get a more versatile light.
The Nichia E21A is the better choice. It has a similar CRI (R9080), a tint under the BBL or on it, is available with every conceiveable CCT (2000K-6500K) and is more powerful compared to the Optoslis (less LEDs required). Here are Maukkas tests. This would require the use of a pcb with a special insulation material that has a low thermal resistance like Clemence and led4power use (should not be a problem cost wise since we need to get a pcb made anyhow). It would have the added benefit that we can put the FET onto this pcb to improve its heatsinking substantially (like led4power does). In my eyes this is the most elegant design.
As djozz has already mentioned tint is more important than ever higher cri ratings. The E21 R9080 LEDs offer a great tint.
The Optisolis’ lower output / lower max amps can be fixed by using more of them. Spreading the emitting surface is not a problem for a lantern….quite the opposite in fact.
That said, I’m not voting for any emitter change, I’m fine with LH351* as well as E21 / Optisolis.
You can’t really see the difference between R9080 and R9090. Thats a tiny difference.
Also, the 5000K Optisolis that Maukka tested was above the BBL. So even these aren’t perfect.
Yes, but if we don’t use a boost driver we would have to put all those LEDs in parallel. Since they all have slightly different Vfs they would all be driven at different currents. With so many LEDs in parallel the lifetime of some of them might be reduced.
Pretty cool to use Optisolis leds. Half a year ago I suggested using a bunch of 3030 midpower leds and did not get much acclaim. In the current phase I do not think it is a good idea to change the led choice anymore. I hope that Sofirn can get their hands on some good tinted LH351D’s
I’m signed up for several lanterns and am really looking forward to these. The biggest thing I care about is durability since these will be used for camping and will be bumping around in trucks offroad, etc. I don’t need the power bank, I don’t need tint shift, I don’t need a lot of the cool options and features that will come with this lantern (although I’m not against them either). What I do want is durability first and foremost.
GhostofHarry, added you to the interest list at number 975
You definitely did, and I definitely didn’t add your second light, until you reminded me. Your second is number 976 on the interest, sorry for the oversight. :disappointed:
