Tank007 UC17 flashlight is a stylish and compact rechargeable flashlight. Only with a 18650 battery achieving 800 lumens of brightness and a range of up to 300 meters, UC17 will meet your needs such as camping, riding, and searching etc. In addition, with 5 model of high med and low strobe SOS, it could suit for everyday lighting perfectly. It can also be used as a mobile power source to provide powerful lighting support for outdoor travel and emergency. With anti-slip texture and prevent overheating design, you will love with this exquisite fellow.
Main Parameters:
Emitters: 1* Cree XM-L2 LED
LED Lifespan: above 100,000 hours
Battery Type: 18650
Max Brightness: 800 lumens
Beam Distance: 200-300m
Max Runtime: 30h
Input Voltage: 3.0 - 4.5V
Impact Resistance: 1.5M
Mode: 5 modes (High - Med - Low - Strobe - SOS)
Waterproof: IPX-6
Brightness Levels and Runtime:
High: 800lm - 100% power ( 1.5 hours )
Med: 400lm - 50% power ( 4 hours )
Low: 200lm - 25% power ( 30 hours )
Product Features:
● Charging with indicator function, red is not full of electricity, green represents a full charge.
● Constant current circuit chip for constant brightness. The flashlights has memory function to memorize the last mode.
● Max 800 Lumens, can meet the requirement of high power lighting.
● The United States imported Cree new generation of LED lamp beads, energy saving, life of 100,000 hours, brightness of 800 lumens, battery life of up to 30 hours, meet your lighting needs.
● Constant current circuit chip which maintains constant brightness.
● Made of durable aircraft-grade aluminum T6061, hard-anodized anti-abrasive finish
● Head rotation switch, which is durable and easy to operate.
● 5 modes of lighting can be applicable to your lighting requirements for different environments.
● Powered by 1 x 18650 2600mAh rechargeable battery.
● IPX6 waterproof design, can satisfy daily waterproofing requirements.
● Intelligent memory gear position automatically remembers the gear position when it was last turned off.
● Body is light and compact, the distinctive head button design makes it easy for you to control with one hand.
Tank007 UC17 in its class is an ideal cost-effective USB charging flashlight with high quality on the market. Thanks to the practical features, it is a practical luminaire for outdoor activities and everyday use. GearVita offers it for you via this link: https://gearvita.com/tank007-uc17-usb-rechargeable-flashlight-800-lumens.html
Related products:
https://gearvita.com/tank007-pt12-high-power-tactical-flashlight-800lm.html
https://gearvita.com/tank007-ec01-mini-magnet-flashlight-400-lumens.html
